Geust Guest
| aj.. 1wire me baby |
Posted: Sat Apr 30, 2005 3:37 pm |
Hey, I change my code,
but it still doesnt work !
can you take a look on my code :
| Code: | #include <16f870.h>
#fuses XT,NOWDT,NOLVP
#define SKIP_ROM 0xCC
#define CONVERT_T 0x44
#define READ_SCRATCHPAD 0xBE
#define DQ PIN_C4
//#define Tx_DS1820 PIN_C5
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
// OW_RESET - performs a reset on the one-wire bus and
// returns the presence detect. Reset is 480us, so delay
// value is (480-24)/16 = 28.5 - we use 29. Presence checked
// another 70us later, so delay is (70-24)/16 = 2.875 - we use 3.
unsigned char ow_reset(void)
unsigned char presence;
output_low(DQ); //pull DQ line low
delay_us(480); // leave it low for 480us
input(DQ); // allow line to return high
delay_us(70); // wait for presence
presence = DQ; // get presence signal
delay_us(424); // wait for end of timeslot
return(presence); // presence signal returned
} // 0=presence, 1 = no part
// READ_BIT - reads a bit from the one-wire bus. The delay
// required for a read is 15us, so the DELAY routine won't work.
// We put our own delay function in this routine in the form of a
// for() loop.
unsigned char read_bit(void)
unsigned char i;
output_low(DQ); // pull DQ low to start timeslot
input(DQ);// then return high
for (i=0; i<3; i++); // delay 15us from start of timeslot
return(DQ); // return value of DQ line
// WRITE_BIT - writes a bit to the one-wire bus, passed in bitval.
void write_bit(char bitval)
if(bitval==1) input(DQ); // return DQ high if write 1
delay_us(104); // hold value for remainder of timeslot
input(DQ);
}// Delay provides 16us per loop, plus 24us. Therefore delay(5) = 104us
// READ_BYTE - reads a byte from the one-wire bus.
unsigned char read_byte(void)
unsigned char i;
unsigned char value = 0;
for (i=0;i<8;i++)
if(read_bit()) value|=0x01<<i; // reads byte in, one byte at a time and then
// shifts it left
delay_us(120); // wait for rest of timeslot
return(value);
// WRITE_BYTE - writes a byte to the one-wire bus.
void write_byte(char val)
unsigned char i;
unsigned char temp;
for (i=0; i<8; i++) // writes byte, one bit at a time
temp = val>>i; // shifts val right 'i' spaces
temp &= 0x01; // copy that bit to temp
write_bit(temp); // write bit in temp into
delay_us(104);
char get[10];
int k;
char temp_f,temp_c;
ow_reset();
write_byte(0xCC); //Skip ROM
write_byte(0x44); // Start Conversion
delay_us(104);
ow_reset();
write_byte(0xCC); // Skip ROM
write_byte(0xBE); // Read Scratch Pad
for (k=0;k<9;k++)
{ get[k]=read_byte();
printf("\n ScratchPAD DATA = %X%X%X%X%X\n",get[8],get[7],get[6],get[5],get[4],get[3],get[2],get[1],get[0]);
whats wrong??
Thx |
burned Guest
Posted: Sun May 01, 2005 9:36 am |
I spent 2 1/2 weeks beating my head on trying to get the 1820 to work.
I tried every code segment on this board -- and there are a lot --'just search the forum and you'll find it" -- yeah, you'll find em - lots of em.
BUT -- I got it working last nite. I finally narrowed it down to : CCS compiler does NOT do accurate timing with delay_us
the problem was not the code but the TIMING.
I added a local segment for us delay from some web site (could have been this one -- I spent so much time searching the web for 'working' code for this -- i lost track of what is from where)
#define XTAL_FREQ 20MHZ /* Crystal frequency in MHz */
#define MHZ *1000L /* number of kHz in a MHz */
#define delayus(x) { unsigned char _dcnt; \
_dcnt = (x)*((XTAL_FREQ)/(12MHZ)); \
while(--_dcnt != 0) \
continue; }
then I replace all the ccs delay_us with the local function delayus and WHAM the code works -- in fact they all started working when I substituted the delay funciton.
The one I have listed has code to deal with the slower clock speeds (like your 4 mhz ) and I chopped that out -- so this prob won't work for you, but the deal is TIMING ! us timing.
find a us delay function for your clock speed to use instead of the library funciton.
good luck |
geust Guest
Posted: Sun May 01, 2005 11:58 am |
finally some good news!!
Thx,
but how can I create a function that gives me uSeconds???
I'm just a rookie,sorry..
and I dont know how to creat a uSecond Segment
Please help
Thanks |
Posted: Sun May 01, 2005 4:26 pm |
| Quote: | | BUT -- I got it working last nite. I finally narrowed it down to : CCS compiler does NOT do accurate timing with delay_us |
It always helps a lot when you mention the compiler version you are using.... See the thread http://www.ccsinfo.com/forum/viewtopic.php?t=19516 for the description of a delay_us() bug in v3.191 - 3.202, causing delays larger than 153 to fail. |
