asic1984
| delay problem? |
Posted: Wed Mar 09, 2005 12:32 pm |
hi
i am new to ccs and to programming pic with the c language
i made a simple program that output to portb pin 6 of pic 16f877
#include "E:\pic16f877\ccs\1\1.h"
#use delay(clock=10000000)
while(true)
output_high(PIN_B6);
delay_ms( 10 );
output_low(PIN_B6);
delay_ms( 10);
the problem is that the delay should be 10 milliseconds but in fact it is nearly up to 4 seconds
so what is the problem
thanks for help |
Posted: Wed Mar 09, 2005 12:43 pm |
| Quote: | | #include "E:\pic16f877\ccs\1\1.h" |
It wouldn't surprise me if it has something to do with the mysterious "1.h" file.
Your simple program should not look like that, it should look more
like the following one. In this one, you can see the #fuses statement.
Also, I suspect that you may be using ICD2. If so, ICD2 uses pins B6
and B7. You should pick another pin for your output. I assume you
have a demo board. If you have PicDem2-Plus, it has LEDs on pins
B0 to B3. So a good choice for your test program would be pin B0.
Also, what are you using for a crystal or oscillator. Do you guarantee
that it's really running at 10 MHz ? What numbers are stamped on
the crystal or oscillator ?
| Code: | #include <16F877.H>
delay_ms( 10 );
output_low(PIN_B6);
delay_ms( 10);
asic1984
Posted: Wed Mar 09, 2005 12:55 pm |
hi
thanks for your help
| Quote: |
it was generated by the ccs ...not by me
i am not using any emulator like icd2 i am just using jdm programmer and then put it to a circuit from my design ...so no problem in slected pins
| Quote: |
the oscillator is 10MHZ as what is stamped on the crystal  |
SherpaDoug
Posted: Wed Mar 09, 2005 12:56 pm |
Can you check that your oscillator is really running at 10MHz?. It could be defective and running 400 times slower.
The only thing that is supposed to happen at anywhere near that speed is the Watchdog timer. Try disabling the WDT and see if things change.
Next I would look at the assembly code in the .lst file. If you have ever done assembly code for any uP this simple program should not be hard to figure out. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed Mar 09, 2005 1:12 pm |
| Quote: | #include "E:\pic16f877\ccs\1\1.h"
it was generated by the ccs ...not by me |
I've never heard of this.
What compiler do you have ? Is it PCW ? What version ?
The version is at the top of the .LST file, which is generated when
you compile a program. It will be a number like 3.219 or 3.221, etc. |
Mark
Posted: Wed Mar 09, 2005 3:16 pm |
| It wouldn't hurt ya to post what is in 1.h! |
asic1984
Posted: Wed Mar 09, 2005 10:22 pm |
hi
that it is the code inside the 1.h file.....
#include <16F877.h>
#device adc=8
#fuses HS,WDT
Mark
Posted: Thu Mar 10, 2005 6:51 am |
| Well as PCM Programmer told you, you have problems there. You have the watchdog timer enabled and are not resetting it. You have LVP enabled. I suggest you try his code. |
asic1984
Posted: Thu Mar 10, 2005 9:49 am |
hi
thanks too much i will try it
