davt
| madness setting in! |
Posted: Fri Nov 05, 2004 8:46 am |
Hi all
Compiler version 3.210.
Pic 16F767.
Programmer Warp-13
If I program my 16F767 with the code below which continually sets the test pins high - all pins should remain high!!
But what I am seeing are pulses 0.2us wide and 2us spacing on pins portb.1 to portb.4
trisa=0b00000111;
trisb=0b00000000;
trisc=0b10000000; // set rc7 rx as an input
test0=0; //
test1=0; // oscilloscope
test2=0; // test
test3=0; // pins
test4=0;
test5=0;
test6=0;
test7=0;
gie=0; // disable all interrupts
test2=1;
test3=1;
test4=1;
test5=1;
test6=1;
test7=1;
If I alter the code to:
trisa=0b00000111;
trisb=0b00000000;
test0=0; //
test2=0; // test
test3=0; // pins
test4=0;
test5=0;
test6=0;
test7=0;
portb=0xff; // sets all pins high
All the pins remain high - as they should!
This only happens on a 16F767
Am I missing something???????
Dave |
SherpaDoug
Posted: Fri Nov 05, 2004 9:22 am |
It sounds like a read-modify-write problem. Try adding a 1ms delay between setting each pin high:
test2=1;
delay_ms(1);
test3=1;
delay_ms(1);
test4=1;
delay_ms(1);
test5=1;
delay_ms(1);
test6=1;
delay_ms(1);
test7=1;
delay_ms(1);
and see if the problem goes away. The root of the problem is the structure of the PIC output pin and its connection to the CPU, there is nothing the compiler can do about it. If two commands to modify a port are in the instruction pipeline together, the first one may be lost. A short delay (1us is probably enough depending on your clock speed) lets the first command complete before the second starts, so everything works.
I am sure there many references to this "gotchya" on this BBS and any other PIC related source. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Mark
Posted: Fri Nov 05, 2004 10:54 am |
| Quote: | The root of the problem is the structure of the PIC output pin and its connection to the CPU, there is nothing the compiler can do about it. If two commands to modify a port are in the instruction pipeline together, the first one may be lost. A short delay (1us is probably enough depending on your clock speed) lets the first command complete before the second starts, so everything works.
Note quite true. The command doesn't get lost. What happens is that the first command is executed and the pin is set to go high. Now this takes some time. The next instruction to set a bit high occurs. Now what really happens is that the port is read, bit changed, and written back out. The problem is that the read occured before the previous bit set had enough time to allow the output to reach a logic level of 1. A small delay will fix this. Some PICs (18's) have a LAT register (LATA, LATB,...). If you use this register you won't have the problem because the data is written to a latch. |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Fri Nov 05, 2004 11:20 am |
What about adding [/code] _________________ Regards, Andrew
SherpaDoug
Posted: Fri Nov 05, 2004 11:37 am |
| asmallri wrote: | | What about adding [/code] |
I don't think that will help. This has nothing to do with the TRIS register. It has more to do with the capacitance on the I/O lines and the ability of the drivers to drive the line to the opposite state before the next instruction starts. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Mark
Posted: Fri Nov 05, 2004 12:38 pm |
| It could actually make it worse. With standard IO the tris register are set/cleared with takes additional instruction cylcles with actually adds a small amount of delay. |
| Re: madness setting in! |
Posted: Sat Nov 06, 2004 6:03 pm |
How did you declare
test0 to test7 ? |
