so confused about timer0 with 16f877
saroch
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Oct 12, 2004 3:54 am     Reply with quote
hi,
i'm a newbie with PIC16f877 and now i'm so confused about using timer0
here is my code
#include <16F877.h>
#define TxD PIN_C6
#define RxD PIN_C7
#define CLOCK_SP 20000000
#fuses HS
#fuses NOLVP, NOWDT
#fuses NOPROTECT
#use delay (clock=CLOCK_SP)
#use rs232 (baud=9600, xmit=TxD, rcv=RxD)
#define use_portb_lcd
#include <lcd.c>
void main ()
   long time;
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_2);
   printf(lcd_putc, "\f"); lcd_gotoxy(1,1);
   printf(lcd_putc, "DIV_2");
   set_timer0(0);
   delay_cycles(18);
   time = get_timer0();
   printf(lcd_putc, "\n");
   printf(lcd_putc, "Time : %lu us", time);
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_4);
   printf(lcd_putc, "DIV_4");
   set_timer0(0);
   delay_cycles(18);
and the output is
DIV_2
Time : 8 us
DIV_4
Time : 4 us
please tell me what this output comes from??
thank you in advance
saroch
asmallri
PostPosted: Tue Oct 12, 2004 5:23 am     Reply with quote
A slight problem with logic.
The timer is counting up from zero. Divide by 4 means that it takes twice as many input clocks as divide by two to get the same count. Your sample program line
could more accurately be represented as
timer_count = get_timer0();
therefore the count value for divide by 2 should be double the count value for divide by 4 giving you the result you observed
PostPosted: Tue Oct 12, 2004 5:47 am     Reply with quote
You seem to be accessing te timer fine. All the timer is, is a 'counter'. It counts at a rate, dependant on the speed of the clock fed into it. The clock comes from the main incoming crystal (RTCC_INTERNAL), divided by four, then divided by the prescaler.
So in your first case, the clock is actually running at 20000000/(4*2) = 2500000Hz.
Now you pause for 18 'cycles'. Each instruction 'cycle' on the PIC, is four counts of the main clock. So the pause is for (18*4)/20000000 second = 36uSec. In 36uSec, the 2.5MHz clock will have counted 0.0000036/(1/2500000) times. This potentially gives 9 as the 'answer'. However you then have to consider the actual operation deeper in the chip. Because values are transferred from the internal 'W' reg, into other registers, at the end on the instruction cycle, but are read 'in', at the start of the cycle, you 'lose' one count edge, on the instruction after the transfer. The same happens in the other case. Hence you see a count of 8 and 4.
saroch
PostPosted: Tue Oct 12, 2004 8:24 am     Reply with quote
just nearly CLEAR !!
but
what about
 set_timer0(0);
is this line for tell us what ??
thank you very much Very Happy Smile
rnielsen
PostPosted: Tue Oct 12, 2004 9:28 am     Reply with quote
The command: set_timer0(0) simply sets timer0's counter to zero(0). If you had entered set_timer0(250) it would have set the counter to 250. In either case, the timer will count up to 255 and then roll over to zero again, at which time the interrupt will occur. This can be a bit tricky though because it takes a few clock cycles to complete this command so your 'count' could be slightly off from what you might think it to be.
Ronald
saroch
PostPosted: Tue Oct 12, 2004 10:06 am     Reply with quote
i understand set_timer0 like this
set_timer0(value)
where value = 256-(Tdelay/prescaler)*(fosc/4)
so i'm confused why using set_timer0(0) in that code
what does set_timer0(0) means in my understanding
PostPosted: Tue Oct 12, 2004 10:51 am     Reply with quote
set_timer0(value)
The counter, just counts. The value in Timer0, is incremented everytime the incoming 'clock' (including prescalers etc.), cycles.
If you set timer0 to 10, then the count will go 10,11,12.....255,0 etc..
The 'Tdelay' useage, comes from the fact that there is an extra circuit associated with the timer, which sets the timer0 interrupt flag (and generates an interrupt if this is enabled), when the timer increments from 255 to 0 (since it is an '8 bit' counter, it can only get to 255).
Hence if you want to delay for 50 'cycles' of the clock feeding the timer, you would want to set the timer to 216 (the 'wrap' is when you go from 255 to 0, which corresponds to a count of '256'). The formula you give, is how to calculate the value needed.
The code you posted, does not use the 'delay' ability of the counter, but just it's ability to count. To make the count start at '0', te counter is set to this value before starting.
I suggest you go to the Microchip website, and get document number 70059b, which is the manual for the timers on the chips. Remember that everything that applies to 16bit timers, also applies to the 8bit units, just with the 'wrap', taking place at 255->0, instead of at 65535->0.
saroch
PostPosted: Tue Oct 12, 2004 10:59 am     Reply with quote
thanks for the help
