pom
| Detecting voltage |
Posted: Thu Nov 25, 2004 10:59 am |
I want to detect voltage by a 18F258. I know how to read the AD-converter and by this I get a value among 0 and 255 (8 Bit). In default, the 255 represents a voltage of 5V and the 0 represents a voltage of 0V. By changing the reference, the 255 might represent the voltage level of AN3 (2,5V in this case).
Is it also possible to change the 0 level? My aim is to have the 0 representing the voltage of AN2 (1,2 V in this case). My measurement would be delimited among 1,2V (read as 0) and 2,5V (read as 255).
I hope, you understand the question. My english is not that good. If there are problems in understanding, please ask me.
I am looking forward to your answers. Thank you. |
newguy
Posted: Thu Nov 25, 2004 11:51 am |
From the 18F258's data sheet, page 245:
| Quote: | The analog reference voltage is software selectable to
either the device’s positive and negative supply voltage
(VDD and VSS) or the voltage level on the RA3/AN3/
VREF+ pin and RA2/AN2/VREF- pin. |
So yes, it's definitely possible.
From the 18f258.h file:
| Code: | ////////////////////////////////////////////////////////////////// ADC
// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
// SET_ADC_CHANNEL(), READ_ADC()
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS 0x86 // None
#define ALL_ANALOG 0x80 // A0 A1 A2 A3 A5 E0 E1 E2 Ref=Vdd
#define ANALOG_RA3_REF 0x81 // A0 A1 A2 A5 E0 E1 E2 Ref=A3
#define A_ANALOG 0x82 // A0 A1 A2 A3 A5 Ref=Vdd
#define A_ANALOG_RA3_REF 0x83 // A0 A1 A2 A5 Ref=A3
#define RA0_RA1_RA3_ANALOG 0x84 // A0 A1 A3 Ref=Vdd
#define RA0_RA1_ANALOG_RA3_REF 0x85 // A0 A1 Ref=A3
#define ANALOG_RA3_RA2_REF 0x88 // A0 A1 A5 E0 E1 E2 Ref=A2,A3
#define ANALOG_NOT_RE1_RE2 0x89 // A0 A1 A2 A3 A5 E0 Ref=Vdd
#define ANALOG_NOT_RE1_RE2_REF_RA3 0x8A // A0 A1 A2 A5 E0 Ref=A3
#define ANALOG_NOT_RE1_RE2_REF_RA3_RA2 0x8B // A0 A1 A5 E0 Ref=A2,A3
#define A_ANALOG_RA3_RA2_REF 0x8C // A0 A1 A5 Ref=A2,A3
#define RA0_RA1_ANALOG_RA3_RA2_REF 0x8D // A0 A1 Ref=A2,A3
#define RA0_ANALOG 0x8E // A0
#define RA0_ANALOG_RA3_RA2_REF 0x8F // A0 Ref=A2,A3 |
From this, the setups that would suit you are:
ANALOG_RA3_RA2_REF
If you're only measuring one analog input, then the last choice, RA0_ANALOG_RA3_RA2_REF, would suit you best. |
