d00dajo
| Defining a structure in CCS, linearly |
Posted: Fri May 13, 2005 5:05 am |
I have run into a problem with code explosion using the CCS compiler.
Now, what I want to define is something like:
struct
int8 b[6]
int8 c[8]
int8 d[2]
int 8 e
}a[3]
That is , I want to access a[1].d[0] etc. Now, looking at the assembler code generated I suspect that the structure is NOT saved in the way I intended it to be.
The way I want to be able to use it, the memory for "b" should be allocated linearly.
That is, to get a[1].b[5] I would like to use
int16 * ptr ;
ptr = a[1].b;
ptr[5]; //THIS SHOULD BE a[1].b[5]
Now, it appears that the struct is not saved in this manner. How do I define a structure with the memorymapping I want?
That is memory usage as follows (in bytes):
//Start of struct
adr+0:[a0.b0]
adr+1:[a0.b1]
adr+2:[a0.b2]
adr+3:[a0.b3]
adr+4:[a0.b4]
adr+5:[a0.b5]
adr+6:[a0.c0]
And so on.
(Yes, I could manually define every variable and separate them, but surely there must be a way to define a struct to do this?)
Thanks in advance //DJ. |
| Re: Defining a structure in CCS, linearly |
Posted: Fri May 13, 2005 6:02 am |
In the portion of code you write, ptr is defined as a pointer to int16, so ptr[5] will return the value of the 5th int16 located 10 bytes after a[1].b.
So,
//THIS SHOULD BE a[1].b[5] : NO
Now, it appears that the struct is not saved in this manner: are you sure ? How is it stored then ?
In my apps, I never had the strange behaviour you are describing (I have arrays of structs each composed of others struct (these containing bit fields) and arrays of int8) |
JPA Guest
Posted: Fri May 13, 2005 6:03 am |
So,
d00dajo
| OF COURSE!!!!!!!!!!!!!!!!! |
Posted: Fri May 13, 2005 6:30 am |
Of course you are right. I couldnt for my life figure out WHY the compiler would store the information in any other way than in a linear fashion. And of course, it doesnt. It works exactly as I wanted it to, the error was in accessing the struct.
Thanks for your help!
//DJ. |
d00dajo
//DJ. |
