		| Author | Message |
		| GDetienne
				| printf and last versions of pcw |
				|  Posted: Fri Dec 17, 2004 12:42 pm |   |
				| I have the last versions of PCW and have some problems. To determine where are the problems I write little programs for 16F876. And I found some differences.
 Here a part of my test program.
  	  | Code: |  	  | char cMin, csec;
 cMin = 12;
 csec= 54;
 printf(LCD_PutChar,"%02U  %02d", cMin, csec);
 The printf(   ) is in the while() and I increment cMin and csec each second. When the two variables come to 99, I reset to 1.
 This program, compiled with version 3.163, show me 12 54 on my LCD and each second the two values are incremented. It's ok.
 When I compile with versions 3.212 , 3.213 and 3.214 I see on my LCD 10  50. After 10 seconds I have 20 60  and so one. I never see  21  22  23 .... Only 20   30   40 ...
 If I change the printf to   printf(LCD_PutChar,"%02u:%02U", cMin, csec);
 I have the same printing.
 The last manual don't give a change in the parameters and the readme file don't give info. I see only this message on the CCS New version board :
  	  | Code: |  	  | 3.212  A %u and %d bug is fixed
 Have somebody an answer ? Where is my mistake ?
 Thanks and regard.
		| PCM programmer
				|  Posted: Fri Dec 17, 2004 5:48 pm |   |
				| You didn't provide a test program, so I made one. Instead of having the output go to an LCD, I just have it
 go to the terminal window on my PC.   It works OK with
 PCM vs. 3.214.   Here is the output:
  	  | Code: |  	  | 12   54 13   55
 14   56
 15   57
 16   58
 17   59
 18   60
 19   61
 20   62
 21   63
 22   64
 23   65
 24   66
 25   67
 26   68
 27   69
  	  | Code: |  	  | #include <16F877.h> #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 #use delay(clock = 4000000)
 char i;
 char cMin = 12;
 char cSec = 54;
 printf("%02U   %02d \n\r", cMin, cSec);
 cMin++;
 cSec++;
		| Mark
				|  Posted: Fri Dec 17, 2004 6:48 pm |   |
				| There seems to be a problem when using the lcd (lcd_putc).  In the below test program, the first line prints correctly while the 2nd line is like what the posted saw.
 #include "mylcd.c"
 char i;
 char cMin = 12;
 char cSec = 54;
 char buf[20];
 sprintf(buf,"\f%02U   %02d", cMin, cSec);
 i = 0;
 while (buf[i])
 lcd_putc(buf[i++]);
 printf(lcd_putc,"\n%02U   %02d", cMin, cSec);
 cMin++;
 cSec++;
 if (cMin == 99)
 cMin = 1;
 if (cSec == 99)
 cSec = 1;
		| GDetienne
				|  Posted: Sat Dec 18, 2004 3:04 am |   |
				| Many thanks for your answers. I agree the fact that I don't have try with a terminal on my PC.
 If my test program work fine on LCD compiled with my old version, with the 3 last versions it don't.
 Normaly I used %02d for this variable, %02U was just for test.
 Then the problem is in the LCD routine, but only with the 3 last versions. It's what Mark say.
 Now the best is to compare both version.
 Thanks and have a nice week end.
		| Mark
				|  Posted: Sat Dec 18, 2004 7:58 am |   |
				| To clear things up for anyone else reading this, the problem isn't per ce with the printf and its not with the lcd routine either but rather the 'glue' between them. |  |
		| GDetienne
				|  Posted: Sun Dec 19, 2004 7:26 am |   |
				| Mark, thanks for your advies about this problem.
 Here follow a little test program to show the problem and to discover "the glue".
 My program is :
  	  | Code: |  	  | /*  test lcd 876       pcwh 3.214*/
 #include <16F876.h>
 #device *=16
 #fuses HS,NOWDT,PUT,BROWNOUT,WRT,NOLVP
 #use delay (clock=16000000)
 #define CRYSTAL_FREQ    16000000
 #define LINE_1          0x00
 #define LINE_2          0x40
 #define CLEAR_DISP      0x01
 #define LCD_D0          PIN_A0   //DB4
 #define LCD_D1          PIN_A1   //DB5
 #define LCD_D2          PIN_A2   //DB6
 #define LCD_D3          PIN_A3   //DB7
 #define LCD_EN          PIN_B6   //enable
 #define LCD_RS          PIN_B7   // rs
 static char cSec;
 const char Title [] = "Test LCD";
 #separate void LCD_Init ( void );
 #separate void LCD_SetPosition ( unsigned int cX );
 #separate void LCD_PutChar ( unsigned int cX );
 #separate void LCD_PutCmd ( unsigned int cX );
 #separate void LCD_PulseEnable ( void );
 #separate void LCD_SetData ( unsigned int cX );
 Main ()
 set_tris_a ( 0x00 );      // tout output
 set_tris_b ( 0x00 );
 cSec = 12 ;
 LCD_Init ( ) ;
 LCD_PutCmd ( CLEAR_DISP );
 LCD_SetPosition ( LINE_1 );
 printf(LCD_PutChar,"%s", Title);
 LCD_SetPosition ( LINE_2 );
 printf(LCD_PutChar,"%02d",cSec);
 while (true)
 To reduce the code, I don't print the LCD routine.
