FAT16 for MMC with SPI
Douglas Kennedy
PostPosted: Fri Feb 04, 2005 10:41 am     Reply with quote
I used a MMC connector but you could use a cut down floppy disk connector cable with the PCB type connector..the pin spacing is the same can can be wired so as to accept the MMC either contacts up or contacts down.
///////////////////////////// SPI interface for ///////////
// Multi Media Card FAT16 only
// FAT16 is a copyright of Microsoft
// This program was developed for personal use only based on
// information Microsoft placed in the public domain
// The code will read MMC SD cards in SPI mode previously formatted
// on a PC
// To write a file update to cards a 512 byte buffer is required
// to store the existing info from a sector prior to updating
// An append or writing a new sector can be done without the buffer
// THe PIC is at 5v and the MMC at 3.3v ... a 5v 7407 open collector
// buffer is used to level convert with 2.2k pull ups on the SPI lines
// the 3.3v MMC supply is either obtained from the 5v via a 3.3 Vreg
// or is dropped down via a led ( also works as a power on indicator)
// and smoothed via 100 uf cap
// the MMC card and the PIC aren't ever in sync so the card has to be polled to
// get the required response. Often a command is just repeated until the CARD responds
// and the card is polled until it sends the data
///             PIN Assignments  //////////////////////////////
/// _CS PIN_C2    // chip select for MMC
///  SDO PIN_C5
///  CLK PIN_C3
/// SDI PIN_C4
//    SPI hardware pins are
//      SDO     C5
//      SDI     C4
//      SCK     C3
///// Note old values needed before all SPI modes could be set up using SPI_setup
///    for 16 parts  ///////////
//#DEFINE SSPCON 0x14
//#DEFINE SSPSTAT 0x94
//#BIT SMP=SSPSTAT.7
//#BIT CKE=SSPSTAT.6
//#BIT CKP=SSPCON.4
//#BIT SSPEN=SSPCON.5
// For 18F452
//#DEFINE SSPSTAT 0x0FC7
//#DEFINE SSPCON1 0x0FC6
//#BIT CKP=SSPCON1.4
//#DEFINE MAX_FILES 2                 /// max number of open files
//#DEFINE MMC_BUFF_SIZE 32           /// 32 for PCM
#DEFINE MMC_FILE_NAME_SIZE 32
#DEFINE ROOT_CLUSTER 0
#DEFINE NEXT_CLUSTER 1
#define MMC_INIT_TRACE FALSE
#define MMC_CMD_TRACE FALSE
#define MMC_CLUSTER_TRACE FALSE // if true prints to serial port
#define MMC_OPEN_TRACE FALSE // if true prints to serial port
#define MMC_READ_TRACE FALSE // if true prints file_addr,cluster index etc
#define MMC_WRITE_TRACE FALSE
#define MMC_READ_BLOCK_TRACE FALSE
#define MMC_SET_BLOCK_LEN_TRACE FALSE
#define MMC_WRITE_BLOCK_TRACE FALSE
#define MMC_NEW_CLUSTER FALSE
////// MMC prototypes
#separate
int init_MMC(int max_tries);
#separate
int open_file(int fnbr,char *fname,int16 rec_length);
#separate
int file_read(int8 fnbr,char *buff);
#separate
int file_write(int8 fnbr,int *buff);
#separate
int file_set(int fnbr,int32 offset);
#separate
int file_new_cluster(int8 fnbr,int8 mode);  /// mode 1=fat1 2=fat2
int32 atoint32 (char *s );
signed int strncmp(char *s1, char *s2, int n);
///////////////////// MMC GLOBALS  /////////////////////////////
int16 cluster_size_bytes;       // bytes in a cluster
//int16 dir_cluster_chain_ptr;    // link to the first cluster in the dir
int32 fat1_address;             // physical address of fat1 cluster table assigned by INIT_MMC
int32 fat2_address;             // physical address of fat2 cluster table assigned by INIT_MMC
int32 root_dir_address;         // physical address of volume,file,folder tiles assigned by INIT_MMC
int32 data_area_address;        // physical address of data area assigned by INIT_MMC
int32 winhex_adj;                // Win hex hides the bytes in the reserved sectors
                                // this means Fat1 is address 512
                                // so adj is fat1-512
int32 block_size;               // current MMC block size
int MMC_init=FALSE;
int MMC_dir_protected=TRUE;
////////// open file specific globals ///////////////////////
struct
  char name[MMC_FILE_NAME_SIZE+1];  // fopen file name
  int32 dir_addr_ptr;               // physical address of this files tile info
  int16 root_cluster_ptr;           // location of first cluster in FAT
  int16 this_cluster_ptr;           // location of current cluster in FAT
  int16 next_cluster_ptr;          // location of the next cluster for a file or sub dir in FAT
  int32 addr_ptr;                   // physical address in the file the current
                                    // cluster points to
                                    // address=(this_chain_ptr-2)*cluster_size_bytes+data_area_address
                                    // cluster_addr(THIS_CLUSTER) assigns it
                                    // cluster_addr(NEXT_CLUSTER) moves to the data the next
