valemike Guest
| cast "signed int" to "float"? Doesn't wo |
Posted: Wed Nov 10, 2004 8:07 am |
I tried the following:
Suppose i have the following float and signed int:
signed int x;
float y;
float z;
z = y + (float) x;
That's not going to give me desired values, right?
e.g.
y = 10.0
x = -4
z will not evaluate to something like 6.0 (or 5.99999), right? |
valemike Guest
Posted: Wed Nov 10, 2004 8:32 am |
I also found that:
unsigned int x;
float y;
float z;
If i then write the following:
z = y + (float) x;
It doesn't work right!
I have to break it up into two steps:
z = (float) x;
z = z + y;
Has anyone noticed that? |
SherpaDoug
Posted: Wed Nov 10, 2004 10:45 am |
What answer does it give you?
Also what complier version are you using?
I am using 3.104 with 16C771 chips. I do lots of casting and it all works fine. But I don't use floats. _________________ The search for better is endless. Instead simply find very good and get the job done. |
| Re: cast "signed int" to "float"? Doesn' |
Posted: Wed Nov 10, 2004 10:55 am |
| valemike wrote: | I tried the following:
signed int x;
float y;
float z;
z = y + (float) x;
e.g.
y = 10.0
x = -4
Wat you post should work, and has worked OK for me in the past. However I'd probably bracket the cast to seperate it from the arithmetic.
So:
z=y+((float)x);
I have seen problems in the past, with the arithmetic, seeming to get confused by the cast, unless the extra brackets are added.
What are you seeing?.
valemike Guest
Posted: Wed Nov 10, 2004 11:15 am |
I wish I could pull this whole topic thread
I realized that i forgot to read the result from eeprom after a hard reset. False alarm! Sorry.
I couldn't verify the result myself because the unit i'm working uses rb6 and rb7, nor does it have a MAX232 with which to connect to Hyperterminal. |
Posted: Wed Nov 10, 2004 11:23 am |
| valemike wrote: | I wish I could pull this whole topic thread
It happens.
Why though did you think that seperating the lines was making it work, if you couldn't really test it?.
You can allways output a 'diagnostic' byte at a low baud rate, on any pinm and latch this on a digital scope, or simply flash an LED really slowly, and count the pulses, if you have even one pin available.
Mark
Posted: Wed Nov 10, 2004 11:39 am |
| Well if you are using MPLAB, there is a simulator in there that works just great for these tests. That is how I would have tested it. |