 After compilation with version 3.163 and 3.214, I have compared the difference in the asm code.
 I give here only the differences. First the with PCW version 3.163
  	  | Code: |  	  | 0000:  MOVLW  00
 0001:  MOVWF  0A
 0002:  GOTO   101
 0003:  NOP
 ....................  /*  test lcd 876       pcwh 3.163*/
 .................... #include <16F876.h>
 ....................  //////// Standard Header file for the PIC16F876 device ////////////////
 .................... #device PIC16F876
 .................... #list
 .................... #device *=16
 .................... #fuses HS,NOWDT,PUT,BROWNOUT,WRT,NOLVP
 .................... #use delay (clock=16000000)
 0032:  MOVLW  24
 0033:  MOVWF  04
 0034:  BCF    03.7
 .................... static char cSec;
 0108:  BCF    03.5
 0109:  CLRF   20
 .................... const char Title [] = "Test LCD";
 0004:  BCF    0A.0
 0005:  BCF    0A.1
 0006:  BCF    0A.2
 0007:  ADDWF  02,F
 0008:  RETLW  54
 0009:  RETLW  65
 000A:  RETLW  73
 000B:  RETLW  74
 000C:  RETLW  20
 000D:  RETLW  4C
 000E:  RETLW  43
 000F:  RETLW  44
 0010:  RETLW  00
 ....................    printf(LCD_PutChar,"%s", Title);
 0117:  CLRF   21
 0118:  MOVF   21,W
 0119:  CALL   004
 011A:  IORLW  00
 011B:  BTFSC  03.2
 011C:  GOTO   121
 011D:  INCF   21,F
 011E:  MOVWF  23
 011F:  CALL   094
 0120:  GOTO   118
 ....................    printf(LCD_PutChar,"%02d",cSec);
 00BC:  MOVF   21,W
 00BD:  MOVWF  77
 00BE:  BTFSC  21.7
 00BF:  GOTO   0C4
 00C0:  BTFSS  22.2
 00C1:  GOTO   0CE
 00C2:  MOVLW  20
 00C3:  GOTO   0C9
 00C4:  COMF   77,F
 00C5:  INCF   77,F
 00C6:  MOVF   77,W
 00C7:  MOVWF  21
 00C8:  MOVLW  2D
 00C9:  MOVWF  78
 00CA:  MOVWF  23
 00CB:  CALL   094
 00CC:  BTFSS  22.2
 00CD:  BSF    22.3
 00CE:  MOVF   21,W
 00CF:  MOVWF  23
 00D0:  MOVLW  64
 00D1:  MOVWF  24
 00D2:  CALL   0A7
 00D3:  MOVF   77,W
 00D4:  MOVWF  21
 00D5:  MOVF   78,W
 00D6:  MOVLW  30
 00D7:  BTFSS  03.2
 00D8:  GOTO   0E0
 00D9:  BTFSC  22.0
 00DA:  GOTO   0E6
 00DB:  BTFSC  22.3
 00DC:  GOTO   0E6
 00DD:  BTFSC  22.4
 00DE:  MOVLW  20
 00DF:  GOTO   0E2
 00E0:  BCF    22.3
 00E1:  BCF    22.4
 00E2:  ADDWF  78,F
 00E3:  MOVF   78,W
 00E4:  MOVWF  23
 00E5:  CALL   094
 00E6:  MOVF   21,W
 00E7:  MOVWF  23
 00E8:  MOVLW  0A
 00E9:  MOVWF  24
 00EA:  CALL   0A7
 00EB:  MOVF   77,W
 00EC:  MOVWF  21
 00ED:  MOVF   78,W
 00EE:  MOVLW  30
 00EF:  BTFSS  03.2
 00F0:  GOTO   0F5
 00F1:  BTFSC  22.3
 00F2:  GOTO   0F9
 00F3:  BTFSC  22.4
 00F4:  MOVLW  20
 00F5:  ADDWF  78,F
 00F6:  MOVF   78,W
 00F7:  MOVWF  23
 00F8:  CALL   094
 00F9:  MOVLW  30
 00FA:  ADDWF  21,F
 00FB:  MOVF   21,W
 00FC:  MOVWF  23
 00FD:  CALL   094
 00FE:  BCF    0A.3
 00FF:  BCF    0A.4
 0100:  GOTO   129 (RETURN)
 0124:  MOVF   20,W
 0125:  MOVWF  21
 0126:  MOVLW  01
 0127:  MOVWF  22
 0128:  GOTO   0BC
 ....................    while (true)
 And for PCWH version 3.124
  	  | Code: |  	  | CCS PCM C Compiler, Version 3.214, 26317               19-déc.-04 12:44
 Filename: C:\CCS Tests\876 lcd 214.LST
 ROM used: 318 words (4%)
 Largest free fragment is 2048
 RAM used: 7 (2%) at main() level
 11 (3%) worst case
