Voice/sound recognition
Goto page 1, 2  Next
edi
PostPosted: Sun Sep 19, 2004 11:48 pm     Reply with quote
Any idea how to recognize specific sound or voice using PIC 16Fxxx device? Small circuit beside the PIC... is also possible.
(Need to recognize just one kind of sound/voice not simple frequency)
Edi
Haplo
PostPosted: Mon Sep 20, 2004 12:04 am     Reply with quote
What do you exactly mean by 'Recognize'?
Voice recognition
PostPosted: Mon Sep 20, 2004 12:43 am     Reply with quote
Get a microphone, hook it up to the PIC. Turn on the PIC. Speak into the mic.
DONE.
PostPosted: Mon Sep 20, 2004 1:07 am     Reply with quote
Microchip has a speech recognition library for their dsPIC chips.
But, it's not free, and it's not for small quantities. But at least
this answers your question of "is it possible ?"
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en020141
edi
PostPosted: Mon Sep 20, 2004 2:26 am     Reply with quote
I want to activate an alarm just if a specific sound heard. Not for any noise!
Of course a MIC is needed and amplifier.
mkent
PostPosted: Mon Sep 20, 2004 5:29 am     Reply with quote
Look up LM567; it may be what you want. Mick
yerpa
PostPosted: Mon Sep 20, 2004 7:57 am     Reply with quote
You have a lot of work ahead of you. Beyond simple filtering and amplitude detection, you won't have much of an intelligent conversation with a PIC. Maybe two commands at best. You've got to be more specific about what your "specific sound" is. DTMF detection is possible and you can search Microchips app notes for that. Good luck.
John Morley
PostPosted: Mon Sep 20, 2004 8:24 am     Reply with quote
There is an IC available that can "learn" a small number of spoken works, and has a microcontroller interface. I'm at the office now, and the info on this is at home, but I will post a followup later on. If I remember correctly, I got it at Jameco or Digikey.
John Morley
John Morley
PostPosted: Tue Sep 21, 2004 5:50 am     Reply with quote
The kit I was referring to is made by Sensory, and is called the VoiceDirect Speech Recognition Kit. You can find their website here: www.sensoryinc.com
Good Luck!
John Morley
Trampas
PostPosted: Tue Sep 21, 2004 7:10 am     Reply with quote
One trick you can do is connect a mic up to an amp, then run the output through 3 or 4 band pass filters with high gain amplifiers. Then run these band pass outputs to RB or external interrupt pins.
Then when that frequency of signal comes in it triggers interrupt which can be used for limited speech recongition.
Trampas
SherpaDoug
PostPosted: Tue Sep 21, 2004 7:11 am     Reply with quote
I remember reading an article quite a few years ago about someone who could control their robot by whistling. I think they sent a 4 bit command by first whistling a reference tone, then whistling the bits either higher or lower in frequency than the reference. They found they couldn't reliably whistle any specific tone, but they could go above and below a reference. Each command quickly becomes a little 5 note tune that is easy to memorize.
It was probably done in assembly for a 6502 or an 8085 chip. Maybe using one of those dog commanding whistles, or a harmonica might make it easier, at least to start.
PostPosted: Tue Sep 21, 2004 7:21 am     Reply with quote
I think I remember the article about whistling for robot and remote control. Reliability was an issue. Its not easy to whistle a Manchester-encoded version of "When the saints go marching in" in real time.
SherpaDoug
PostPosted: Tue Sep 21, 2004 9:41 am     Reply with quote
It depends on how many commands are needed. If you can get away with four commands that is only two bits plus one as checksum for four tones total. Of course certain codes need to be avoided so you don't get slapped in mixed company.
Another option might be whistling Morse code. There must be plenty of Morse decoding code for PICs out there.
PostPosted: Tue Sep 21, 2004 10:06 am     Reply with quote
Not for any noise! Of course a MIC is needed and amplifier.
I think you're trying to do something like this product. It has a little
microphone, and it responds to certain tones, and then sounds an alarm.
http://www.keyringer.com/
Sergio
PostPosted: Tue Sep 21, 2004 9:05 pm     Reply with quote
John,
I was also looking at the Sensory chip for an upcoming project. Have you played around with it yet?
Sergio
Goto page 1, 2  Next
Page 1 of 2
