treitmey
Darren Rook - newest compiler question |
Posted: Thu Jan 13, 2005 12:06 pm |
I was concerned when I recieved 2 notices of new comp. 3.216
I downloaded the fist one yesterday.
And one today.
pcwhupd.exe
the sizes don't match??
8,334,810
8,334,821
from a dos dir comand.
Is there a reson for this?
Is there and difference in the two?
rnielsen
Posted: Thu Jan 13, 2005 12:37 pm |
They made some changes to the newest one, hence the size difference.
Ronald |
Posted: Thu Jan 13, 2005 12:40 pm |
They've been doing this for years. I emailed them once and
told them it's not a good idea to do this, but it didn't have any effect. |
ckielstra
Posted: Thu Jan 13, 2005 12:57 pm |
Whaaaatttt???????
First when I read this I thought Treitmey made a mistake somewhere, but CCS is really making changes to the released version without version number changes????
This gives me a very bad feeling........  |
Hans Wedemeyer
Re: Darren Rook - newest compiler question |
Posted: Thu Jan 13, 2005 2:13 pm |
treitmey wrote: | I was concerned when I recieved 2 notices of new comp. 3.216
And one today.
pcwhupd.exe
8,334,810
8,334,821
Is there and difference in the two? |
Today's version 3.216 (8,334,821 bytes) has a fix in it for delay_ms(1000) that I reported as a bug yesterday.
I think they must have forgotten to update the version number... |
treitmey
Posted: Thu Jan 13, 2005 3:30 pm |
You HAVE to change the version number.
Its just good engineering.
If I put in my comments that this firmware run on compiler 3.19. I want
that version SET IN STONE. Golden. Not to be changed by anyone, or anything.
The number is just a number.
Change it for EVERY change! |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Thu Jan 13, 2005 4:16 pm |
There are a lot of things wrong with CCS' change log and version update policies... |
kypec
File version info |
Posted: Fri Jan 14, 2005 1:34 am |
I agree with everybody else here that it is VERY VERY BAD
practice to release newer/different files with the same version number.
Just a small note:
one can quickly inspect THE REAL FILE VERSION by right-clicking
install file pcwhupd.exe and choosing properties.
Under the version tab the older file reads File version: 3.216.11.16
whereas the new one has: 3.216.12.9
Good luck and strong nerves with future CCS releases wishes
kypec  |
Mark
Posted: Fri Jan 14, 2005 7:50 am |
Exactly how many times has CCS made the mistake of not changing the version number? This is the first that I know. It was probably a mistake and people do make them. Lighten up fellows. |
Posted: Fri Jan 14, 2005 12:14 pm |
I'm sorry Mark, but I have 8 cases on record that I know of,
starting with vs. 2.703, back in Feb. 2000.
I think it happens when the programmer discovers a mistake
soon after posting the new release. Then he reposts a
revised version the next day. As far as I can tell, versions
that have been sitting out there for weeks or months are
not changed. Every now and then, I re-download a version
and do a binary file compare on it, just to check on this, so
that's how I can tell. |
Mark
Posted: Fri Jan 14, 2005 12:25 pm |
Alright, then I will agree with the rest of you. Bad CCS, bad CCS.  |
A rock solid CCS version ! ? |
Posted: Fri Jan 14, 2005 10:54 pm |
kypec wrote: | I agree with everybody else here that it is VERY VERY BAD
Just a small note:
kypec  |
Shall we use this 4 digit format to refer the CCS version ?
say, PCWH 3.216.12.9 instead of just 3.216?
There will be no more confusion, no more, no more, not any more.
Cheers!  |