 Stack:    4 locations
 0000:  MOVLW  00
 0001:  MOVWF  0A
 0002:  GOTO   112
 0003:  NOP
 ....................  /*  test lcd 876       pcwh 3.214*/
 011B:  BCF    03.5
 011C:  CLRF   20
 .................... #separate void LCD_Init ( void );
 .................... #separate void LCD_SetPosition ( unsigned int cX );
 ....................    cSec = 12 ;
 0121:  MOVLW  0C
 0122:  BCF    03.5
 0123:  MOVWF  20
 012A:  CLRF   21
 012B:  MOVF   21,W
 012C:  CALL   004
 012D:  IORLW  00
 012E:  BTFSC  03.2
 012F:  GOTO   134
 0130:  INCF   21,F
 0131:  MOVWF  23
 0132:  CALL   094
 0133:  GOTO   12B
 0137:  MOVF   20,W
 0138:  MOVWF  21
 0139:  MOVLW  01
 013A:  MOVWF  22
 013B:  GOTO   0BC
 There are no difference in the LCD code.
 I see that :
 - the code for the const char Title [] = "Test LCD"; is missing
 - the code for printf(LCD_PutChar,"%02d",cSec);  is totally different
 - the code for printf(LCD_PutChar,"%s", Title); call to addresse 0004 not excist.
 What can I do ?
 I thing the only solution is send a mail to CCS....
 Thanks for all what you do in this forum. Have a nice day.
		| PCM programmer
				|  Posted: Sun Dec 19, 2004 12:20 pm |   |
				| To see the code which begins at 0004, edit the 16F876.H file and comment out the #nolist statement at the beginning of the file.
 Example:
 #device PIC16F876
 // #nolist     <- Comment out this line
 Then recompile your program and look at the .LST file.
 You will now see the code at 0004.
		| GDetienne
				|  Posted: Wed Dec 22, 2004 4:28 pm |   |
				| Answer received today from CCS :
  	  | Code: |  	  | This will be fixed in 3.215.
 Thanks.
		| bfmitch
				| A workaround |
				|  Posted: Mon Jan 03, 2005 9:11 am |   |
				| If you need to display int8 values, print them as int16 instead with the variable cast as an int16.
  	  | Code: |  	  | int8 var1;
 int8 var2;
 printf ( lcd_putc, "Variable1: %lu Lbs", (int16)var1 );
 printf ( lcd_putc, "Variable2: %lu", (int16)var2 );
 When they get the bug fixed, it'll be simple to change them to what they should be.
 The problem doesn't seem to exist when using serout in 3.214.  However, I seem to remember that in 3.212 it did exist in serout.  It drove me crazy for about 4 hours one day.  I finally decided it was an optimization issue and found a different way to do it.
 If they fixed it by modifying serout instead of printf, I hope they remember to take the change out of serout when printf gets fixed.
		| GDetienne
				| Thanks. |
				|  Posted: Mon Jan 03, 2005 5:49 pm |   |
				| Thanks for your suggestion. I'll try tomorrow. |  |
		| Guest
				| How about 3.215 ? |
				|  Posted: Wed Jan 05, 2005 8:35 am |   |
				| How about 3.215 ?  |  |
		| bfmitch
				| Just Updated Apparently |
				|  Posted: Wed Jan 05, 2005 8:42 am |   |
				| Two days ago the current version was 3.214.  I haven't received an email telling me that 3.215 was available.  Apparently it is now. |  |
		| GDetienne
				| Bug solved |
				|  Posted: Fri Jan 07, 2005 1:29 am |   |
				| This bug is solved in the last version (3.215).
 Thanks for you help.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
