VREF in PCH
Orcino Borges
VREF in PCH
PostPosted: Tue Feb 25, 2003 9:02 am     Reply with quote
Hi, in PCH with 18f458 the comand
setup_vref(OFF); not compiler and send a erro
"UNDEFINED INDENTIFER". I need VREF in a VDD.
Help me.
Orcino
Original Post ID: 12083
R.J.Hamlett
Re: VREF in PCH
PostPosted: Tue Feb 25, 2003 9:33 am     Reply with quote
:= Hi, in PCH with 18f458 the comand
:= setup_vref(OFF); not compiler and send a erro
:= "UNDEFINED INDENTIFER". I need VREF in a VDD.
:= Help me.
The 18F458, does not have a internally configrable Vref (which this function is for). It allows you to connect the Vref input, to Vdd, AN3, or the internal _fixed_ reference voltage. This is done by the 'SETUP_ADC_PORTS' function. The 'SETUP_VREF' function, is confined to chips that have a configurable voltage divider internally attached to the Vref source, and this function then controls which 'tap' from the divider is used.
You need to look up which analog inputs you want to use, and then select the option with this combination, and Vref=Vdd. The options available are listed in the include file for the chip.
Original Post ID: 12084
