Over ride the PWM and set the output bit high?
frierray
PostPosted: Sat May 16, 2009 8:12 am     Reply with quote
Hi All,
I am using a 18f2520 with compiler version 4.073 and need to set the PWM output pin high at the end of the PWM code. When I set the PWM duty to 0, pin C2 is in a low state. I need to set it high to have the braking function work in a LMD18200. I tried output_bit(PIN_C2, 1); however it does not set C2 high. Is there someway to over ride the PWM and set the output bit high?
Ray
PostPosted: Sat May 16, 2009 9:43 am     Reply with quote
Just set the duty to the maximum.....
frierray
PostPosted: Sat May 16, 2009 3:39 pm     Reply with quote
Thanks, that did just what I needed. So the output_bit(PIN_C2, 1); cannot override the PWM state for the pin.
PostPosted: Sun May 17, 2009 2:42 am     Reply with quote
As the hardware manual clarifies, second output functions of I/O ports take priority over the port function. You have to disable the respective function, e.g. PWM, UART output, SPI to reenable port operation.
