Howto set up the source for debugging with the CCS ICD?
PostPosted: Tue Dec 14, 2004 9:00 am     Reply with quote
My boss brought packet containing this CCS made IDC-U40 debugger last week and I'm still trying to figure out what changes I need to make in my program to get debugger to work with It.
I only got B7 and B6 datalines connected and Userstream Enabled set to False in debugger conf.
I'm tried to add following to the code.
#opt 0
#device PIC16F877A *=16 ICD=TRUE
//added IDC=TRUE
#use delay(clock=10000000)
#fuses HS,NOPUT,NOCPD,NOPROTECT,NOWDT,NOLVP,BROWNOUT,NOWRT,DEBUG
//Added the DEBUG fuse I don't really know if this is mened for Microchip's //debugger only?
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
//Do I have to enable rs233 manually for ICD or does it generate it's own //code for serial communication?
//Do I have to use settings like STANDARD_IO for PORTB?
Q:http://www.ccsinfo.com/faq/?45
The target chip oscillator must be running for the ICD to work with a debugger.
So do I have to add function call for ICD or something in my RTCC_isr()-function?
At the moment programming is working flawless just debugger keeps throwing me following error after loading program to target MCU.
Could not start target : The target was not halted after reset check the target oscillator and MCLR.
And the program seems to be halted just after printing the 1st line on the lcd.
When I close the debugger I got Error: List index out of bounds.
Any program example for PCM 3.213 explaining howto get the CCS ICD to do some debugging with the PIC16F877A is highly appreciated.
PostPosted: Wed Dec 15, 2004 4:09 pm     Reply with quote
a debugger.
This means you must have a crystal (and the correct capacitors for it)
connected to the OSC1 and OSC2 pins on your 16F877A.
See this FAQ answer which shows how to connect the ICD to your board.
Also download and read the CCS ICD trouble-shooting guide:
http://www.ccsinfo.com/faq/?51
