Pavel Kolinko
Any idea if Microchip will support 3.3V on MCUs? |
Posted: Fri Nov 04, 2005 10:23 pm |
Microchip dsPic supports 3.3V.
However I was wondering if anyone knows
whether Microchip has plans to support 3.3V in MCUs.
I looked for 3.3V MCUs on Microchip website, but it doesn't seem like they have any.
Thanks in advance for your help.
Pavel |
newguy
Posted: Fri Nov 04, 2005 10:29 pm |
The LF processors are low voltage capable. Some are able to run as low as 2.0 V (I think). For example, the 18F452 runs at 4.2 - 5.0 V, while the 18LF452 will run down to something in the neighbourhood of 2 or 3 V. I'm too lazy to look up the exact specs - check microchip's website again. |
Pavel Kolinko
Thanks! |
Posted: Fri Nov 04, 2005 11:19 pm |
Thanks!
I found the LF parts that I need. |
MikeValencia
Posted: Sat Nov 05, 2005 6:25 am |
Pavel,
Just make sure that you have Brown-Out Reset DISABLED. Otherwise, you'll never get these things to run! I guess the feature is in there because these same 3.3V chips can still run at 5V. |
MGP
Posted: Sat Nov 05, 2005 12:29 pm |
You also may have problems with low voltage in-system programming since you can't do a bulk erase at Vdd less than 4.2V. You need to be able to do a bulk erase if you want to change fuse settings, since a bulk erase is the only way to erase the existing fuse settings. |
kender
Posted: Sat Nov 05, 2005 3:15 pm |
MikeValencia wrote: | Just make sure that you have Brown-Out Reset DISABLED. Otherwise, you'll never get these things to run! I guess the feature is in there because these same 3.3V chips can still run at 5V. |
Mike, does it mean that LF chios would need an external microcontroller superviser with a different brownout detect? I've never used LF myself, but I'm curious, because eventually I'll need to re-tool to 3.3V, becasue 5V programmable logic, in turn, is gradually becoming exticnt. |
Posted: Sun Nov 06, 2005 5:22 pm |
kender wrote: | MikeValencia wrote: | Just make sure that you have Brown-Out Reset DISABLED. Otherwise, you'll never get these things to run! I guess the feature is in there because these same 3.3V chips can still run at 5V. |
Mike, does it mean that LF chios would need an external microcontroller superviser with a different brownout detect? I've never used LF myself, but I'm curious, because eventually I'll need to re-tool to 3.3V, becasue 5V programmable logic, in turn, is gradually becoming exticnt. | It all depends on the PIC model you are using, some models only have a single fixed BOR voltage while other models have multiple preset voltages you can select from. For example the old PIC18LF458 has BOR voltages of 2.0V, 2.7V, 4.2V and 4.5V |