  int32 size;                       // size of open file in bytes
  int32 cluster_offset;             // offset within the file representing the start of the current cluster
                                    //     (0 is start  and ends with the cluster contianing eof )
                                    // auto increased by cluster_size_bytes each time a new cluster is entered
  int32 offset;                     // current offset into the open file ( 0 is start size(file size) is end)
                                    // auto increased by rec size each time a rec is read
                                    // addr_prt+offset-cluster_offset is physical address of
                                    // the current position within the file
                                    // the physical positions are not always contiguous since the
                                    // clusters of the file  are not always adjacent to each other
  int16 rec_size;                   // fopen record_size
 // char buff[MMC_BUFF_SIZE+1];       // used for open and for read write
                                    // init MMC uses file 0 buff to fetch the globals
  } file[MAX_FILES];
#separate
int mmc_cmd(int8 cmd,int32 address,int8 tries,int8 valid,int8 invalid)
int i,r1;
for( i=0;i<16;i++) SPI_READ(0xFF);// digest prior operation
// commands
// 7 6 5 4 3 2 1 0
// 0 1 b b b b b b    bbbbbb=cmd
// 16=0x50 set blocklength
// 17=0x51 read block
// 24=0x58 write block
#if MMC_CMD_TRACE
printf("\n\r cmd=%2X \n\r",cmd);
SPI_READ(cmd);
SPI_READ(MAKE8(address,3));
SPI_READ(MAKE8(address,2));
SPI_READ(MAKE8(address,1));
SPI_READ(MAKE8(address,0));
SPI_READ(0x95);
// card comes up in MMC mode and requires a valid MMC cmd to switch to SPI mode
// valid crc for MMC 0x40 cmd only
// spi mode doesn't require the CRC to be correct just there
for(i=0;i< tries;i++) {
                  r1=SPI_READ(0xFF);
                  #if MMC_CMD_TRACE
                  printf(" %2X",r1);
                  if (r1==valid)  break;
                  if (r1==invalid)  break;
return(r1);
#separate
int set_BLOCKLEN( int32 size)
int r1;
r1=mmc_cmd(0x50,size,16,0x00,0x40); /// cmd.data,tries,valid code,invalid code
if (r1==0x00) goto done ;
if (r1==0x40) goto invalid;
return(false);
invalid:
#IF MMC_SET_BLOCK_LEN_TRACE
printf("\n\r para err\n\r");
#ENDIF
return(false);
done:
block_size=size; //// assign global block size
//printf("\n\r blk size=%lu",block_size);
return(true);
#separate
int read_BLOCK( int32 address, char *buff)
//// low level read ..requires block len to be called first to set global blocksize
int r1;
long i,iw; /// allows large gt 255 buff size addressing
//int data[128];
r1=mmc_cmd(0x51,address,16,0x00,0x40);
if (r1==0x00) goto get_token ; // we can read data payload
#IF MMC_READ_BLOCK_TRACE
printf("\n\r read block err 1 address=%lu \n\r",address);
#ENDIF
return(false);
invalid:
printf("\n\r read block err 2 adress=%lu \n\r",address);
#ENDIF
return(false);
get_token:
for(iw=0;iw<1024;iw++){
               r1=SPI_READ(0xFF);
               //data[iw]=r1;
              if (r1==0xFE) goto read_data; // read token $FE
printf("\n\r read block err 3 address=%lu \n\r",address);
#ENDIF
return(false);
read_data:
printf("\n\r read block tries for FE =%lu \n\r",iw);
#ENDIF
for (i=0;i<block_size;i++) buff[i]=SPI_READ(0xFF);
SPI_READ(0xFF); // read crc
SPI_READ(0xFF);
return(true);
///////////////////////////////// INIT MMC ///////////////////////
#separate
int32 start_lsec=0;
int16 sec_resv,sec_for_FAT,bytes_per_sector,root_dir_entries,
      sec_for_data,count_of_clusters,root_dir_sectors,total_sectors;
int i,tries,sec_per_cluster,c;
char buff[32];
tries=0;
cmd0:
///////////////////// place null treminators in globals fname and buff
for(i=0;i<MAX_FILES;i++)
   file[i].name[0]=0;
   file[i].rec_size=32; //// default rec_size = 32 byte tile size of FAT16
//buff[MMC_BUFF_SIZE]=0;
//frec_size=32; //// default rec_size = 32 byte tile size of FAT16
output_high(_CS);   /// reset chip hardware !!! required
delay_ms(20);
for(i=0;i<20;i++) SPI_READ(0xFF); // min 80 clocks to get MMC ready
output_low(_CS);   ///                      !!! required
delay_ms(20);
 #if MMC_INIT_TRACE
printf("cmd0");
 #ENDIF
c=mmc_cmd(0x40,0x00000000,128,0x01,0x99);
    if (c==0x01) goto exit_cmd1;
// note: i must cycle at least 8 times (16 is safe )
if (tries++<max_tries) goto cmd0;  /// restart
return (10);
exit_cmd1:
// CPDMOD - This SOMETIMES seems to be necessary
//    output_high(_CS);
//    SPI_READ(0xFF); // min 8 clocks to get MMC ready
//    output_low(_CS);
//CPDMOD End
tries=0;
cmd1:
/// now try  to switch to idle mode
/// Note: cmd1(idle) is the only command allowed after a cmd0(reset)
c=mmc_cmd(0x41,0x00000000,128,0x00,0x99);
              if (c==0x00) { goto ready;}
if( tries++<max_tries) { printf("cmd1"); goto cmd1;}
else return(11);
ready:
//for( i=0;i<32;i++) SPI_READ(0xFF);// digest operation
/// MMC is inialized and in idle state ready for commands
//// we need to first access the master boot sector physical address=0
if(set_BLOCKLEN((int32)32)==false) return(12); /// sets global block_size to 32
if (read_block(0x00000000,buff)==false) return (99); /// read the first few bytes
#if MMC_INIT_TRACE
printf("\n\r sector0=");
for(i=0;i<32;i++)printf("%2X ",buff[i]);
#ENDIF
if (buff[0]==0xEB || buff[0]==0xE9)
    /// sector 0 is the boot sector
    #if MMC_INIT_TRACE
    printf("\n\r boot sector= 0");
    #ENDIF
   //// partition
   /// access the master boot sector physical address 0 at offset 1BE
   if (read_BLOCK(0x000001BE,buff)==false) return(13);
   #if MMC_INIT_TRACE
   #ENDIF
   // start_lsec is address of the partion boot sector
   start_lsec=make32(buff[11],buff[10],buff[9],buff[8]);
   #if MMC_INIT_TRACE
   printf("\n\r boot sector= %lu",start_lsec);
   #ENDIF
   if (read_BLOCK(start_lsec*512,buff)==false) return(14);
bytes_per_sector=make16(buff[12],buff[11]);
if(bytes_per_sector!=512) return(15);
sec_per_cluster=buff[13];
cluster_size_bytes=(int16)sec_per_cluster*bytes_per_sector;
sec_resv=make16(buff[15],buff[14]);
root_dir_entries=make16(buff[18],buff[17]);// number of 32 byte tiles
total_sectors=make16(buff[20],buff[19]);
sec_for_FAT=make16(buff[23],buff[22]);
//branch to file directory
fat1_address=(start_lsec+sec_resv)*bytes_per_sector;
fat2_address=fat1_address+bytes_per_sector*sec_for_FAT;
root_dir_address=(sec_for_FAT*2+start_lsec+sec_resv)*bytes_per_sector;
data_area_address=root_dir_address+root_dir_entries*32;
///// check for FAT16
root_dir_sectors=root_dir_entries>>4;
sec_for_data=total_sectors - sec_resv -sec_for_fat*2 -root_dir_sectors;
count_of_clusters=sec_for_data/sec_per_cluster;
if (count_of_clusters <4085 || count_of_clusters>65525) return(17);
winhex_adj=fat1_address-bytes_per_sector;
return(0);
#separate
int get_CID(char s)
{int i,r1;
r1=mmc_cmd(0x4A,0x00000000,16,0x00,0x99);
return(false);
get_token:
for(i=0;i<16;i++)if (SPI_READ(0xFF)==0xFE) goto read_CID; // read token $FE
return(false);
read_CID:
for (i=0;i<18;i++) s[i]=SPI_READ(0xFF);
return(true);
#separate
int get_CSD(char s)
{int i,r1;
r1=mmc_cmd(0x49,0x00000000,16,0x00,0x99);
return(false);
get_token:
for(i=0;i<16;i++)if (SPI_READ(0xFF)==0xFE) goto read_CSD; // read token $FE
return(false);
read_CSD:
return(true);
#separate
int write_BLOCK( int32 address,char *buff,int16 size)
/// low level write ....MMC restriction is that exactly 512 bytes must be written
/// so a 512 byte section is read in starting at address the first (size) bytes
/// are over written with the new data and the updated 512 bytes written back
/// the starting address of the block that contains the requeseted address
/// the data may span a block if so it is split and two writes are done
/// so as to maitain MMC 512 write boundary restrictions
int r1,a,b,c,d;
int16 i,blk_offset,bytes_posted;
char tmp_buff[512];
int32 block_address;
#if MMC_WRITE_BLOCK_TRACE
printf("addr=%lu",address);
a=make8(address,3);
b=make8(address,2);
c=make8(address,1);
c=c & 0b11111110;
d=0;
block_address=make32(a,b,c,d);  //// address int divided by 512
printf("wb>> size=%lu payload=",size);
for(i=0;i<size;i++)printf("%c",buff[i]);
/// first set up the block size to 512
if(set_BLOCKLEN((int32)512)==false) return(false);  // sets global block_size
if(block_size!=512) return(false);
bytes_posted=0; /// no data updated yet
next_block:  /// loop back here for second block
printf("\n\r blk addr=%lu \n\r",block_address);
if((block_address < data_area_address) && MMC_dir_protected) return(false);
MMC_dir_protected=true;
printf("read blk");
/// first read in the existing block
 if(read_block(block_address,tmp_buff)==false) return(false) ;
 /// now update the block with new data
blk_offset=(address - block_address); /// offset within the block
printf("blk_offset=%lu size=%lu",blk_offset,size);
if( blk_offset + size > 512 )
 // data spans the block so write to end of block first
 //// original data
 printf("\n\r spans wb=");
 for(i=blk_offset;i<512;i++)printf("%c",tmp_buff[i]);
 for (i=blk_offset;i < 512;i++)tmp_buff[i]=buff[i-blk_offset];
  /// updated data
  printf("\n\r spans wb*=");
 bytes_posted=512-blk_offset; /// wrote from offset to end of block
  printf("\n\r posted=%lu",bytes_posted);
