Timer0 overflow interrupt does not work
flip
PostPosted: Tue Feb 15, 2005 3:07 pm     Reply with quote
I think all of the calculations for the time delay is correct and the program compiles however when I program it on to my PIC it does not do anything. I think I might be initializing my Timer0 interrupt incorrectly.
//Output on a LED every two seconds using Timer0
#include <18F458.h>
#use delay(clock=40000000)   //40MHz
#fuses HS, OSCSEN, BROWNOUT, BORV20, STVREN, NODEBUG, NOLVP //High Speed, Oscillator switching enabled, Brownout reset at 2.0V, Stack full causes rest, Low Voltage programming
int16 t = 0;
int out;
#int_TIMER0 // interrupt occurs every 3.2micro sec * 256 = 819.12 micro sec
TIMER0_isr()
   set_timer0(0); // set timer back to zero
   if (t++ == 2441)   // After t gets up to 2441 , 2 seconds has lapsed 819.12 micro seconds * 2442 = 2 seconds
      t = 0;
      output_c(0x01);  // output a light every 2 seconds
   set_tris_c(0xFF);
   setup_counters(RTCC_INTERNAL, RTCC_DIV_32); //pulse occurs every 3.2 micro seconds (1/(40MHz/4*32))
   enable_interrupts(global);
If anyone could figure out the problem that would be great. Thanks
PostPosted: Tue Feb 15, 2005 3:35 pm     Reply with quote
You set pin 0 on port C to go high, but you don't ever set it to go low.
ckielstra
PostPosted: Tue Feb 15, 2005 3:36 pm     Reply with quote
#include <18F458.h>
In order to run at 40MHz you have two options:
1) A 10MHz crystal and the fuse setting H4 i.s.o. HS
2) A 40MHz external clock driver (not a crystal!!!) and fuse setting EC or EC_IO i.s.o. HS.
ckielstra
PostPosted: Tue Feb 15, 2005 3:47 pm     Reply with quote
You don't need this line. The timer interrupt is generated on a timer overflow and the timer continues counting from zero.
In fact, this line will introduce a timing error: Interrupts are not not magic, it takes some time to enter the interrupt rountine (saving registers, discovering which interrupt is active, etc). On the PIC18 with CCS dispatcher code it takes about 40 instruction cycles (or so) to enter the interrupt routine. In this time the timer has advanced some 40+ ticks and you are setting it back.....
Because of the above mentioned interrupt overhead this is a waste of processing power!!! Please setup your counter with a higher prescaler setting so as to get just the minimum number of interrupts required for your purpose.
flip
Timer0 doesnt work
PostPosted: Tue Feb 15, 2005 4:04 pm     Reply with quote
I added a line of code into my main() and something for sure is not working because it should output high on Port C but it doesnt?
#include <18F458.h>
unsigned int16 t = 0;
#int_TIMER0 // interrupt occurs every 3.2micro sec * 256 = 819.12 micro seconds
TIMER0_isr()
      t = 0;
      output_c(0x03);  // output a light every 2 seconds
   set_tris_c(0xFF);
      output_c(0x01);
dyeatman
PostPosted: Tue Feb 15, 2005 4:29 pm     Reply with quote
As ckielstra asked you earlier, what are you using for a clock source? Are you using an external oscillator or a crystal? As he told you earlier you cannot run at 40MHZ using a crystal., the max is 25MHZ in HS mode.
I hope you have your LED tied to PIN 16 (RC1) otherwise, as newguy told you, it wont work at all.
Why are you using 0x3 and 0x1 to change the C1 pin? You are setting C0 (pin 15) high repeatedly. You can use 0x2 and 0x0.
What version of compiler are you using? If it is a fairly recent version why not use output_high(PIN_C1) and output_low(PIN_C1)?
