Return cursor
alexz
Return cursor
PostPosted: Fri Dec 17, 2004 6:57 am     Reply with quote
I am sending data through the RS232 and read it using some terminal.
When I read it as a string and send WriteByte('\n');
WriteByte('\r');
the cursor is returned to the begining of the next row.
How can I do the similar thing when reading it as HEX in the terminal?
Alex
asmallri
PostPosted: Fri Dec 17, 2004 7:36 am     Reply with quote
You are doing this the wrong way around. Traditional terminals send the end of line sequence <CR><LF> being carriage return and line feed respectively. Most applications expect a line to be terminated either with a <CR> or a <CR><LF> Lots of applications fail when the <LF> preceeds the <CR>
You should be doing
WriteByte('\r');  // this is the carriage return <CR>
WriteByte('\n);  // this is the line feed <LF>
Not sure what you mean. If you mean what is the hex representation of the <CR><LF> characters then this is equivalent to above
WriteByte(0x0d);  // this is the carriage return <CR>
WriteByte(0x0a);  // this is the line feed <LF>
If you meant how do you get a terminal display that is showing the hex representation of characters to display a carriage return and line feed then the answer is you cannot because in hex mode it will desplay the hex value of these control characters
Regards, Andrew
alexz
PostPosted: Fri Dec 17, 2004 7:41 am     Reply with quote
If you meant how do you get a terminal display that is showing the hex representation of characters to display a carriage return and line feed then the answer is you cannot because in hex mode it will desplay the hex value of these control characters[/quote]
Yes, thats what I meant.
Bad news.
Is there a terminal which allows me to do that?
I mean to see numbers in HEX but with returning the carriage after certain amount of sent bytes.
In other words to vombine the HEX view and string together
Alex
SherpaDoug
PostPosted: Fri Dec 17, 2004 7:59 am     Reply with quote
Termial by Br@y can display both ASCII and Hex (and binary and decimal) simultaniously.
http://bray.velenje.cx/avr/terminal
alexz
PostPosted: Fri Dec 17, 2004 9:21 am     Reply with quote
I have got it, so how can I view both string and hex?
Alex
SherpaDoug
PostPosted: Fri Dec 17, 2004 9:58 am     Reply with quote
At the right side of the Receive window there are three check boxes, "Dec", "Hex", and "Bin". Check what you want to see.
Warning: I suspect that if I check them all and the serial data comes in real fast, ie. high baud rate, long strings, small inter-character spacing, on my PC I may miss an occasional character. Therefore don't display all formats if you don't need them.
This is my favorite serial comms program!
alexz
PostPosted: Fri Dec 17, 2004 10:02 am     Reply with quote
I wanna see string and hex at the same time
I wanna return the cariage
Alex
SherpaDoug
PostPosted: Fri Dec 17, 2004 10:23 am     Reply with quote
The main Receive window shows the ASCII values of the bytes, and executes the <CR> and <LF> characters. Simultaniously the Hex window shows the hexadecimal values of the bytes, executing nothing.
What else are you looking for?
P.S. I just noticed the latest version has custom baud rates! So now if your clock is 5% slow you can use 9120 baud instead of 9600. I haven't seen that in a serial program since DOS days! I'll have to test it to see what the granularity is at high baud rates.
alexz
PostPosted: Mon Dec 20, 2004 2:54 am     Reply with quote
I would like to see something like that:
AA AA 80 06 00 01 00 00 40 00
DD DD 12 01 10 01 00 00 00 08
AC AC
AA AA 00 05 03 00 00 00 00 00
AC AC
AC AC
AA AA 80 06 00 01 00 00 12 00
I would like to use the normal strings instead of the values DDDD and AAAA...
But the main thing is that I want see it in coloumn like this and not evering in one row, because its not really readable and hard to follow
Alex
asmallri
PostPosted: Mon Dec 20, 2004 3:08 am     Reply with quote
Hi Alex,
What you are asking for does not make sense because on one hand you would like to see the hexidecimal value of a character and on the other you want the application to respond to control characters. If the application was to correctly interpret <CR> and <LF> then you would expect it to also correctly interpret cursor commands up, down, left, right, erase to EOL, erase to BOL etc. You can't have it both ways :-)
Regards, Andrew
