		| Author | Message |
		| rafa
				| I need help with my graphic lcd based in T6963C |
				|  Posted: Tue Sep 28, 2004 10:32 am |   |
				| I can't make my lcd function. I have found code for it but it isn't sufficient. Please, someboby give me the code. I already have been 1 month workng and i don't find a solution.
 Thanks,  rafa
		| Oznog
				|  Posted: Sat Oct 16, 2004 1:59 am |   |
				| What is it doing?
 Post your code, maybe we can fix it?  I've done T6963C, graphics tasks, graphical fonts, it's all good.
 And- the question that will make you find something breakable around you and smash it if this is it- did you give it the appropriate -Vee?  Display won't show anything without it!
		| Mark
				|  Posted: Sat Oct 16, 2004 10:28 am |   |
				| Then post your question in the other forum.  This one is for posting code to share with others and not for asking questions.  Also do a search.  That is the first thing you should do.  I know I have seen routines posted for that controller.  Heck, it is even in this forum!!!
 http://www.ccsinfo.com/forum/viewtopic.php?t=19957&highlight=t6963c
		| rafa
				|  Posted: Mon Oct 18, 2004 5:02 am |   |
				| This is the code i'm using. Initially this war for a pic18f452. I have intented change it but i can't get function it for my pic16f877.
 ////                           EX_GLCD.C                             ////
 //// This example program demonstrates the use of a graphic LCD.     ////
 //// A reading is taken by the analog to digital converter and       ////
 //// displayed on the LCD. A bar shows the current reading relative  ////
 //// to the minimum and maximum values. If the reading is greater    ////
 //// than 4 volts, a warning message is displayed. A clock timer     ////
 //// demonstrates the use of the circle and line functions and shows ////
 //// that the program is active.                                     ////
 ////        (C) Copyright 1996,2003 Custom Computer Services         ////
 //// This source code may only be used by licensed users of the CCS  ////
 //// C compiler.  This source code may only be distributed to other  ////
 //// licensed users of the CCS C compiler.  No other use,            ////
 //// reproduction or distribution is permitted without written       ////
 //// permission.  Derivative programs created using this software    ////
 //// in object code form are not restricted in any way.              ////
 #if defined(__PCM__)
 #include <16f877.h>   //CAMBIO
 #CASE
 //#fuses HS,NOWDT,PROTECT,NOLVP,WRT,BROWNOUT,BORV45,NODEBUG,STVREN,PUT,NODEBUG
 #fuses HS,NOWDT,NOPROTECT,NOLVP,PUT,BROWNOUT
 //CAMBIO: he cambiado este fuses por el de arriba + put + brownout
 //#fuses HS,NOWDT,PROTECT,NOLVP,WRT,BROWNOUT,BORV45,NODEBUG,STVREN,PUT,NODEBUG,WRT,WRTD,WRTB,WRTC,CPD,CPB
 #use delay(clock=4000000)   //CAMBIO: ulilizo una velocidad de 4000000
 //CAMBIOS:¿hacen falta las 3 proximas lineas?
 //#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
 //#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=STDERR) // STDERR(same as DEBUG)
 //#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,stream=RS485)  // RS485 is the default
 #zero_ram
 #use fast_io(D)  //CAMBIO
 #include <stdlib.h>
 //#include <stdlibm.h>  //AQUI ESTA EL ERROR
 #include <math.h>
 int16 ERRORS;
 #include "LCD_T6963C.h"     //CAMBIO: incluyo esta libreria
 void displayVoltage(int data) {
 char voltValue[9];                                // Stores the converted number
 sprintf(voltValue, "%f", (float)data * .01960784);// Converts number to text
 voltValue[4] = '\0';                              // Limit shown digits to 3
 glcd_rect(45, 18, 69, 25, YES, OFF);              // Clear the old number
 glcd_text57(45, 18, voltValue, 1, ON);            // Write the new number
 int   value1 = 0, value2 = 0, Warn = 0;
 char  voltText[] = "Volts", warning[] = "Warning";
 float theta = 0;
 //setup_adc_ports(RA0_ANALOG);                 // Set the ADC to read A0
 //setup_adc(ADC_CLOCK_INTERNAL);               // Set the ADC clock
 //set_adc_channel(0);                          // Set ADC to use channel 0
 glcd_init(ON);
 glcd_WriteCmd0(LCDDispMode | LCDDisp_GRH);   // Must initialize the LCD
 //glcd_rect(1, 5, 126, 15, NO, ON);            // Draw the rectangle around the bar
 glcd_text57(70, 18, voltText, 1, ON);        // Write "Volts" on the LCD
 glcd_circle(30, 47, 10, NO, ON);             // Draw the clock circle