 //original or remaining spanned block data fits in next block or original block
 printf(" blk offset=%lu",blk_offset);
 /// original data
 printf("\n\r wb=");
 for(i=blk_offset;i<blk_offset+size;i++)printf("%c",tmp_buff[i]);
 for (i=blk_offset;i<blk_offset+ size;i++)tmp_buff[i]=buff[bytes_posted+i-blk_offset];
 /// updated data
 printf("\n\r wb*=");
 bytes_posted=size;
/////////// write out the block
printf("wb>> writing block %lu",block_address);
r1=mmc_cmd(0x58,block_address,16,0x00,0x40);
if (r1==0x00) goto send_token ; // we can send data payload
return(false);
invalid:
printf("\n\r write block err %2X\n\r",r1);
return(false);
send_token:
SPI_READ(0xFE);
for (i=0;i < 512;i++) {
                                  SPI_READ(tmp_buff[i]);  /// send payload
SPI_READ(0xFF); // send dummy chcksum
SPI_READ(0xFF);
r1=SPI_READ(0xFF);
for( i=0;i<0x0fff;i++) {
                        r1=SPI_READ(0xFF);// digest prior operation
                        if (r1!=0x00) break;
if(size > bytes_posted)
  /// data spanned block so we need to upadte next block as well
 size=size-bytes_posted;
 block_address=block_address+512;/// advance a block
 address=address+bytes_posted; /// move address ptr forward
 goto next_block;
return(true);
#separate
void dump_block()
int in_buff[12],c,i,j;
int32 read_address;
for(i=0;i<12;i++)in_buff[i]=0;
printf("\n\r Input Start address:");
j=0;
do {
   c=getc();
   in_buff[j++]=c;
   putc(c);
   }while(c!=13);
in_buff[j-1]=0;
read_address=atoint32(in_buff);
if (read_BLOCK(read_address,buff)==true){
                     printf(" BLOCK\n\r");
                     for(j=0;j<MMC_BUFF_SIZE;j=j+8)
                         printf("%4LX ",read_address+j);
                         for(i=0;i<8;i++)printf(" %2X",buff[i+j]);
                         printf("\n\r");
else printf("\n\r read_BLOCK failed");
#separate
int32 cluster_addr(int fnbr,int mode)
int32 address;
char buff[2]; //// buffer for 2 byte ptrs
///// returns the physical address in the data area of the data pointed to by either the
///// root cluster or the next cluster in the chain
///// if ROOT_CLUSTER is called then this routine returns the address of the first cluster
///// and assigns this_cluster_ptr and next_cluster_ptr
///// if NEXT_CLUSTER is called then this routine returns the address of the next cluster
///// using the existing next_cluster ptr number
///// and moves the existing next_cluster ptr number into this_cluster
///// and assigns the new next cluster ptr number (FFFF) if at the end of chain
///// if NEXT_CLUSTER is called and the next_cluster_ptr number is FFFF
///// an address of FFFFFFFF is returned
///// uses the globals cluster_size_bytes,data_area_address
////  file struct has the base=root cluster ptr, current=this cluster ptr ,next =cluster chain ptr
////  !!!! a call with NEXT_cluster must have a valid next_cluster_ptr value
////  !!!! a call to THIS CLUSTER must have a valid this_cluster_ptr
////  !!!! Fopen logic considers the cluster prt in the directory tile
////  to be a next=next_cluster_ptr so NEXT_CLUSTER is used to calc the physical address
////  of the first root cluster this also assigns the current=this_cluster_ptr
///   and fetches the next cluster prt
#IF MMC_CLUSTER_TRACE // if true prints to serial port
    printf("\n\r cluster addr>> next_cluster_ptr= %lu this_cluster=%lu \r\n",file[fnbr].next_cluster_ptr,file[fnbr].this_cluster_ptr);
#ENDIF
if (mode==NEXT_CLUSTER)
    ///access the next cluster in the chain
    /// requires a valid this_cluster_ptr number and a valid next_cluster_ptr number
  if(file[fnbr].next_cluster_ptr==0xFFFF)
    printf("last cluster");
   #ENDIF
    address=0XFFFFFFFF;
    if(set_BLOCKLEN((int32)2)==false) return(35); /// set up to read 2 bytes
    if(read_BLOCK(fat1_address+(file[fnbr].next_cluster_ptr)*2,buff)==false) return(33);
    file[fnbr].this_cluster_ptr=file[fnbr].next_cluster_ptr; // update current with prev next in chain
    file[fnbr].next_cluster_ptr=make16(buff[1],buff[0]); /// update next in chain
    address=((int32)file[fnbr].this_cluster_ptr-(int32)2)*(int32)cluster_size_bytes+
              data_area_address;
if (mode==ROOT_CLUSTER)
    //// root_cluster_ptr was assigned from the file tile in fopen
    file[fnbr].this_cluster_ptr=file[fnbr].root_cluster_ptr;
    if(read_BLOCK(fat1_address+(file[fnbr].this_cluster_ptr)*2,buff)==false) return(33);
              data_area_address;
// printf("clust addr call fnbr=%u blk_size=%lu",fnbr,file[fnbr].rec_size);
 if(set_BLOCKLEN(file[fnbr].rec_size)==false) return(37); /// reset to original rec_size
    printf("\n\r cluster addr>> next_cluster_ptr*= %lu this_cluster*=%lu \r\n",file[fnbr].next_cluster_ptr,file[fnbr].this_cluster_ptr);
