Re: Multiple PWM outputs |
Posted: Tue Mar 14, 2006 12:03 am |
davt wrote: | Hi, I need 24 PWM outputs is this possible to do - with the right Pic of course!
I need to read in dmx 512 information and provide multiple PWM outputs.
Can it be done with just one Pic or would it be best to have one Pic dealing with the dmx info. and another dedicated to the PWM outputs?
Can someone advise me on the best way to provide multiple PWM outputs at around 2khz eg. software example or detailed explanation of how this is done - probably using the capture module?
many thanks for your time.
Dave |
there r a dmx decoder:dm118
http://www.freeweb.com.tw/sd/upload/product/File/Product/DM118X%20_SD.pdf
http://www.skylinedynamics.com/ |
Posted: Wed Mar 15, 2006 12:16 am |
Anonymous wrote: | davt wrote: | Hi, I need 24 PWM outputs is this possible to do - with the right Pic of course!
Dave |
i have used the dm118, the 8 channels pwm(100hz, 256 grey degree) is so good for led:) |
Posted: Sun Apr 09, 2006 9:43 pm |
Anonymous wrote: | Anonymous wrote: | davt wrote: | Hi, I need 24 PWM outputs is this possible to do - with the right Pic of course!
Dave |
so good |
tavioman_ Guest
Posted: Mon Apr 10, 2006 5:15 am |
You could use one of Atmel's MCU they have up to 16 PWM channels. |
Posted: Sun May 14, 2006 11:29 pm |
tavioman_ wrote: | You could use one of Atmel's MCU they have up to 16 PWM channels. |
avr so good. |
jemly
DMX |
Posted: Thu Jun 28, 2007 9:04 am |
I know this is an old post but I have been testing the code and it works great as it stands. However I would like to utilise all availble output pins on the 18f252 (16 pins) and I'm having trouble getting this to work. I thought it would be as simple as uncommenting the references to portb and port c in the two interrupt routines but I get strange results - has anyone else tried this?? |