 do{value1 = read_adc();                      // Read a value from the ADC
 displayVoltage(value1);                   // Display the reading
 value1 = (value1 > 250) ? 250 : value1;   // Keep the value under 251
 if(value1 > 200 && !Warn) {               // Check if reading is above 200
 glcd_rect(45, 38, 124, 55, YES, ON);   // Draw a filled black rectangle
 glcd_text57(47, 40, warning, 2, OFF);  // Write "Warning" on the LCD
 Warn = 1; }
 else if(value1 <=200){
 glcd_rect(45, 37, 125, 55, YES, OFF);  // Draw a filled white rectangle
 Warn = 0; }
 // The following 3 lines make the clock hand spin around
 glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), OFF);
 theta = (theta > 5.9) ? 0 : (theta += .3);
 glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), ON);
 glcd_rect(value1/2, 6, value2/2, 14, YES, OFF); // Clears the old bar
 glcd_rect(1, 6, value1/2, 14, YES, ON);         // Draws a new bar
 value2 = value1;                                // Set old value to new
 delay_ms(150);                                  // Delay for a bit
 } while (TRUE);
 //  Notice : Copyright (c) 2004 Sentinel Systems Corporation
 //         : All Rights Reserved
 //  Date   : 01-05-2004
 //  Version: 1.0
 //// LCD_T6963C.c
 //// This file contains drivers for using a Tosiba T6963C controller ////
 //// in parallel/8080(intel) mode.  The T6963C is 240 pixels across  ////
 ////  and 64 pixels down. The driver treats the upper left pixel 0,0 ////
 ////  glcd_init(mode)                                                ////
 ////  glcd_pixel(x,y,color)                                          ////
 ////  glcd_line(x1,y1,x2,y2,color)                                   ////
 ////  glcd_rect(x1,y1,x2,y2,fill,color)                              ////
 ////  glcd_bar(x1,y1,x2,y2,width,color)                              ////
 ////  glcd_circle(x,y,radius,fill,color)                             ////
 ////  glcd_text57(x,y,textptr,size,color)                            ////
 ////  glcd_fillScreen(color)                                         ////
 //5/25/2004 9:26AM consolidating pins on port A & D
 //5/25/2004 10:06AM consolidating pins on port C & D
 //5/26/2004 7:48AM V1.2.4
 //5/26/2004 7:48AM Fixing little graphics problems
 //5/26/2004 10:22AM V1.2.5
 //5/27/2004 8:31AM V1.2.6 Good LCD, RX/TX, now working on keypad
 #ifndef GLCD_COL
 #define GLCD_COL 240    // Used for text wrapping by glcd_text57 function and sanity check
 #ifndef GLCD_ROW
 #define GLCD_ROW 128    //CAMBIO: 64 en vez de 128
 #define ON  1
 #define OFF 0
 #define YES 1
 #define NO  0
 #define set_tris_lcd(x) set_tris_c(0b00000000);set_tris_d(x) //CAMBIO: 0b00000000 por 0b10000000
 #define set_lcd_defaults(x) set_tris_lcd(0xFF);LCD.w_bar=1;LCD.r_bar=1;LCD.cd=1;LCD.reset=1 //CAMBIO:RESET
 #define glcd_WriteCmd0(x) glcd_WriteByte(1,x)
 #define DispScn(x) glcd_WriteCmd2(TextHome+240*x,0x80)   //CAMBIO: 0x80 por 0x40
 #define LCDTxtAdr(s,x,y) 0x780+(240*s)+(AreaSet_T*y)+x
 #define LCDSetPtr 0x24
 //FS=0, 5x7 char in 8x8 field, 30char/line, 240 char total,graphic pics 8pixels/address, 0x780 grh addresses
 //FS=1, 5x7 char in 6x8 field, 40char/line, 320 char total,graphic pics 6pixels/address, 0xA00 grh addresses
 // - - - - 64K RAM - - - - 0 to 0xFFFF
 // 0 grh home
 // grh end (right before txt home)
 // 0x780----(screen 0)  or 0xA00 Txt home depends on FS
 // 0x870----(screen 1)  adding 240 for each screen
 // 0x960----(screen 2)
 // 0xA50----(screen 3)
 const int1  LCDFont  = 0;//FS pin has internal pull-up. FS=1 unless grounded
 const int8  LCDField = 8+(!LCDFont*2); //CAMBIO:8 POR 6 //FS=1 then field=6. FS=0 then field=8
 const int8  LCDCharWidth  = GLCD_COL /LCDField;
 const int16 CharPerScn= LCDCharWidth*16; //CAMBIO: 16 por 8 //number of characters on a screen
 const int16 GraphicsHome=0x0000;        //RAM area where graphics is held
 const int8  AreaSet_G= 30+(LCDFont*10); //how many bytes before a new line
 const int16 TextHome = (GLCD_COL/LCDField)*128;  //CAMBIO: 128 por 64//text comes right after graphics area
 const int8  AreaSet_T= 30+(LCDFont*10); //how many bytes before a new line. 30 or 40
 const int8 AutoModeWrite=0xB0;
 const int8 AutoModeRead =0xB1;
 const int8 AutoModeReset=0xB2;
 const int8 LCDModeSet  = 0x80;//send this OR'd with the following
 const int8 LCDMode_OR  = 0b0000;
 const int8 LCDMode_XOR = 0b0001;
 const int8 LCDMode_AND = 0b0010;
 const int8 LCDMode_TA  = 0b0100; //TEXT ATTRIBUTE mode.