#ENDIF return(address);
/////////////////////////   OPEN FILE  ///////////////////////////////////////////
#separate
int32 dir_addr_ptr;
int16 bytes_read;
int i,ptr1,ptr2,lnf_tiles;
char file_name[12];
int attribute,directory,archive;
char tmp;
char buff[32];  //// buffer for 32 byte tiles
int level;  /// level in the directory structure 0 is top
 ///////  directory is searched and if file is found
 //////   init_MMC(tries) must be called first
 //////   uses globals root_dir_address
 //start by searching the root directory for folder or file
 /// assign an inital next_cluster_ptr in the root directory
 file[fnbr].next_cluster_ptr=0;
 file[fnbr].this_cluster_ptr=0;
dir_addr_ptr=root_dir_address;
file_name[11]=0;
level=0;
ptr1=0;
ptr2=0;
bytes_read=0; //// byte read so far in this cluster
read_directory:
/// extract the directory levels(folders)
 while ((fname[ptr2]!='/') && (fname[ptr2]!='\\') && (fname[ptr2]!='\0') && (fname[ptr2]!='.') )
        // a dos directory (folder) name can not exceed 8 chars
        if ((ptr2-ptr1)>7) return (20);
        ptr2++;
#IF MMC_OPEN_TRACE
        printf("\n\r fopen ptr1=%u ptr2=%u ",ptr1,ptr2);
#ENDIF
if (ptr2==0){ ptr2=1;ptr1=1;goto read_directory;}    /// skip a leading '/' or '\'
if ((ptr2-ptr1)==0) return (21);
// ptr1 is the chars processed so far
// ptr2 is the position of '/' or '\' or '.' or '\0'
// prepare the file or directory  name fomat is cccccccceee
// c is a valid letter or blank eee is extension or blank
// a directory name is 'cccccccc   ' a file 'cccccccceee' always 11 chars
 for(i=0;i<11;i++)file_name[i]=32;//blank
  file_name[11]=0;
   i=0;
   while(ptr1<ptr2)
          // extract the name
          tmp=fname[ptr1];
          tmp=TOUPPER(tmp);
          file_name[i]=tmp;
          ptr1++;i++;
   if(fname[ptr2]=='.')
          // extract the extension
          i=8;
         while((fname[ptr1]!='\0') && (i<12))
               ptr1++;
               tmp=fname[ptr1];
               file_name[i]=TOUPPER(tmp);
               i++;
ptr1++;
ptr2=ptr1; // advance over the '\' or '/' so next pass starts correctly
if (block_size!=(int32)32)
    if(set_BLOCKLEN((int32)32)==false) return(17); /// tiles are 32 bytes
if (read_BLOCK(dir_addr_ptr,buff)==false) return(10);
// decode the FAT16 entries
// a tile is 32 bytes
// std dos files take one tile
// a long file name has multiple tiles
// starting with the last down to the first and
// then a std dos tile is found
// byte 11 is 0x0f for LNF tiles and 0x00 for std
// we skip the LNF and goto STD tile
tile_decode:
lnf_tiles=0;
if (buff[0]==0xE5) goto next_tile; ///0xE5 is the deleted file flag
if (buff[0]==0x00)
                  printf("\n\r file err [%s] not found \n\r",file_name);
                   return(11);     /// file not found
if (buff[11]==0x0F)
                  /// get number of LNF tiles
                  lnf_tiles=buff[0] & 0b00111111;
                  bytes_read=bytes_read+lnf_tiles*32;
                  if(bytes_read>cluster_size_bytes)
                           // compute next cluster address next_cluster_ptr must be valid
                           // assigns this_cluster_ptr
                           dir_addr_ptr=cluster_addr(fnbr,NEXT_CLUSTER);
                           if (dir_addr_ptr==0xFFFFFF) return (22);
                           bytes_read=bytes_read-cluster_size_bytes;
                           dir_addr_ptr=dir_addr_ptr+bytes_read;
                          dir_addr_ptr=dir_addr_ptr+lnf_tiles*32;
                  //advance over the lnf tiles
                  /// test to see if we need next cluster in chain
                  if (read_BLOCK(dir_addr_ptr,buff)==false) return(31);
                  /// !!! may read into next sector
/// check out the standard DOS tile
#IF MMC_OPEN_TRACE
printf("\n\r fname[%s] level=%u \n\r",file_name,level);
for (j=0;j<11;j++)printf("%c",buff[j]);
#ENDIF
if(strncmp(buff,file_name, 11)==0) ///8.3 file name ex "FILE    EXT"
                                   ///                 "FOLDER     "
   // we have a  file type or a sub directory(folder)
   // so we get the starting cluster number
   attribute=buff[11];
   file[fnbr].root_cluster_ptr=make16(buff[27],buff[26]);/// assign initial  cluster ptr
                                               /// if it is not a directory
                                               /// it points to the begining of the file
                                               /// cluster chain
   if ((attribute & 0b00010000)>0)directory=true;
   else directory=false;
   if ((attribute & 0b00100000)>0 || attribute==0)
                  archive=true;   //// we have our file
