implementing diode keyboard matrix
Christophe
PostPosted: Tue May 10, 2005 1:27 am     Reply with quote
I want to implement a 9 x 8 keyboard matrix (72 keys) with some diodes for simultaneous keypress detection. So I will have rows and columns. How does the algorithm works? Are the Rows outputs and the columns inputs? Are there any examples?
http://www.sensotec.be/ASP/Catalog.asp?ID=Sensotec%20EUROSCOPE&LC=10 You can see the device with the buttons..
PostPosted: Tue May 10, 2005 10:46 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=19726
This will give you an idea of how to start.
Christophe
PostPosted: Thu May 12, 2005 1:51 am     Reply with quote
He's using portB interrupts.. I cannot use that code because I have 9 rows x 8 columns
PostPosted: Thu May 12, 2005 8:30 am     Reply with quote
Right. I didn't say that you could use that code as is, only that it would help give you ideas about what to do. Now that you see how it's done with 16 buttons, couldn't you "scale" that approach to get your 72 buttons?
treitmey
PostPosted: Thu May 12, 2005 8:47 am     Reply with quote
Christophe
PostPosted: Thu May 12, 2005 8:51 am     Reply with quote
Well the matrix can be divided into 3 matrices:
* 3R x 8C matrix : simultaneous press detection needed
* 1 x 8 matrix : simultaneous
* 5 x 8 matrix: only single press detection needed
treitmey
PostPosted: Thu May 12, 2005 9:00 am     Reply with quote
Christophe
PostPosted: Thu May 12, 2005 9:20 am     Reply with quote
Of course that is possible..
set row '1'
read 8 column bits
=> decode bits to keypresses
treitmey
PostPosted: Thu May 12, 2005 10:00 am     Reply with quote
Sory, I guess you have this solved.
PostPosted: Mon May 16, 2005 1:48 pm     Reply with quote
I mean it is possible without extra IC's ... with a pic only and diodes.. I'm just asking for some tips/code samples , algorithms, something that can get me started...