 const int8 LCDMode_RAM = 0b1000; //1=CG RAM, 0=internal CG ROM
 const int8 LCDSetCursorPtr =0x21;  //Cursor position
 const int8 LCDSetCursorSize=0xA0;  //Number of lines in the cursor
 const int8 LCDDispMode = 0x90;//send this OR'd with the following
 const int8 LCDDisp_BLK = 0b0001;
 const int8 LCDDisp_CUR = 0b0010;
 const int8 LCDDisp_TXT = 0b0100;
 const int8 LCDDisp_GRH = 0b1000;
 const int8 LCDMaxBusyCount = 4;//will try count-1 times before giving up
 //#include <stdlibm.h>  //CAMBIO: lo puse yo
 struct lcd_pin_def
 BOOLEAN fs1;   // C0
 BOOLEAN md2;   // C1
 BOOLEAN reset;      // C2
 BOOLEAN ce;   // C3
 BOOLEAN w_bar;      // C4 Write bar active low
 BOOLEAN r_bar;      // C5 Read bar active low
 BOOLEAN cd;         // C6 Command/Data BCR   1=command 0=data
 BOOLEAN unusedC7;   // C7
 //BOOLEAN unusedC4;   // C4
 //BOOLEAN unusedC5;   // C5
 //BOOLEAN unusedC6;   // C6
 //BOOLEAN unusedC7;   // C7
 // int     data   : 8;  // D=Data bus
 struct lcd_pin_def  LCD;
 struct lcd_pin_def1
 int data:8;
 struct lcd_pin_def1  LCD1;
 #byte LCD  = 0x07   //CAMBIO     //note: no semicolin    5=A0 on a 16F877A
 //int data[8];
 #byte LCD1 = 0x08
 //#use fast_io(C)
 //#use fast_io(D)
 //#byte LCD  = 0xF82   //note: no semicolin    5=A0 on a 16F877A
 #bit  LCDSTA0 = 0x8.0    //CAMBIO: he cambiado las proximas direcciones
 #bit  LCDSTA1 = 0x8.1
 #bit  LCDSTA2 = 0x8.2
 #bit  LCDSTA3 = 0x8.3
 //---------------- Prototypes--------------------
 //void glcd_FontSelect(int1 fs);
 glcd_WriteByte(int1 cd, BYTE data);
 glcd_WriteByteAuto(BYTE data);
 BYTE glcd_ReadByte();
 BYTE glcd_ReadByteAuto();
 glcd_WriteCmd1(BYTE data, BYTE cmd);
 glcd_WriteCmd2(int16 data, BYTE cmd);
 glcd_pixel(int16 x,int16 y,int1 color);
 glcd_clr(int16 location, int16 size);
 void glcd_CpyScn(unsigned int16 ptr1,unsigned int16 ptr2);
 //             INICIALIZACION                        //
 void glcd_init(int1 mode)
 //fprintf(DEBUG,"LCD init\n\r");
 set_lcd_defaults();
 //reset
 //LCD.w_bar=0;  // preform a reset.  When w_bar=0 & r_bar=0 then reset_bar=0
 //LCD.r_bar=0;  // preform a reset.
