| RS232 problem with PIC18f452 |
Posted: Wed Dec 22, 2004 9:57 pm |
I am using a serial LCD to debug my PIC programs.
I have been using it fine with the PIC16f84a which has no hardware USART. Since the PIC and the serial LCD were directly wired, I used the INVERT option.
Now, I am trying to use a PIC18f452, which has a hardware USART. I don't want to use the software USART (by changing the xmit pin or using the option FORCE_SW).
The problem is that the LCD is getting garbage characters. How can I fix this problem???.
Here is some code snipet:
| Code: | #include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=2400,parity=N,invert,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
| Code: | #define COUNT_TO 31
byte count;
unsigned int num;
int printmsg;
void clearScreen(void);
#INT_RTCC
clock_isr() {
if(--count==0) {
num++;
count = COUNT_TO;
printmsg = 1;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
count = COUNT_TO;
num = 0;
printmsg = 1;
/* give plenty of time to the LCD to initialize */
set_rtcc(0);
setup_counters(RTCC_INTERNAL, RTCC_DIV_128);
enable_interrupts(INT_RTCC);
while(1) {
if (printmsg) {
clearScreen();
printf("Count: %u", num);
printmsg = 0;
putc(254);
putc(1);
return;
Posted: Wed Dec 22, 2004 9:59 pm |
| I forgot... This program is supposed to count seconds. |
Posted: Wed Dec 22, 2004 10:55 pm |
Have you really compiled this code ? If I try to compile your program,
the line below causes this error message:
"USE parameter value is out of range H/W USART can not invert"
| Code: | | #use rs232(baud=2400,parity=N,invert,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
Posted: Thu Dec 23, 2004 8:43 am |
You get this error message because of the invert in the fuse statement. If you remove that invert option, the code compiles fine.
Anyway, I did get it to count seconds and display the result correctly on the LCD by forcing the compiler to use the Software USART on C6 and C7 pins.
But I was hoping there was another way to do this (using just hardware USART).
here is the most updated version of the code (working)
#device adc=8
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,FORCE_SW,invert,bits=8) |
byte count;
unsigned int num;
int printmsg;
#INT_TIMER0
clock_isr() {
if(--count==0) {
num++;
count = COUNT_TO;
printmsg = 1;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_128 | RTCC_8_BIT);
count = COUNT_TO;
num = 0;
printmsg = 1;
set_timer0(0);
while(1) {
if (printmsg) {
clearScreen();
printmsg = 0;
putc(254);
putc(1);
return;
Posted: Thu Dec 23, 2004 11:25 am |
The hardware UART doesn't support the invert option. Sending non-inverted data to the LCD will result in garbage.
Inverting the data yourself before sending it to the hardware UART won't work because the start- and stopbits will still be non-inverted. Your only option for using the hardware UART is to add an hardware inverter (cheap). |
