Reading a Register of a PICmicro
chingB
PostPosted: Sun Nov 07, 2004 5:33 am     Reply with quote
How would you be able to read a specific register of a PICmicro... say, PIC18F452 -- register PORTA?
I understand using :
#byte PORTA = 0xF80 --> can be use to write a certain value to a PORTA register?
Anyone can provide me info or a sample code snippet?
BTW would this be also applicable to other PICmicro register?
Thanx
asmallri
PostPosted: Sun Nov 07, 2004 5:46 am     Reply with quote
Here are a couple of examples. The first is writing to PORTB using the standard output_x() functions. The compiler is responsible for knowing the location of PORTB in the example.
   output_b(PB_DefData);
   set_tris_b(PB_DefTRIS);
The second methid is more flexible except you need to tell the compiler the location (address) of the register which means the code is processor dependent.
byte   TXREGM; #locate TXREGM = 0x10 // Transmit Register
   TXREGM = TxChar;
Regards, Andrew
chingB
PostPosted: Sun Nov 07, 2004 6:00 am     Reply with quote
Thank u asmallri...
The information you provide would be of great help.
dyeatman
More info....
PostPosted: Sun Nov 07, 2004 8:06 am     Reply with quote
This question is covered in the FAQ section and shows a more straight forward way of doing it... It also shows how to map a struct to a port.
http://www.ccsinfo.com/faq/?18
<and>
valemike
PostPosted: Sun Nov 07, 2004 8:15 am     Reply with quote
I prefer to do bit manipulation the following way:
#byte PIC_THIS_REG 0x20 // for example
If I want to set bit 3:
PIC_THIS_REG |= 0x08; // 0000 1000
If I want to clear bit 3:
PIC_THIS_REG &= ~0x08; // 0000 1000
In fact, there is only one assembly instruction generated by this.
bsf or bcf.
Mark
PostPosted: Sun Nov 07, 2004 8:39 am     Reply with quote
All these examples really show writing. The really simple answer is
PORTA = var;  // write to register
var = PORTA; // read from register
asmallri
PostPosted: Sun Nov 07, 2004 8:47 am     Reply with quote
This is only simple for registers that have been defined. By default CCS only defines a few. If you want anything else you end up with the second example being a good fit.
   TXREGM = TxChar;
Regards, Andrew
Mark
PostPosted: Sun Nov 07, 2004 9:56 am     Reply with quote
Read his orginal post. He knows how to do that. He just didn't understand that reading a value was just as simple as writing one.