 LCD.reset=0;  //reset
 delay_ms(1);  // delay 1ms minimo,CAMBIO:yo pongo 2 por ejemplo
 LCD.reset=1;
 LCD.fs1=0;
 LCD.md2=0;
 LCD.ce=0;
 //LCD.w_bar=1;  // run
 //LCD.r_bar=1;  //
 //Set up the graphics and text areas
 glcd_WriteCmd2(TextHome,0x40);     //set text home
 glcd_WriteCmd2(AreaSet_T,0x41);   //set text area
 glcd_WriteCmd2(GraphicsHome,0x42);//set graphics home
 glcd_WriteCmd2(AreaSet_G,0x43);   //set graphics area
 //cursor
 glcd_WriteCmd0(LCDSetCursorSize | (0x01-1));//1 line cursor
 glcd_WriteCmd2(0x0000,LCDSetCursorPtr);//0x  yy xx , cursor position
 //modes
 glcd_WriteCmd0(LCDModeSet | LCDMode_XOR);
 //glcd_WriteCmd0(LCDDispMode | LCDDisp_TXT |LCDDisp_BLK | LCDDisp_CUR);
 glcd_WriteCmd0(LCDDispMode | LCDDisp_TXT);
 //offset register
 glcd_WriteCmd2(0x0002,0x22);//offset register=0x0002
 //Clear all RAM of LCD
 glcd_clr(0x0000,0xFFFF);//Clear all of RAM
 //fprintf(DEBUG,"LCD init DONE.\n\r");
 // Purpose:       Copys a screen(CharPerScn bytes) from ptr2 to ptr1
 // Inputs:        ptr1 ptr2
 // Ouputs:
 int8 x;
 int8 temp_array[128];       //CAMBIO
 ////fprintf(DEBUG,"ptr1=%lx  ptr2=%lx\n\r",ptr1,ptr2);
 //read data and put in array
 glcd_WriteCmd2(ptr2,LCDSetPtr);
 glcd_WriteCmd0(AutoModeRead);
 for (x=0;x<CharPerScn;x++)
 temp_array[x]=glcd_ReadByteAuto();
 ////fprintf(DEBUG,"0x%lx<-0x%x ",ptr2+x,temp_array[x]);
 glcd_WriteCmd0(AutoModeReset);
 //write data from array
 glcd_WriteCmd2(ptr1,LCDSetPtr);
 glcd_WriteCmd0(AutoModeWrite);
 glcd_WriteByteAuto(temp_array[x]);
 ////fprintf(DEBUG,"0x%x->0x%lx ",temp_array[x],ptr1+x);
 // Purpose:       Writes a byte of data from the current location
 // Inputs:        cd  1=command 0=data     BYTE data
 // Ouputs:        Int1 1=success 0=failure
 void glcd_WriteByte(int1  cd, BYTE data)
 set_lcd_defaults();
 LCD.r_bar=0;      // Read
 while(!LCDSTA0 && !LCDSTA1) //CAMBIO:&& por || //wait till both are one
 ////fprintf(DEBUG,".");
 LCD.r_bar=1;      // Release
 //  if(cd==0) {//fprintf(DEBUG,"D=%lx ",data);}
 //  if(cd==1) {//fprintf(DEBUG,"C=%lx ",data);}
 set_tris_lcd(0x00); //All outputs
 LCD.cd=cd;          //Command/Data bar
 LCD1.data=data;
 LCD.w_bar=0;        //write
 set_lcd_defaults();
 // Purpose:       Writes continuous bytes of data from the current location
 // Inputs:        BYTE data
 void glcd_WriteByteAuto(BYTE data)
 set_lcd_defaults();
 while(!LCDSTA3) //wait till STA3 is one
 LCD.cd=0;           //This is always data, cd=0
 LCD1.data=data;      //Put data on data bus
 set_lcd_defaults();
 // Purpose:       Reads continuous bytes of data from the current location, and inc
 // Ouputs:        Data byte read
 BYTE glcd_ReadByteAuto(void)
 int8 data;
 set_lcd_defaults();
 while(!LCDSTA2) //wait till STA2 is one
 set_tris_lcd(0xff); // All inputs
 LCD.cd=0;           // This is always data, cd=0
 data=LCD1.data;      // Read data bus
 set_lcd_defaults();
 return (data);   //Return status
 // Purpose:       Writes a one byte of data and a command
 // Inputs:        BYTE data     BYTE cmd
 void glcd_WriteCmd1(BYTE data, BYTE cmd)
 glcd_WriteByte(0,data);
 glcd_WriteCmd0(cmd);
 // Purpose:       Writes a two data byte command
 // Inputs:        int16 data     BYTE cmd
 void glcd_WriteCmd2(int16 data, BYTE cmd)