                  file[fnbr].size=make32(buff[31],buff[30],buff[29],buff[28]);
                  file[fnbr].dir_addr_ptr=dir_addr_ptr; ///save address of this files tile
                  /// assign global value
   else archive=false;
     goto match_found;
//   goto fill_table; // we have a match
next_tile:
bytes_read=bytes_read+32;
if(bytes_read > cluster_size_bytes)
                            /// requires a valid next=next_cluster_ptr
                           // compute next cluster address and assign this cluster
                           if (dir_addr_ptr==0xFFFFFF) return (23);
                          dir_addr_ptr=dir_addr_ptr+32;
if (read_BLOCK(dir_addr_ptr,buff)==false) return(32);
goto tile_decode;
match_found:
///// if we have a sub directory we need to cycle down a level
if (directory==true) {
                      // compute the sub directory address
                     // compute this cluster address this_cluster_ptr must be valid
              dir_addr_ptr=cluster_addr(fnbr,ROOT_CLUSTER); /// set physical addr of starting cluster
              #IF MMC_OPEN_TRACE
              printf("\n\r next_cluster_ptr=%lu \n\r ",file[fnbr].next_cluster_ptr);
              #ENDIF
             //printf("\n\r dir_addr_ptr=%lu",dir_addr_ptr);
             // dir_addr_ptr=((int32)cluster_table[0]-(int32)2)*(int32)cluster_size_bytes+
             // data_area_address;
                      level++;
// note record length must divide into 512 to align properly
if (rec_length<2) return(12);
/// get the initial file_addr_ptr
 file[fnbr].addr_ptr=cluster_addr(fnbr,ROOT_CLUSTER);
 file[fnbr].offset=0; //init  bytes read from beginning of open file
 file[fnbr].cluster_offset=0; //init bytes read to beginning of the current cluster
 file[fnbr].rec_size=(int32)rec_length; /// assign file record size
#IF MMC_OPEN_TRACE
printf("root_cluster=%lu \n\r",file[fnbr].root_cluster_ptr);
 #ENDIF
 //printf("\n\r fopen %u rec size=%lu",fnbr,file[fnbr].rec_size);
 if(set_BLOCKLEN(file[fnbr].rec_size)==false) return(13);
return(0);
////////////////////////////// FILE READ   ///////////////////////////////////////
#separate
int32 address;
int32 nxt_cluster;
//// MMC allows a read to start and stop at any address but this file system
//// imposes a record size restriction the record size must divide into the
///  512 block  to allow writing of the records
/// rec_size must align with cluster boundary 2048 ...must be a divisor of 2048
/// find the cluster containing the offset
/// buff must be at least the size of the recordsize requested in the File open
//printf("foffset=%lu coffset=%lu ",file[fnbr].offset,file[fnbr].cluster_offset);////$$$$
if ( file[fnbr].offset>=file[fnbr].size) return(10); /// already beyond eof
if ( file[fnbr].offset + (int32) file[fnbr].rec_size > file[fnbr].cluster_offset + (int32) cluster_size_bytes)
 #IF MMC_READ_TRACE
   printf("adv to next cluster");
 #ENDIF
  /// need to advance to the next cluster
  nxt_cluster=cluster_addr(fnbr,NEXT_CLUSTER);
  if ( nxt_cluster!=0XFFFFFFFF) file[fnbr].addr_ptr=nxt_cluster;
  else return(11); /// last cluster in file reached
  file[fnbr].cluster_offset=file[fnbr].cluster_offset+(int32)cluster_size_bytes; //foffset is the byte offset within the file
                               //that file_addr_ptr points to
address=file[fnbr].addr_ptr+file[fnbr].offset-file[fnbr].cluster_offset;
#IF MMC_READ_TRACE
              printf("\n\r offset=%lu",offset);
              printf("\n\r data_area_address=%lu",data_area_address);
              printf("\n\r cluster_size_bytes=%lu",cluster_size_bytes);
              printf("\n\r file_addr_ptr=%lu",file_addr_ptr);
#ENDIF
if (read_BLOCK(address,buff)==false)return(12); /// read block into buff
if ( file[fnbr].offset+file[fnbr].rec_size< file[fnbr].size )
           file[fnbr].offset=file[fnbr].offset+file[fnbr].rec_size;
    {        /// end of file
    #IF MMC_READ_TRACE
            printf("eof size=%lu",file[fnbr].size);
    #ENDIF
            buff[ file[fnbr].size-file[fnbr].offset]=0; /// short record
            file[fnbr].offset=file[fnbr].size;
            return(255); //eof
return(0);
//////////////////////////////  WRITE FILE   /////////////////////////////////////
#separate
//// buff size must be at least  the recordsize requested in File open
//// the record is updated only chars beyond rec_size are ignored
/// set up for write
/// A MMC write is restricted it must be for a block and allign on block boundaries
/// blocklen must be exactly 512 and start address must be the begining of a
/// sector
/// the buff could potentially span a sector and or span a block(512) boundary
