tberckmann Guest
| Interfacing to a Multimediacard (MMC) |
Posted: Tue May 24, 2005 11:11 am |
I am attempting to connect a PIC18f6720 to an Atmel AT45DCB008 MMC using the SPI bus.
I have confirmed that the card is receiving the required 3.3V, that it is properly grounded, and that the pins are properly connected to the bus.
I initialized the card with the following code:
SETUP_SPI(SPI_MASTER | SPI_CLK_DIV_4);
SSPSTAT |= 0x40; // set CKE - bit 6
SSPCON1 &= ~0x10; // unset CKP - bit 4
chip_select(NONE); // set SS = 1 (off)
for(i=0;i<10;i++) // send at least 74 clks on
SPI_WRITE(0xFF);
chip_select(MMC_CS); // set SS = 0 (on)
delay_us(250);
SPI_WRITE(0x40); // send reset command
SPI_WRITE(0x00); // all the arguments are 0x00
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0x95); // precalculated checksum
SPI_READ(0xFF)
I confirmed (using an oscilloscope) that the write commands were in SPI mode 0 (that the command was available on the rising edge, and properly formatted, etc...) and that all of the timing was correct. However, in the final SPI_READ command, there is no response from the card, despite polling for several seconds.
Does anyone have some troubleshooting tips or suggestions for me? |
Posted: Tue May 24, 2005 11:32 am |
The AT45DCB008 has a physical connector and dimensions that are equal to an MMC card, the used protocol however is completely different. I had a quick look at the datasheets and the protocol looks much easier than the protocol for the MMC card.
For a detailed description of the AT45DCB008 you have to look at the datasheet for the AT45DB642 |
