Is this a bug or...?
Matte
PostPosted: Sat Mar 05, 2005 2:38 pm     Reply with quote
This code works fine with 3.156
LcdD4 = n & 1; // Lcd4 is a int1, n is a int8
it failed with version ???
but i do know it failed with 3.190 and later
I put this code to work it out now
if(n & 1) LcdD4 = 1; else LcdD4 = 0;
Confused
PostPosted: Sat Mar 05, 2005 3:08 pm     Reply with quote
This was reported at the time. It was a deliberate change, apparently to actually bring the compiler closer to ANSI in some way, but it results in arithmetic, that doesn't happen to 'hit' the bit used by an int1, resulting in a false. Use:
LcdD4=((n&1)!=0).
This should result in a faster version than the if test.
