alexbilo
Joined: 01 Jun 2004 Posts: 39 Location: Trois-Rivières
| i2c : slave misses data |
Posted: Thu Sep 30, 2004 4:03 pm |
I'm working on a pic to pic i2c communication link.
Master : PIC18F452 (running at 40MHz)
Slave : PIC18F452 (running at 10MHz)
The master executes a comm. routine which sends many bytes to the slave.
The slaves reads the bytes in an interruption routine.
I found out that if I let the master running top speed, the slave doesn't even see the i2c events (doesn't enter in the interruption service routine). If I send the i2c events (start, adress, data1, data2, etc.) one at a time using the ICD2 debugger with breakpoints, it works perfectly (the slave enters in the int. routine and receives valid data).
Any idea about what can cause this?
Could it be some hardware issue, as the value of the pull-up resistor (anyway what could be a good value?)?
Thanks in advance for your advices... _________________ Alex |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Thu Sep 30, 2004 5:36 pm |
| Depending on the I2C bus speed, if you are using the standard interrupt handler you may have too much latency because of the context switching. If this is the problem then investigate using high priority interrupts and assembler with a RETFIE 1 |
alexbilo
Posted: Fri Oct 01, 2004 9:19 am |
| Quote: | | If this is the problem then investigate using high priority interrupts and assembler with a RETFIE 1 |
I tried the fast interrupts to be sure, because it's possible that the lenghty ISR I use become a problem. However, even if the ISR takes too long to execute, it should at least enter in it when it first receives the adress. This isn't happening, as if the hardware doesn't even get triggered by the i2c events.
Here's the flow of events :
Start condition (no interrupt generated)
Adress sent, write mode (interrupt should be generated)
Data1 sent (another interrupt)
Data 2 sent, etc.
If, in the master, I executes these commands one at a time (breakpoint between) each, the slave reacts properly. If a set a breakpoint only before data2 is sent, per example, nothing happens in the slave (doesn't even enter in the ISR).
Thanks again, _________________ Alex |
Mark
Posted: Fri Oct 01, 2004 11:10 am |
| You would probably get more help if you posted a small test program that demonstrates the problem. Remember to use the code button! |
alexbilo
Posted: Fri Oct 01, 2004 11:52 am |
Since the code is a little bit complicated, I choosed to explain it in words instead... But since you ask for it
Note that I use my own functions, not the CCS' functions.
Master code :
i2c_start();
ack=i2c_send(WRITE);
ack+=i2c_send(data=make8(tension,1));
temp^=data;
ack+=i2c_send(data=make8(tension,0));
temp^=data;
ack+=i2c_send(data=make8(courant,1));
temp^=data;
ack+=i2c_send(data=make8(courant,0));
temp^=data;
ack+=i2c_send(data=make8(temperature,1));
temp^=data;
ack+=i2c_send(data=make8(temperature,0));
temp^=data;
ack+=i2c_send(data=control_status);
temp^=data;
ack+=i2c_send(temp);
// Réception des informations
i2c_repstart();
ack=i2c_send(READ);
// Lire l'indicateur de transmission
temp=i2c_recv(0);
Slave ISR :
/* ssp_isr()
Événement du module i2c
Arguments : aucun
Valeur retournée : aucune
#INT_SSP FAST
void ssp_isr(void) {
static int index;
int temp, i, buffer[20];
int W_save, STATUS_save, FSR0L_save, FSR0H_save;
int scratch_save[5];
// Sauvegarder l'état des registres
W_save=WREG;
STATUS_save=STATUS;
FSR0L_save=FSR0L;
FSR0H_save=FSR0H;
scratch_save[0]=*0x1;
scratch_save[1]=*0x3;
no_step++;
// Le contrôleur envoie des données
if(!RW) {
// Réception de l'adresse et remise à zéro des variables
if(!DA) {
temp=i2c_recv();
last=temp;
index=0;
//no_step=0;
if(!com_status) com_status=SYNCH;
// Réception des données du contrôleur
else {
// Lire la donnée
if(index<NB_DATA) {
buffer[index]=i2c_recv();
last=buffer[index];
// Incrémenter l'index
index++;
//no_step++; // POUR DÉBOGAGE
// Fin de la réception
if(index==NB_DATA) {
// Calcul du checksum
temp=0;
for(i=0;i<(NB_DATA-1);i++) {
temp^=buffer[i];
// Si CRC valide, enregistrer les données
if(temp==buffer[(NB_DATA-1)]) {
com_status=OK;
tension_brute=make16(buffer[0], buffer[1]);
courant_brut=make16(buffer[2], buffer[3]);
temperature_brute=make16(buffer[4], buffer[5]);
control_status=buffer[6];
fin_com=1;
// Sinon erreur de communication
else com_status=NOCOM;
// Envoi des données au contrôleur
else if(RW) {
// Si nouvelles données et aucun verrou
if(!verrou_trans && nouv_trans) {
// Envoi du caractère de confirmation de transmission
i2c_send('D');
// Envoi des informations
i2c_send(consigne_msb);
i2c_send(consigne_lsb);
i2c_send(courant_max_msb);
i2c_send(courant_max_lsb);
i2c_send(temp_max_msb);
i2c_send(temp_max_lsb);
i2c_send(tension_max_msb);
i2c_send(tension_max_lsb);
i2c_send(mode);
i2c_send(commande);
// Sinon
else {
// Envoi du caractère d'inhibition de transmission
i2c_send('N');
DEL_verte();
// Fin de transmission
i2c_send('\n');
DEL_off();
// Restaurer l'état des registres
*0x3=scratch_save[1];
*0x1=scratch_save[0];
FSR0H=FSR0H_save;
FSR0L=FSR0L_save;
STATUS=STATUS_save;
WREG=W_save;
In fact, all this works when I execute the master code step by step, but doesn't work if I let it run at full speed (40MHz xtal for the master and 10MHz xtal for the slave).
Let me know if you want more details...
Thanks, _________________ Alex |
alexbilo
Posted: Fri Oct 01, 2004 12:43 pm |
I got it to work by adding delays between each i2c commands. Seems that the slave's ISR wasn't fast enough finaly.
Thanks to all... _________________ Alex |
rnielsen
Posted: Fri Oct 01, 2004 5:56 pm |
Remember that the SCL line should be held low, by the Slave, indicating that it's not done doing it's thing. The Master will monitor this line to know when it can start sending clock pulses again. Try setting the CKP bit (this might be in the SSPCON register) low before each piece of data to be sent and then setting it high, when you're done sending that data, to allow the Master to continue. I'm not sure if the built in functions "i2c_send()" does this or not. If it will work the communications should be faster than waiting for all of the delays.
Ronald |