 int8 lcddata;
 //  glcd_WriteByte(0,data & 0xFF);
 //  glcd_WriteByte(0,data>>8);
 //  glcd_WriteCmd0(cmd);
 // - - - - - - - - - - - - data - - - - - - - - -
 set_lcd_defaults();
 lcddata=data & 0xFF;
 while(!LCDSTA0 && !LCDSTA1) //CAMBIO:&& por || //wai t till both are one
 LCD.cd=0;          //Command/Data bar
 LCD1.data=lcddata;
 set_lcd_defaults();
 lcddata=data>>8;
 LCD1.data=lcddata;
 // - - - - - - - - - - - - command- - - - - - - -
 set_lcd_defaults();
 LCD.cd=1;          //Command/Data bar
 LCD1.data=cmd;
 set_lcd_defaults();
 // Purpose:       Clears LCD RAM
 void glcd_clr(int16 location,int16 size)
 ////fprintf(DEBUG,"loc=%lu  size=%lu\n\r",location,size);
 glcd_WriteCmd2(location,LCDSetPtr);
 for (;size;size--)
 glcd_WriteByteAuto(0x00);//clear ram
 // Purpose:       Reads a byte of data from the current location
 // Ouputs:        A byte of data read from the LCD
 int8 data=0;
 //do a read and don't inc command
 glcd_WriteCmd0(0xc5);
 set_lcd_defaults();
 LCD.cd=0;         // Command/Data bar
 data=LCD1.data;    // Latch data
 set_lcd_defaults();
 ////fprintf(DEBUG,"-0x%x-",data);
 return(data);        //Return the read data
 // Purpose:       Sends data to LCD
 void glcd_putc( char c) {
 ////fprintf(DEBUG,"P=0x%x ",c);
 switch (c) {
 //     case '\f'   : lcd_send_byte(0,1);
 //                   delay_ms(2);
 //                                           break;
 //     case '\n'   : lcd_gotoxy(1,2);        break;
 //     case '\b'   : lcd_send_byte(0,0x10);  break;
 default     : glcd_WriteCmd1(c-0x20,0xc0);break;//Write to LCD autoinc
 // Purpose:       Turn a pixel on a graphic LCD on or off
 // Inputs:        x - the x coordinate of the pixel
 //                y - the y coordinate of the pixel
 //                color - ON or OFF
 // Output:        1 if coordinate out of range, 0 if in range
 glcd_pixel(int16 x,int16 y, int1 color)
 int8 r=0,c=0;
 c=color;//converting booean to an int8
 if (x>=GLCD_COL)
 bit_set(ERRORS,5);//ERRORS=bit 5. LCD x range exceeded
 return (FALSE);
 if (y>=GLCD_ROW)
 bit_set(ERRORS,6);//ERRORS=bit 6. LCD y range exceeded
 return (FALSE);
 r=fmod(x,8);
 glcd_WriteCmd2(GraphicsHome+(y*30+(x/8)),LCDSetPtr);
 glcd_WriteCmd0(0xf0|(c<<3) |(7-r));
 // Purpose:       Draw a line on a graphic LCD using Bresenham's
 //                line drawing algorithm
 // Inputs:        (x1, y1) - the start coordinate
 //                (x2, y2) - the end coordinate
 // Dependencies:  glcd_pixel()
 void glcd_line(int x1, int y1, int x2, int y2, int1 color)
 signed int  x, y, addx, addy, dx, dy;
 signed long P;
 int i;
 dx = abs((signed int)(x2 - x1));
 dy = abs((signed int)(y2 - y1));
 x = x1;
 y = y1;
 if(x1 > x2)
 addx = -1;
 addx = 1;
 if(y1 > y2)
 addy = -1;
 addy = 1;
 if(dx >= dy)
 P = 2*dy - dx;
 for(i=0; i<=dx; ++i)
 glcd_pixel(x, y, color);
 if(P < 0)
 P += 2*dy;
 x += addx;
 P += 2*dy - 2*dx;
 x += addx;
 y += addy;
 P = 2*dx - dy;
 for(i=0; i<=dy; ++i)
 if(P < 0)
 P += 2*dx;
 y += addy;
 P += 2*dx - 2*dy;
 x += addx;
 y += addy;
 // Purpose:       Draw a rectangle on a graphic LCD
 //                fill  - YES or NO
 // Dependencies:  glcd_pixel(), glcd_line()
 void glcd_rect(int x1, int y1, int x2, int y2, int fill, int1 color)
