mike holeton Guest
| Converting Micro Chip J1939 to CCS J1939 Help! |
Posted: Mon May 09, 2005 8:45 pm |
The following won't compile because of the "static rom struct"
static rom struct TX_BUFFER_INFO_STRUCT BUFFER_TABLE[ECAN_MAX_TX_BUFFERS] = {
{ 0x06 }, // TXB1
{ 0x08 }}; // TXB0
I was wondering if anyone has converted the Micro Chip J1939 library to a CCS library.
Mike |
Posted: Tue May 10, 2005 12:28 pm |
| Quote: | | The following won't compile because of the "static rom struct" |
In CCS, to place a variable in ROM, you use "const".
I think you'll need to make a lot of test programs, to prove
to yourself that your modifications will work.
This means not only compiling the modified declarations, but it
also means putting in sample code to access the structures.
Preferably, use code that was taken right out of the J1939.c program.
That's what I've done below. I've also added code to access all
elements in the structure and display them. That way, I know I can
read all of them. I get the following result displayed on my terminal
window:
06
08
In the code below, you'll notice that I've commented out certain lines
of the J1939 code, and substituted lines that are compatible with CCS.
1. They've declared an instance of the structure, and they want to place
it in ROM. In CCS, this done by using the type specifier 'const'.
So I've removed 'static rom' and replaced it with 'const'.
2. They've declared LastTXBufferUsed to be static. But in CCS, 'static'
doesn't do much for you. In a normal compiler, you have linkable
object modules and if want variables to local to a module, then you
declare them to be 'static'. But CCS has no linker. All "modules"
must be #included into the main source file. In CCS, using 'static'
only really makes sense if you use it within a function so as to preserve
the variable between calls to that function. I suppose you could leave
it in there on that particular line and it really wouldn't hurt. CCS does
initialize static variables to zero unless you initialize them to some
other value. So keep that in mind. This is in the manual.
3. I've used a #byte statement to declare the CANCON register address.
That's how it's done in CCS.
4. They're using "unsigned char", and in CCS, a "char" is unsigned by
default. It doesn't really hurt to leave it as "unsigned char", so that's
what I did.
You're going to need to become familiar with the differences between
data types for CCS and other compilers. In CCS, a "long" is an
unsigned 16-bit value. An "int" is an unsigned 8-bit value.
It's best to use the alternate names for CCS data types, which are
int8, int16, and int32. These are unsigned. It's much easier to see
what the size is when you do it that way.
| Code: | #include <18F458.h>
#fuses XT, NOWDT, NOPROTECT,PUT,BROWNOUT,NOLVP
#define ECAN_MAX_TX_BUFFERS 2
struct TX_BUFFER_INFO_STRUCT {
unsigned char WindowBits; };
//static rom struct TX_BUFFER_INFO_STRUCT BUFFER_TABLE[ECAN_MAX_TX_BUFFERS] = {
const struct TX_BUFFER_INFO_STRUCT BUFFER_TABLE[ECAN_MAX_TX_BUFFERS] = {
{ 0x06 }, // TXB1
{ 0x08 }}; // TXB0
//static unsigned char LastTXBufferUsed = 0;
#byte CANCON = 0xF6F
CANCON = BUFFER_TABLE[LastTXBufferUsed].WindowBits;
printf("%x \n\r", BUFFER_TABLE[LastTXBufferUsed].WindowBits);
LastTXBufferUsed = 1;
mike holeton Guest
Posted: Tue May 10, 2005 8:19 pm |
Thank You very much for the help. I am begining to think this is not going to be a easy(maybe not even fun conversion) to do. I will take your advice and see how far I can go with it. I may be back for additonal help, so bare with me.
Thank You
Mike (licensed and maintenced CCS member) |
rwskinner Guest
Posted: Tue Dec 05, 2006 8:39 pm |
Mike,
Did you ever make it very far on the Microchip J1939 to CCS conversion.
I'm faced with the same thing right now, my problem is I'm just now learning C (Came over from PBP) |
ScottSD
Posted: Thu Sep 15, 2016 3:34 pm |
| I would be very interested in this as well. |
Joined: 01 Jul 2010 Posts: 9656 Location: Greensville,Ontario
Posted: Fri Sep 16, 2016 5:05 am |
| gee an 11 year old post, does this make the 'record book' ? |
