		| View previous topic :: View next topic   |
			Fabri
				| preprocessor command as CBLOCK in assembler |
				 Posted: Wed Apr 12, 2006 2:51 am     |
				Hi everybody,
I need to define a block string as constant.
In assembler I used CBLOCK to define a block of location as follow:
 	  | Quote: |
CBLOCK D'100'
one
two
three
four
ENDC
so:
one=100
two=101
three=102
four=104
I don't want use #define 200 times, is there any prerocessor command as CBLOCK ?
Thanks for support, |
				 Posted: Wed Apr 12, 2006 4:51 am     |
				Nothing quite the same in terms of a 'named' list. Remember though, that #ROM, will allow you to place data of any type at a location, so a structure with named elements can be placed where you want. However in general, in C, you wouldn't bother. Why would you need to put something at a spcific location?. In general, much easier just to declare a const structure or array, and let the compiler put it where it wants.
#Defines,won't do this at all (they are only preprocessor commands, and do not actually store anything).
			Fabri
				 Posted: Wed Apr 12, 2006 5:24 am     |
				Hi Ttelmah,
I have to define some eeprom location where read and write specific data.
In my project there is over 200 eeprom location.
Actually i use #define, have you got any idea ?
Thanks, |
				 Posted: Wed Apr 12, 2006 6:46 am     |
				I suppose you mean that you 'define' a symbolic 'name' for the location, to give it 'significance', and then access this with the read_eeprom function?.
This would be 'distinct' from what can be done using a structure defined 'at' a memory location (which would include the retrieval code).
You can do this with the C 'enum'.
So:
enum EEPROM_LOCN {one=100,two,three,four,five };
etc..
