HOW ICD2 WORK AS PROGRAMMER?
garyzheng
PostPosted: Tue Jan 04, 2005 11:07 am     Reply with quote
I am debugging the program for wireless chip(CC1000) +PIC16F876. Everything go right under the ICD2's debugger mode. BUt when I use ICD2 as the programmer and wanna burn the hex file into PIC16F876, it can not work alone. It should need the cable connection with ICD2 and use the "Release From Reset" command on the programmer list. Someone could explain that to me? Thank uSmile
rwyoung
PostPosted: Tue Jan 04, 2005 1:28 pm     Reply with quote
Did you remove the "DEBUG" entry from your #fuses statement?
Did you remove the #DEVICE ICD=TRUE line from your code?
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
