play songs on a peizo buzzer?
Goto page Previous  1, 2
SherpaDoug
PostPosted: Thu Dec 22, 2005 7:58 am     Reply with quote
Try:
X0R(portc, 0b000 0011);
Now it won't change any of the other bits. If portc is mapped to the actual port the XOR itself will change the port pins without affecting the tristate register.
Mark
PostPosted: Thu Dec 22, 2005 10:57 am     Reply with quote
Christophe wrote:
So,
that would be
output_high(C0);
output_low(C1);
X0R(portc, 1111 1111);
output(portC);
the problem is that all port C pins are changing and becoming outputs. I don't want that because they are used for other purposes.
This function is causing the problem
output(portC);
you will need to specify fast_io to prevent this and handle the tris register yourself.
mcafzap
PostPosted: Fri Dec 23, 2005 7:11 am     Reply with quote
To avoid RMW problems on the I/O ports, here is my buzzer routine:
void shortbeep(void)
int8 t;
t = Port_A & 0xCF;
for(j=0; j<=250;j++)
   Port_A = t | 0x20;
   Delay_Us(120);
   Port_A = t | 0x10;
   Delay_Us(110);
Port_A = t;
Steve
Page 2 of 2
