| View previous topic :: View next topic   |
			smashHIT
				| Wrong # of cycles in delay_cycles...? |
				 Posted: Thu May 05, 2005 5:04 pm     |
				So, I'm trying to produce a 38,5kHz square wave on my PIC for an IR diod. I'm running a 16F874A in 4MHz, wich means that the internal clock is 1MHz. I have figured out that I need a pulse period of ~26us to achive 38,5kHz. Wich means that i can set a PIN to be high for 13us, then low for 13us and so on... right?
Well, i tried this code: (sample)
 	  | Code: | 	 		  while(true){
     output_high(PIN_D1);
     delay_cycles(13);
     output_low(PIN_D1);
     delay_cycles(13);
But when looking in the asm listing, I don't end up with 13 cycles of delay, rather 8. Looks like this:
 	  | Code: | 	 		  ....................          delay_cycles(13);
0013:  MOVLW  04
0014:  MOVWF  20
0015:  DECFSZ 20,F
0016:  GOTO   015 |
Am I looking at this wrong?
By the way...
I'm trying measure a distance with my IR diodes, does anyone have any tips on that?
Thanks! |
				 Posted: Thu May 05, 2005 5:12 pm     |
				Any instruction that does a jump takes two cycles.
Look at it again. |
			smashHIT
				 Posted: Thu May 05, 2005 5:21 pm     |
				Yes, forgot about about that NOP due to the jump. Thanks!
				 Posted: Fri May 06, 2005 4:13 am     |
				Remember also that the 'output_high', and 'output_low', each take a cycle, and the while loop involves both a test, and a jump. You'd probably need the first delay to be twelve cycles (to allow for the output instruction), and the second to be 9 (guessing slightly here).
			SherpaDoug
				 Posted: Fri May 06, 2005 7:00 am     |
				How long a distance are you trying to measure?  What resolution and accuracy do you need?  What is the medium, air, water, vacuum? _________________ The search for better is endless.  Instead simply find very good and get the job done. |
			DragonPIC
				 Posted: Fri May 06, 2005 11:59 am     |
				Looks like you could accomplish what you are doing mor precisely using PWM. _________________ -Matt |
			smashHIT
				 Posted: Fri May 06, 2005 3:23 pm     |
				My mind is set on a miniature "radar" unit, but with IR-diodes. The medium will be air, and the maximum rage will be arund 40cm (with 5 different zones). It's just fur fun!
The diodes sit ontop of a servo, that spins 180 degrees, back and fourth.
Okey, so you say I should use PWM... how do I manage to get the dividers and stuff right for a 38,5kHz pulse?
I red that it was recomended to use another IC, like 555 or so, to get the modulation pulse. And then control that signal (on and off), with the PIC +some logic. Anyone familiar with that? |
			DragonPIC
				 Posted: Mon May 09, 2005 2:37 pm     |
				setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_1,26,1);  //(1/4MHz)*4*1*26 = 26us = 38.5Khz
SET_PWM_DUTY(52); //13us/(1*(1/4MHz))
should set things up for you.  You will have to use RC2 though. _________________ -Matt |