 if(fill)
 int y, ymax;                          // Find the y min and max
 if(y1 < y2)
 y = y1;
 ymax = y2;
 y = y2;
 ymax = y1;
 for(; y<=ymax; ++y)                    // Draw lines to fill the rectangle
 glcd_line(x1, y, x2, y, color);
 glcd_line(x1, y1, x2, y1, color);      // Draw the 4 sides
 glcd_line(x1, y2, x2, y2, color);
 glcd_line(x1, y1, x1, y2, color);
 glcd_line(x2, y1, x2, y2, color);
 // Purpose:       Draw a bar (wide line) on a graphic LCD
 //                width  - The number of pixels wide
 void glcd_bar(int x1, int y1, int x2, int y2, int width, int1 color)
 signed int  x, y, addx, addy, j;
 signed long P, dx, dy, c1, c2;
 int i;
 x = x1;
 y = y1;
 c1 = -dx*x1 - dy*y1;
 c2 = -dx*x2 - dy*y2;
 if(x1 > x2)
 addx = -1;
 c1 = -dx*x2 - dy*y2;
 c2 = -dx*x1 - dy*y1;
 addx = 1;
 if(y1 > y2)
 addy = -1;
 addy = 1;
 if(dx >= dy)
 P = 2*dy - dx;
 for(j=-(width/2); j<width/2+width%2; ++j)
 if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
 glcd_pixel(x, y+j, color);
 if(P < 0)
 P += 2*dy;
 x += addx;
 P += 2*dy - 2*dx;
 x += addx;
 y += addy;
 P = 2*dx - dy;
 if(P < 0)
 P += 2*dx;
 y += addy;
 P += 2*dx - 2*dy;
 x += addx;
 y += addy;
 glcd_pixel(x+j, y, color);
 // Purpose:       Draw a circle on a graphic LCD
 // Inputs:        (x,y) - the center of the circle
 //                radius - the radius of the circle
 //                fill - YES or NO
 void glcd_circle(int x, int y, int radius, int1 fill, int1 color)
 signed int a, b, P;
 a = 0;
 b = radius;
 P = 1 - radius;
 do
 if(fill)
 glcd_line(x-a, y+b, x+a, y+b, color);
 glcd_line(x-a, y-b, x+a, y-b, color);
 glcd_line(x-b, y+a, x+b, y+a, color);
 glcd_line(x-b, y-a, x+b, y-a, color);
 glcd_pixel(a+x, b+y, color);
 glcd_pixel(b+x, a+y, color);
 glcd_pixel(x-a, b+y, color);
 glcd_pixel(x-b, a+y, color);
 glcd_pixel(b+x, y-a, color);
 glcd_pixel(a+x, y-b, color);
 glcd_pixel(x-a, y-b, color);
 glcd_pixel(x-b, y-a, color);
 if(P < 0)
 P+= 3 + 2*a++;
 P+= 5 + 2*(a++ - b--);
 } while(a <= b);
 const BYTE TEXT[51][5] ={ 0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
 0x00, 0x00, 0x5F, 0x00, 0x00, // !
 0x00, 0x03, 0x00, 0x03, 0x00, // "
 0x14, 0x3E, 0x14, 0x3E, 0x14, // #
 0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
 0x43, 0x33, 0x08, 0x66, 0x61, // %
 0x36, 0x49, 0x55, 0x22, 0x50, // &
 0x00, 0x05, 0x03, 0x00, 0x00, // '
 0x00, 0x1C, 0x22, 0x41, 0x00, // (
 0x00, 0x41, 0x22, 0x1C, 0x00, // )
 0x14, 0x08, 0x3E, 0x08, 0x14, // *
 0x08, 0x08, 0x3E, 0x08, 0x08, // +
 0x00, 0x50, 0x30, 0x00, 0x00, // ,
 0x08, 0x08, 0x08, 0x08, 0x08, // -
 0x00, 0x60, 0x60, 0x00, 0x00, // .
 0x20, 0x10, 0x08, 0x04, 0x02, // /
 0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
 0x04, 0x02, 0x7F, 0x00, 0x00, // 1
 0x42, 0x61, 0x51, 0x49, 0x46, // 2
 0x22, 0x41, 0x49, 0x49, 0x36, // 3
 0x18, 0x14, 0x12, 0x7F, 0x10, // 4
 0x27, 0x45, 0x45, 0x45, 0x39, // 5
 0x3E, 0x49, 0x49, 0x49, 0x32, // 6
 0x01, 0x01, 0x71, 0x09, 0x07, // 7
 0x36, 0x49, 0x49, 0x49, 0x36, // 8
 0x26, 0x49, 0x49, 0x49, 0x3E, // 9
 0x00, 0x36, 0x36, 0x00, 0x00, // :
 0x00, 0x56, 0x36, 0x00, 0x00, // ;
 0x08, 0x14, 0x22, 0x41, 0x00, // <
 0x14, 0x14, 0x14, 0x14, 0x14, // =
 0x00, 0x41, 0x22, 0x14, 0x08, // >
 0x02, 0x01, 0x51, 0x09, 0x06, // ?