/// ex there could be 1byte left in a block and 1 byte lect in a sector
//  if the block is the last block in the sector
/// worst case we could write to two blocks and need a new sector
int32 address,nxt_cluster;
int16 in_cluster_size,out_cluster_size;
int8 appending_flag;
appending_flag=0;
if (file[fnbr].offset + file[fnbr].rec_size>=file[fnbr].size) appending_flag=1;
if ( file[fnbr].offset+file[fnbr].rec_size>=file[fnbr].cluster_offset + cluster_size_bytes)
  #IF MMC_WRITE_TRACE
   printf("spanning cluster \n\r");
  #ENDIF
  /// spans the current cluster so we split the write
  in_cluster_size=file[fnbr].cluster_offset+cluster_size_bytes-file[fnbr].offset;
                /// bytes from start of file to end of this cluste- bytes into the file
  out_cluster_size=file[fnbr].rec_size - in_cluster_size;
  #IF MMC_WRITE_TRACE
   printf("write>> spanning cluster inside=%lu outside=%lu \n\r",in_cluster_size,out_cluster_size);
  #ENDIF
  address=file[fnbr].addr_ptr+file[fnbr].offset - file[fnbr].cluster_offset;
           // physical address=
          // physical address of the cluster +offset from begining of file
          // - offset from the begining of file for the byte at the begining of the cluster
#IF MMC_WRITE_TRACE
  printf("write file>>cluster=%lu in clstr addr=%lu",file[fnbr].this_cluster_ptr,address);
#ENDIF
  //// address=physical offset of this cluster +bytes into this cluster
   if(write_BLOCK(address,buff,in_cluster_size)==false)return(81); //// write first chunk
  /// allocate the next cluster
  nxt_cluster=cluster_addr(fnbr,NEXT_CLUSTER); ///physical address of file data that the
                                              /// specific cluster indexes
  #IF MMC_WRITE_TRACE
   printf("nxt_cluster=%lu",nxt_cluster);
  #ENDIF
   if ( nxt_cluster==0xFFFFFFFF)
       #IF MMC_WRITE_TRACE
        printf("updating FAT");
       #ENDIF
       //// FAT2 is an identical copy of FAT1
       file_new_cluster(fnbr,1); /// a new cluster is allocated in FAT1
       file_new_cluster(fnbr,2); /// a new cluster is allocated in FAT2
       #IF MMC_WRITE_TRACE
        printf("\n\r write>>nxt_cluster addr=%lu this clstr=%lu next=%lu",nxt_cluster,file[fnbr].this_cluster_ptr,file[fnbr].next_cluster_ptr);                                                 /// specific cluster indexes
       #ENDIF
   file[fnbr].addr_ptr =nxt_cluster;
   file[fnbr].cluster_offset=file[fnbr].cluster_offset + cluster_size_bytes; //foffset is the byte offset within the file
   address=file[fnbr].addr_ptr + file[fnbr].offset - file[fnbr].cluster_offset + in_cluster_size;
   #IF MMC_WRITE_TRACE
    printf("out addr=%lu,out size=%lu",address,out_cluster_size);
   #ENDIF
   if(write_BLOCK(address,&buff[in_cluster_size],out_cluster_size)==false)return(82); /// write block pads with 0x00 to end of sector
  }// end of spanned cluster
   /// within the current cluster
  if(write_BLOCK(address,buff,file[fnbr].rec_size)==false)return(84); /// write block pads with 0x00 to end of sector
if(appending_flag==1) {
               /// if appended we need to up date the file size
                file[fnbr].size=file[fnbr].size + file[fnbr].rec_size; /// add one record
                address=file[fnbr].dir_addr_ptr+28; /// file size is offset 28 in tiles
                #IF MMC_WRITE_TRACE
                printf("new file size=%lu",file[fnbr].size);
                #ENDIF
                buff[0]=make8(file[fnbr].size,0);
                buff[1]=make8(file[fnbr].size,1);
                buff[2]=make8(file[fnbr].size,2);
                buff[3]=make8(file[fnbr].size,3);
                MMC_dir_protected=false;
                if(write_BLOCK(address,buff,4)==false)return(85);
if(set_BLOCKLEN(file[fnbr].rec_size)==false) return(86); /// reset to original rec_size
return(0);
#separate
/// file open sets the offset to the begining offset=0
/// this sets the offset within the file ...offset of 0 is a reset
if(offset>=file[fnbr].size) return(71);
file[fnbr].offset=offset; //// overwrite the existing offset
file[fnbr].next_cluster_ptr=file[fnbr].root_cluster_ptr; /// set current ptr to beginning
// move the cluster to the one containing the offset
while ( offset>cluster_size_bytes )
    file[fnbr].addr_ptr=cluster_addr(fnbr,NEXT_CLUSTER);
    file[fnbr].cluster_offset+=cluster_size_bytes; //foffset is the byte offset within the file
    if (offset-cluster_size_bytes >0) offset= offset - cluster_size_bytes;
return(0);
#separate
/////////////   this does identical  writes to either the FAT1 and FAT2 sectors
int16 eof_cluster;
char buff[2],tmp_buff[2];
int32 address;
int32 fat_address;
int16 slot;
/// an unused cluster has the value 0x0000 as its next cluster ptr
