write / read eeprom -- integers
Goto page 1, 2  Next
Guestt
PostPosted: Sat Mar 05, 2005 11:45 am     Reply with quote
Im using 16F877 and if i write values form 0 to 10 all is working ok.
If i want to write value 240 i get blocked program...
How can i write and read bigger int data to eeprom?
John
rwyoung
PostPosted: Sat Mar 05, 2005 12:01 pm     Reply with quote
Post smallest possible sample program that exhibits the problem. Also include the compiler version number and programmer type.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
Guestt
PostPosted: Sun Mar 06, 2005 4:19 am     Reply with quote
#define adr_bPress  0xF000
main()
write_eeprom(adr_bPress,00);
if(bPress())
   lcd_gotoxy(1,1);
                    value++;
   write_eeprom(adr_bPress,value);
                    printf(lcd_putc,"%X",value);
Im trying to count from 1 to 240... First 10 numbers are displayed OK but after that nothing happens.
2.)
How can i read stored eeprom values thet are in range from 0xF000
to 0xF00A ?
Guesst
PostPosted: Sun Mar 06, 2005 4:25 am     Reply with quote
compiler version is 3.150 and programmer is ICD2..
PostPosted: Sun Mar 06, 2005 6:33 am     Reply with quote
With this code, you will wear out the EEPROM very fast!
Take care and write data only when needed.
PostPosted: Sun Mar 06, 2005 7:40 am     Reply with quote
... any suggestions or example code how to make this on correct way?
rwyoung
PostPosted: Sun Mar 06, 2005 8:48 am     Reply with quote
Forgetting for a moment that you are going to wear-out the EEPROM quickly with your code, I can't tell much from what you posted. I should have been more explicit and said the SMALLEST POSSIBLE COMPLETE PROGRAM.
Given the age of your compiler I'd suspect it isn't doing the internal eeprom write correctly. Look at the LST file and compare the code associated with "write_eeprom" with the datasheet for your part. There will be a section in the datasheet that discusses the internal EEPROM and the correct way to write. And depending on your exact part, you may also need to check the errata.
Rob Young
Mark
PostPosted: Sun Mar 06, 2005 9:11 am     Reply with quote
From what he posted, he is not able to get the printf command to work correctly. He doesn't even read the eeprom values.
Guestt
PostPosted: Mon Mar 07, 2005 12:26 pm     Reply with quote
#include <16F877.h>
#include <lcd.c>
#device adc=8
#use delay(clock=20000000)
#fuses HS,WDT
#define adr_bPress 0x00
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_counters(RTCC_INTERNAL,WDT_18MS);
   setup_timer_1(T1_DISABLED);
   if(INPUT(PIN_B0))
      //lcd_gotoxy(1,1);
      value++;
      printf(lcd_putc,"%X",read_eeprom(adr_bPress));
/// ---- this is what im using BUT ich need some new(better) way to to this. Can you give me some eg. from 1 to 500 ?
Manfred
ckielstra
PostPosted: Mon Mar 07, 2005 2:53 pm     Reply with quote
You are telling us you want to have an improved version of the shown code, but which part exactly do you need improvement on? It looks fine to me, so what is the reason you want suggestions for improvement?
The only problem I can think of is that the eeprom is specified to a minimum of 100.000 write cycles, say 10.000 to be on the safe side. How often is your program going to write to the eeprom?
PostPosted: Mon Mar 07, 2005 3:19 pm     Reply with quote
This can't work. The 16F877 only has 256 bytes of internal eeprom.
The address range is 0x00 to 0xFF. You are trying to write to
an eeprom address that does not exist.
Mark
PostPosted: Mon Mar 07, 2005 3:29 pm     Reply with quote
Not to mention that he never increments the address if is actually trying to.
Mark
PostPosted: Mon Mar 07, 2005 3:32 pm     Reply with quote
Also read this but I think maybe his compiler is too old for it to affect him
http://www.ccsinfo.com/forum/viewtopic.php?t=21281&highlight=printf+glue
PostPosted: Sun Mar 27, 2005 7:12 am     Reply with quote
Can someone post another "universal" ( for different chips) working example for this task ?
Thank you in advance
PostPosted: Sun Mar 27, 2005 7:45 am     Reply with quote
.... forgot to mention, im counting this and i overwrite last value with the new one.
Goto page 1, 2  Next
Page 1 of 2
