arrow Guest
| Weird problem involving timer1 and printf? |
Posted: Mon Nov 15, 2004 1:59 am |
Hi
I have a weird bug involving counters/ timers.
In the code below the interH, and ChXH are output correctly, while interL and ChXL are output incorrectly. If I swap the two bits of code "Look for Low on ChX" and "Look for High on ChX", the output for interL and ChXL are correct now, and the other 2 are incorrect.
By changing the baud rate I can decrase or decrease the error. The error seems always to be a fixed value. I think that printf is occuring simultaneously as the first bit of code in the "while(TRUE)" loop.
I also tried to insert delay_ms(5) but that made the output of the variables out by a further 5ms.
Can someone please help me?
Thank you in advance for your help.
arrow
| Code: | //-----------------------------------
#include <16F873.H>
#fuses HS,NOPROTECT,NOWDT
#use delay(clock=19660800)
#use rs232(baud=57600, xmit=PIN_A0, rcv=PIN_A1)
//=====================nnnce=============================
int inter;
#int_timer1
void int_counter(){
inter++;
main() {
long int ChXH, ChXL;
int interH, interL;
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
while(TRUE){
//***Look for Low on ChX
set_timer1(0);
inter=0;
while(!input(PIN_C2)){
ChXL = get_timer1();
interL = inter;
//***Look for High on ChX
set_timer1(0);
inter=0;
while(input(PIN_C2)){
ChXH = get_timer1();
interH = inter;
printf("H%x%x%x ",
interH,(ChXH>>8)&0x00ff,ChXH&0x00ff
printf("L%x%x%x ",
interL,(ChXL>>8)&0x00ff,ChXL&0x00ff
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Mon Nov 15, 2004 3:08 am |
You are using a software generated serial port, which creates the timings for the desired baud rate artificially (unlike the hardware UART). You also have the Timer1 interrupting at full speed. In CCS, there is an interrupt overhead of about 40 instructions. It seems what is happening is that while the UART is transmitting the interrupt keeps happening and messing up the timing of the bits. The delays CCS uses to generate the correct timing will get bigger, because the length of the ISR keeps getting added to them, many times. This will cause baud rate problem which result in broken communications. Especially with a connection as fast as 57600 which is very sensitive to bit times. At this speed you easily can have a bit streched twice as long as it should be.
You either have to use the hardware UART, or slow down your interrupt, or slow down your serial port (you may need to bring it down as low as 4800bps, believe it or not. do some calculations on the bit-width, the interrupt period and the time it takes to execute the ISR+overhead). |
arrow Guest
Posted: Mon Nov 15, 2004 2:12 pm |
Hi Haplo
Thank you for your reply. I shall try the 4800 baud rate.
Also could you please tell me how to do the UART communication?
I am not sure what UART is, but I need to communicate with my PC over the RS232 port.
All the best
arrow |
Haplo
Posted: Mon Nov 15, 2004 4:23 pm |
Change your #use RS232 statement to:
| Code: | | #use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7,ERRORS) |
This will use the hardware UART which makes RC6 your transmit pin and RC7 your receive pin. In this case all the bit timings are generated in hardware, so the Timer1 interrupt will not mess up the serial communication. Therefore you can maintain the 57600bps and don't need to bring it down.
By the way, you will also need a level converter (such as MAX232) to be able to talk to a PC. |
arrow Guest
Posted: Tue Nov 16, 2004 2:31 am |
Hi Haplo
Thank you for your post. I have tried what you say, and it does not
fix the problem!
I have written a VC++ program that reads the RS232 port, and displays
the data. Both what you suggested, and what I had before allowed the
PC to read the data (I dont seem to be able to go faster than 57600 though).
However, somewhere within the PIC code there is a problem.
Its as if printf starts executing, and instead of completing and
then going back to the while loop, the while loop starts to execute
in parallel (!?!) with the printf- is this possible?
I have noticed that the faster I printf (via baudrate), the smaller
is the timing error.
Also, global disabling the interrupts, does not change the error.
Would you know of a way to ensure that the printf finishes and then
the code goes to the beginning of the loop?
(I tried to delay_ms(5) after the printf, that did not help either).
Once again, I appreciate your help.
All the best
arrow |
Haplo
Posted: Tue Nov 16, 2004 9:39 pm |
The other statements should not run until printf finishes...
It seems like your watchdog is resetting. Make sure the watchdog is disabled. I see you have NOWDT in the fuses, but if you use ICD with MPLAB or some other programmer aside from CCS' ICD.EXE, they will override these fuse settings. Make sure you adjust the fuse settings of the programmer as well.
And by the way, unless you are using Low Voltage Programming, make sure you always include the NOLVP fuse. |
