Christophe
standalone ? |
Posted: Tue May 31, 2005 8:28 am |
I am using:
* CCS PCWH latest compiler version
* ICD-U40
When I use the debugger to program, my program runs perfectly. Now I want to use my application in standalone mode, but nothing works !?
Code: | #include <16F877A.h>
#device adc=8
#fuses XT, NOPUT, NOPROTECT, NOLVP, NOCPD, NOWRT,WDT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
What can I be doing wrong? |
drolleman Guest
Posted: Tue May 31, 2005 8:41 am |
you are in debug mode you must program the chip. i use mplab as my enviroment so instead of setting my debugger i set the unit as a programmer |
Christophe
Posted: Tue May 31, 2005 8:42 am |
How can I change that? if that's the problem.. |
Konrad
Use CCS ICD.EXE stand alone program |
Posted: Tue May 31, 2005 3:58 pm |
Use the stand alone ICD program.
Make sure you have the icd define off before you compile.
You can run the program with the ICD connected, or simply disconnect the ICD. |