/// a used cluster has either 0xFFFF meaning last in chain
/// or a valid cluster displacement in the FAT1 amd FAT2 area
/// to append a cluster the 0XFFFF needs to be replaced by the appended
/// cluster location and the appended locations data (next ptr) needs to be set to 0XFFFF
eof_cluster=file[fnbr].this_cluster_ptr;
#IF MMC_NEW_CLUSTER
printf("the cluster with eof (FFFF)=%lu \n\r",eof_cluster);
#ENDIF
slot=0;
if(set_BLOCKLEN((int32)2)==false)return(false);  // force blocklen to 2
/// use global address of FAT1 assigned by INIT
if (mode==2)fat_address=fat2_address;
else fat_address=fat1_address;
address=fat_address;
#IF MMC_NEW_CLUSTER
printf("mode=%u FAT addr=%lu \n\r",mode,address);
#ENDIF
do
if(read_block(address,buff)==false) return(false) ;
slot=slot+1;
address=address+2;
//printf(" slot  %lu =%2x %2x",slot,buff[0],buff[1]);
}while (buff[0]!=0 || buff[1]!=0);
address=address-2; // correct for over step
slot=slot-1;
#IF MMC_NEW_CLUSTER
printf("slot=%lu address=%lu",slot,address);
#ENDIF
/// found an unused cluster
tmp_buff[0]=0xFF;tmp_buff[1]=0xFF; /// stamp it as last
MMC_dir_protected=false; /// allow writes to the protected areas
if(write_block(address,tmp_buff,2)==false ) return(false);
/// update prev cluster with 0xFFFF in it
tmp_buff[1]=make8(slot,1);
tmp_buff[0]=make8(slot,0);
if (mode==1)
//// update the file info
file[fnbr].next_cluster_ptr=slot;
#IF MMC_NEW_CLUSTER
printf("cluster %lu was updated to point to %lu",file[fnbr].this_cluster_ptr,file[fnbr].next_cluster_ptr);
#ENDIF
/// compute physical address of the current cluster
 if(write_BLOCK(fat_address+(file[fnbr].this_cluster_ptr)*2,tmp_buff,2)==false) return(33);
if(set_BLOCKLEN((int32)file[fnbr].rec_size)==false)return(false);  // reset blocklen
return(true);
   for (; n > 0; s1++, s2++, n--)
      if (*s1 != *s2)
         return((*s1 <*s2) ? -1: 1);
      else if (*s1 == '\0') return(0);
   return(0);
      if (*s1 != *s2)
   return(0);
      if (*s1 != *s2)
   return(0);
end of driver file MMCDOS.c
below is an example
//#include <18F8720.h>
#include <18F452.h>
#DEVICE *=16 CCSICD=TRUE
/// add new open file handling
//// working May 13 2003 with 18F452
//// write append tested for no new cluster append
#fuses HS,NOWDT,NOPROTECT,NOPUT,NOLVP,NOBROWNOUT,NOWRT
#use delay(clock=20 000 000)
//#use rs232(baud=9600, bits=8, parity = N, xmit=PIN_C6, rcv=PIN_C7)
#use rs232(DEBUGGER)
//#USE FAST_IO(A)
//#USE FAST_IO(B)
//#USE FAST_IO(C)
//#USE FAST_IO(D)
//#USE FAST_IO(E)
/// test of SPI interface at 40 mz prior to merging into web server
/// hardware SDI is C4 SDO is C5 SCK is C3
#DEFINE _CS PIN_C2
#define PIC_MODE PIN_A0 /// NIC or DRAM
#include<mmcdos.c>
main()
int r1,i,j,error,error0,error1;
int16 rec_no;
int16 index,rec_size;
int32 offset;
char fname[32],buff0[MMC_BUFF_SIZE+1],buff1[MMC_BUFF_SIZE+1];
char c;
//int32 read_address,dir_address,dir_addr_ptr,start_lsec,
// file_addr_ptr,file_size,file_start_addr,total_bytes_read,fat1_address;
//int16 sec_resv,sec_for_FAT,start_cluster,this_cluster,next_cluster,cluster_size_bytes,
// total_clusters_read,cluster_bytes_read;
//int sec_per_cluster,lnf_tiles;
printf("\n\r start mmctest");
/// init SPI interface
setup_adc_ports(NO_ANALOGS);
/// MMC Setup
set_tris_c(0b10010011); //c7=rx I, c6=tx O, c5 SDO O,c4 SDI I
//c3 CLK O,c2 CS O,
output_high(_CS);
printf("\n\r Start SPI MMC\n\r");
// Note code below was needed before SPI_XMIT_LTO_H was available
// SETUP_SPI(SPI_MASTER | SPI_CLK_DIV_16 | SPI_L_TO_H );
// CKE=0;
// CKP=1;
// SMP=0;
SETUP_SPI(SPI_MASTER | SPI_CLK_DIV_16 | SPI_H_TO_L |SPI_XMIT_L_TO_H );
/// transmit on rising edge and sample receive on the rising edge
/// of the clock
/// idle clock is high
buff0[MMC_BUFF_SIZE]=0;
buff1[MMC_BUFF_SIZE]=0;
rec_no=0;
///////// init MMC ////////////////////////////////////////
error=init_MMC(10);
if (error>0) {
printf("\n\r Init failed error=%U\n\r",error);
goto mmc_exit;
printf("\n\r MMC initialized \n\r");
rec_size=MMC_BUFF_SIZE;
// note \ is a special char in CCS so we use \\ to get a single \ (0x5C)
//strcpy(fname,"MMCTEST\\PICFILES\\PIC.TXT");
/// same as "MMCTEST\PICFILES\PIC.TXT"
strcpy(fname,"WEB\\HOME.HTM");
error0=open_file(0,fname,rec_size);
if (error0>0) {
printf("\n\r fopen as 0 failed error=%U\n\r",error);
goto mmc_exit;
else printf("\n\r opened as 0 file %s with rec size %lu \n\r",fname,rec_size);
do {
error0=file_read(0,buff0);
if (error0>0 && error0<255 ) {
printf("\n\r fread 0 failed error=%U\n\r",error0);
printf("%s",buff0);
//printf("f0rec_no=%lu \n\r",rec_no);
rec_no++;
} while (error0==0);
mmc_exit:
printf("\n\r done winhex adj= %lu \n\r",winhex_adj);
while(true);
