Multiple compiler versions installed at the same time
Greg_R
PostPosted: Mon Sep 25, 2006 1:00 pm     Reply with quote
Is there a clean way to have multiple versions installed at the same time?
I have two large projects. One requires 3.236 and the other needs 3.249.
I just did a release for one so now I'm going to unistall the compiler and reinstall the other. This is getting really old.
Greg
PostPosted: Mon Sep 25, 2006 1:04 pm     Reply with quote
Which compiler are you using -- the IDE compiler (PCW/PCWH) or
the command line compilers (PCM, PCH, etc.) ?
If you let me know, I can post links to extensive discussions on this
topic.
Greg_R
PostPosted: Mon Sep 25, 2006 2:21 pm     Reply with quote
I use the IDE with PCWH. I only work with 18Fs.
I did a search that came up empty before I posted the question...
Greg
PostPosted: Mon Sep 25, 2006 2:36 pm     Reply with quote
Here is a thread in which Ttelmah explains how to do it.
He also uses PCWH.
http://www.ccsinfo.com/forum/viewtopic.php?t=20474
Greg_R
PostPosted: Tue Sep 26, 2006 11:22 am     Reply with quote
Excellent, I will give that a try! Are there any gotcha's with 4.x?
