demarware Guest
| PIC18F8720 Analog Comparator |
Posted: Mon Jan 24, 2005 9:31 pm |
I'm trying implement a comparator interrupt; based on the example EX_COMP.C. (and searching this board)
I'm using an external ref. (200mV, <10K Z), and an input of 0-4V.
Here's the code
#include <18F8720.h>
#device *=16
#device icd=true
#fuses HS, BROWNOUT, NOWDT, PUT, DEBUG, NOLVP
#use delay(clock=19660800)
short safe_conditions=TRUE;
#INT_COMP
void isr() {
safe_conditions=FALSE;
printf("WARNING!! Voltage level is above ref. \r\n");
main() {
printf("\r\nRunning voltage test...\r\n\n");
//setup_comparator(A1_VR_OUT_ON_A2);
//setup_vref(VREF_HIGH|15);
setup_comparator(F6_F5_NC_NC_OUT_ON_F2);
enable_interrupts(INT_COMP);
if(safe_conditions)
printf("Voltage level is below ref. \r\n");
This works as expected, however I need an interrupt when the input is below the ref. So I thought I would only need to switch the inputs?? But that doesn't work, I get the same results.
Except if I debug/break, then switch the wires, then resume execution - I get the irq when the input is < ref. Restarting from a reset produces the opposite.
Where am I confused?
And, the datasheet says "The comparator interrupt flag is set whenever there is a change in the output value of either comparator." This code seems to produce an interrupt whenever X>Y only (even if it is always >), and not on the change back to X<Y. Is that due to the ccs implementation?
Oh yeh, v3.191. (this is the version I should be using right?)
Thanks in advance.
[/code] |
Posted: Mon Jan 24, 2005 10:15 pm |
Both the data sheet and the reference manual state that you must
clear the "change condition" by reading (or writing) the CMCON register.
So I think you should add the lines shown below in bold:
#byte CMCON = 0xFB4
#INT_COMP
void isr() {
char c;
c = CMCON;
PIC18 reference manual for the comparator module:
http://ww1.microchip.com/downloads/en/DeviceDoc/39524.pdf |
demarware Guest
Posted: Mon Jan 24, 2005 11:29 pm |
| Thanks, Now I have both changes. |
demarware Guest
Posted: Tue Jan 25, 2005 10:47 am |
FYI
use bit_test () on CMCON to detect change "direction".
#int_COMP
COMP_isr()
byte b;
b = CMCON;
if(bit_test (b, 6)) //c1out