 0x3E, 0x41, 0x59, 0x55, 0x5E, // @
 0x7E, 0x09, 0x09, 0x09, 0x7E, // A
 0x7F, 0x49, 0x49, 0x49, 0x36, // B
 0x3E, 0x41, 0x41, 0x41, 0x22, // C
 0x7F, 0x41, 0x41, 0x41, 0x3E, // D
 0x7F, 0x49, 0x49, 0x49, 0x41, // E
 0x7F, 0x09, 0x09, 0x09, 0x01, // F
 0x3E, 0x41, 0x41, 0x49, 0x3A, // G
 0x7F, 0x08, 0x08, 0x08, 0x7F, // H
 0x00, 0x41, 0x7F, 0x41, 0x00, // I
 0x30, 0x40, 0x40, 0x40, 0x3F, // J
 0x7F, 0x08, 0x14, 0x22, 0x41, // K
 0x7F, 0x40, 0x40, 0x40, 0x40, // L
 0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
 0x7F, 0x02, 0x04, 0x08, 0x7F, // N
 0x3E, 0x41, 0x41, 0x41, 0x3E, // O
 0x7F, 0x09, 0x09, 0x09, 0x06, // P
 0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
 0x7F, 0x09, 0x09, 0x09, 0x76};// R
 const BYTE TEXT2[44][5]={ 0x26, 0x49, 0x49, 0x49, 0x32, // S
 0x01, 0x01, 0x7F, 0x01, 0x01, // T
 0x3F, 0x40, 0x40, 0x40, 0x3F, // U
 0x1F, 0x20, 0x40, 0x20, 0x1F, // V
 0x7F, 0x20, 0x10, 0x20, 0x7F, // W
 0x41, 0x22, 0x1C, 0x22, 0x41, // X
 0x07, 0x08, 0x70, 0x08, 0x07, // Y
 0x61, 0x51, 0x49, 0x45, 0x43, // Z
 0x00, 0x7F, 0x41, 0x00, 0x00, // [
 0x02, 0x04, 0x08, 0x10, 0x20, // \
 0x00, 0x00, 0x41, 0x7F, 0x00, // ]
 0x04, 0x02, 0x01, 0x02, 0x04, // ^
 0x40, 0x40, 0x40, 0x40, 0x40, // _
 0x00, 0x01, 0x02, 0x04, 0x00, // `
 0x20, 0x54, 0x54, 0x54, 0x78, // a
 0x7F, 0x44, 0x44, 0x44, 0x38, // b
 0x38, 0x44, 0x44, 0x44, 0x44, // c
 0x38, 0x44, 0x44, 0x44, 0x7F, // d
 0x38, 0x54, 0x54, 0x54, 0x18, // e
 0x04, 0x04, 0x7E, 0x05, 0x05, // f
 0x08, 0x54, 0x54, 0x54, 0x3C, // g
 0x7F, 0x08, 0x04, 0x04, 0x78, // h
 0x00, 0x44, 0x7D, 0x40, 0x00, // i
 0x20, 0x40, 0x44, 0x3D, 0x00, // j
 0x7F, 0x10, 0x28, 0x44, 0x00, // k
 0x00, 0x41, 0x7F, 0x40, 0x00, // l
 0x7C, 0x04, 0x78, 0x04, 0x78, // m
 0x7C, 0x08, 0x04, 0x04, 0x78, // n
 0x38, 0x44, 0x44, 0x44, 0x38, // o
 0x7C, 0x14, 0x14, 0x14, 0x08, // p
 0x08, 0x14, 0x14, 0x14, 0x7C, // q
 0x00, 0x7C, 0x08, 0x04, 0x04, // r
 0x48, 0x54, 0x54, 0x54, 0x20, // s
 0x04, 0x04, 0x3F, 0x44, 0x44, // t
 0x3C, 0x40, 0x40, 0x20, 0x7C, // u
 0x1C, 0x20, 0x40, 0x20, 0x1C, // v
 0x3C, 0x40, 0x30, 0x40, 0x3C, // w
 0x44, 0x28, 0x10, 0x28, 0x44, // x
 0x0C, 0x50, 0x50, 0x50, 0x3C, // y
 0x44, 0x64, 0x54, 0x4C, 0x44, // z
 0x00, 0x08, 0x36, 0x41, 0x41, // {
 0x00, 0x00, 0x7F, 0x00, 0x00, // |
 0x41, 0x41, 0x36, 0x08, 0x00, // }
 0x02, 0x01, 0x02, 0x04, 0x02};// ~
 // Purpose:       Write text on a graphic LCD
 // Inputs:        (x,y) - The upper left coordinate of the first letter
 //                textptr - A pointer to an array of text to display
 //                size - The size of the text: 1 = 5x7, 2 = 10x14, ...
