Array concatenation
alexz
Array concatenation
PostPosted: Wed Oct 06, 2004 4:14 am     Reply with quote
Is there any way to concatenate for example 2 bytes array to 1 variable?
Say:
BYTE array[2];
int Var; //2 bytes
I want to write the whatever in the array into the Var.
Thank you
Alex
asmallri
PostPosted: Wed Oct 06, 2004 5:12 am     Reply with quote
Use a union
union my_union {
     int 16   var;
     int8 array[2];
     } my_union_variable;
alexz
PostPosted: Wed Oct 06, 2004 5:17 am     Reply with quote
int16 and int8
are not recognized for some reason
and also cannot make a variable more than 8 bits.
it does recognize 'long', but the variable is still 8 bits
Alex
asmallri
PostPosted: Wed Oct 06, 2004 5:29 am     Reply with quote
alexz wrote:
int16 and int8
ok - so int8 and int16 are not defined.
how do you know the long variable is only 8 bits? Are you sure you aren't running into a typecast problem?
alexz
PostPosted: Wed Oct 06, 2004 5:32 am     Reply with quote
I am not sure.
I just cant find a way to define a 16bit variable :(
I already tryed #type int16=16
Alex
asmallri
PostPosted: Wed Oct 06, 2004 5:52 am     Reply with quote
A long is a 16 bit variable
alexz
PostPosted: Wed Oct 06, 2004 5:54 am     Reply with quote
I know that.
But in the watch window it is still 8
Alex
Mark
PostPosted: Wed Oct 06, 2004 7:59 am     Reply with quote
Your version must be old as dirt!
typedef uint8_t int;
typedef int18_t signed int;
typedef uint16_t long;
typedef int16_t signed long;
treitmey
PostPosted: Wed Oct 06, 2004 8:53 am     Reply with quote
What version of the compiler did you say you were using?
We are trying to help,.. but the assignment is easy. and we don't understand the problem?
int8 array[2];
int16 Var;
Var=make16(array[0],array[1]); //whatever order you want
I think the problem is the compiler version or the watch window.
(ps i think its the watch window)
alexz
PostPosted: Wed Oct 06, 2004 8:55 am     Reply with quote
version CCS 3.207
Alex
treitmey
PostPosted: Wed Oct 06, 2004 9:24 am     Reply with quote
Here is a little test progrm. in watch window put in addr,h tmp,h
the ",h" displays it in hex digits,.. 4 bits per 1 hex digit
btw. I used 3.212 compiler
#include <16F877.h>
#device *=16
#CASE
#use delay(clock=16000000)
#define VER_MAJOR 1
#define VER_MINOR 00
#define INTS_PER_MIN_TMR2 3660
#zero_ram
#use rs232(baud=57600,xmit=PIN_A2,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,stream=FA403)  //This is talking to FA403 wireless
  int8 tmp[2];
  int16 addr;
  tmp[0]=1;
  tmp[1]=2;
   addr=make16(tmp[0],tmp[1]);
