Pin on PIC drive
Christophe
Pin on PIC drive
PostPosted: Thu May 12, 2005 8:56 am     Reply with quote
this is the scheme:
http://expand.xs4all.nl/uploadarchief/download.do?file=schma.jpg
I need to drive ENABLE_CHARGING LOW to disable charging. This means that the pin on the PIC (I'm using PIC16lF877A Vdd = 3V) is on Vadap via a pull-up resistor. Vadap = 8V ; can that harm the pic?
thx
newguy
PostPosted: Thu May 12, 2005 9:17 am     Reply with quote
That will definitely harm the PIC. Use a transistor to pull that line low instead.
PIC --- R --- base of BJT (or gate of FET), emitter (or source) to GND
The collector/drain of the transistor then goes to your ENABLE CHARGING line. The only difference is that now a logic high on the PIC line will bring ENABLE CHARGING low.
PostPosted: Thu May 12, 2005 9:43 am     Reply with quote
There is another way without requiring additional components and without harming the PIC. Use RA5 of the PIC to drive this PIC. RA5 is open drain.
newguy
PostPosted: Thu May 12, 2005 9:53 am     Reply with quote
Good point, only it's A4 that's open drain, not A5.
The only thing is that A4 can only tolerate a maximum of 8.5V (first page of chapter 17 of the 877A's data sheet). If the line that it is connected to is a nominal 8V, it doesn't leave much room for error.
PostPosted: Mon May 16, 2005 1:43 pm     Reply with quote
can I put a diode in series with the resistor? then I have 8V-0.7V = 7.3 op RA4
newguy
PostPosted: Mon May 16, 2005 2:44 pm     Reply with quote
I guess so. I'm just overly cautious - experience has taught me to be that way. As I said before, I'd do things differently.