 void glcd_text57(int x, int y, char* textptr, int size, int1 color)
 const BYTE bytes_per_char=5;
 int i, j, k, l, m;                     // Loop counters
 BYTE pixelData[bytes_per_char];                     // Stores character data
 for(i=0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
 if(textptr[i] < 'S') //falta un = // Checks if the letter is in the first or second array
 memcpy(pixelData, TEXT[textptr[i]-' '], bytes_per_char);
 else if(textptr[i] <= '~') // Check if the letter is in the second array
 memcpy(pixelData, TEXT2[textptr[i]-'S'], bytes_per_char);
 memcpy(pixelData, TEXT[0], bytes_per_char);   // Default to space
 if(x+5*size >= GLCD_COL)          // Performs character wrapping
 x = 0;                           // Set x at far left position
 y += 7*size + 1;                 // Set y at next position down
 for(j=0; j<bytes_per_char; ++j, x+=size)         // 5 bytes per character
 for(k=0; k<7*size; ++k)          // Loop through the vertical pixels
 if(bit_test(pixelData[j], k)) // Check if the pixel should be set
 for(l=0; l<size; ++l)      // The next two loops change the
 {                          // character's size
 for(m=0; m<size; ++m)
 glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
 //// Purpose:       Fill the LCD screen with the passed in color.
 ////                Works much faster than drawing a rectangle to fill the screen
 //// Inputs:        ON - turn all the pixels on
 ////                OFF - turn all the pixels off
 //// Dependencies:  glcd_WriteByte()
 //void glcd_fillScreen(int1 color)
 //  int line_num, column;
 //  // Loop through the lines
 //  //fprintf(DEBUG,"Fill screen with %d\n\r",color);
 //  for(line_num = 0; line_num < 8; ++line_num)
 //    glcd_WriteByte(0, 0xB0+line_num);
 //    glcd_WriteByte(0, 0x10);
 //    glcd_WriteByte(0, 0x00);
 //    // Loop through the horline_numzontal sectline_numons
 //    for(column = 0; column < 128; ++column)
 //      glcd_WriteByte(1, 0xFF*color);  // Turn all pixels on or off
 //// Purpose:       Selects a font and sets up areas
 //// Ouputs:        A bit that is applied to the FS(font select) pin
 //void glcd_FontSelect(int1 fs) {
 //   LCD.fs=fs;
 //   switch (fs)
 //     case 1:
 //            glcd_WriteCmd2(TextHome,0x40);
 //            glcd_WriteCmd2(AreaSet_T,0x41);
 //            glcd_WriteCmd2(GraphicsHome,0x42);
 //            glcd_WriteCmd2(AreaSet_G,0x43);
 //            break;
 //     default:
 //     glcd_WriteCmd1(c-0x20,0xc0);
 //     break;
 ////////////////////////////////JUNK YARD ////////////////////////////////////
 ////// Purpose:       Reads status of LCD
 ////// Ouputs:        Returns 1=busy 0=not busy
 ////int1 glcd_notbusy()
 ////  BYTE data,count=0;             // Stores the data read from the LCD
 ////  do
 ////    set_tris_lcd(0xFF)  ;  // Port D inputs
 ////    LCD.cd=1;     //Instruction
 ////    LCD.r_bar=0;  //Read
 ////    LCD.w_bar=1;  //not write
 ////    data=LCD.data;
 ////    LCD.r_bar=1;  //Release Read
 ////    set_tris_lcd(0xFF);//Port D tristate
 ////    ++count;
 //////    //fprintf(DEBUG,"count=%U\r",count);
 ////    if (count>3){return(0);}
 ////  }while (!bit_test(data,1) || !bit_test (data,0) );//til bit0 and bit1==1
 ////    return (1);   //Return status
 | You cannot post new topics in this forum You cannot reply to topics in this forum
