oladawg Guest
how to convert a byte array to a string.... |
Posted: Mon Mar 21, 2005 11:57 pm |
Hey guys i'm trying to convert some information from ibuttons, which is giving in bytes to a string so I can make a strcmp to see if i perform a function or not....
The question is does anybody know how to convert a byte array to a string....
Any help would be most appreciated.....
O |
Andreas
Posted: Tue Mar 22, 2005 1:59 am |
Why not comparing the byte direct using a switch statement ?
Will be the fastest solution and is easy to program
Andreas |
Posted: Tue Mar 22, 2005 5:24 am |
In one sense, a byte array, already is a string.
If (for instance), you have:
byte demo[8] = {0x20,0x48,0x65,0x6c,0x6c,0x6f,0x20,0};
Then print("%s",demo), will print ' Hello '.
The only special feature of a 'string', is that it must have a null terminator, and as such, a null must not appear anywhere else in it.
However the code for strcmp, is in the string.h include file, and doing a version to allow zero to exist, and just use a size (like strncmp, but ignoring the terminator), will allow byte arrays to be compared, without having to fiddle around, or worry about the terminator characters, ad is probably easier.
Posted: Tue Mar 22, 2005 5:35 am |
why strcmp and not memcmp? |
Posted: Tue Mar 22, 2005 8:22 am |
Will the same rules apply if i'm trying to move:
byte demo[8] into a char string[]?????
Or is there some special function I have to perform??? |
oladawg Guest
Posted: Tue Mar 22, 2005 8:24 am |
Sorry Ttelmah, i was going to quote you and i went about it the wrong way and I put your name down as if you were asking the previous question..... Hey that's a good way to get somebody in trouble.... |
