crni2004
| Exception must point to constant |
Posted: Tue Sep 14, 2004 9:08 am |
HI !
Im totaly new to pic programming. I wrote small program im CCS C and when i went on compile i get error : Expression must evulate to constant.
OK. I went into help and there was some example but not the solution.
The compiler is pointing to pic.h file and i can't find pic12xxx.h files in my
ccs dir. I dont now how to solve this......
If someone has some solution please write down.
Thanx in advance |
Mark
Posted: Tue Sep 14, 2004 10:21 am |
You are posting in the wrong forum!
It might be helpful to actually post the code that is giving you a problem. |
crni2004
| Example and wrong forum |
Posted: Wed Sep 15, 2004 1:33 am |
Ok. Sorry for the forum... Where can i send such questions ?
2.) This is the test code from the microchip debounce.c that i want to test on pic12f675. The orginal hex file packed in example is working fine and i can burn him on chip but now i want to compile this example thru CCS C.
#include "Debounce.h"
Init();
if (!BUTTON) // sense BUTTON closure
ToggleLED();
Debounce();
void Init(void)
ANSEL = 0b00000000; // configure A/D inputs as digital I/O
TRISIO = D0_1Tris; // GPIO 3,4 outputs, GPIO 0,1,2,5,6,7 inputs
OPTION = 0b11010000; // Timer0 internal clock, 1:2 prescale
GPIO = D0On;
CMCON = 0b00000000; // configure comparator inputs as digital I/O
void ToggleLED(void)
if(LEDOn)
GPIO = D0Off;
GPIO = D0On;
void Debonce(void)
unsigned char COUNT = TenMS;
TMR0 = 0;
for(;;)
if(!BUTTON)
// reset 10 millisecond COUNT if BUTTON pushed
COUNT = TenMS;
// decrement timer COUNT for every Timer0 overflow
if(T0IF)
// reset flag
T0IF = 0;
if(--COUNT == 0) break;
Posted: Wed Sep 15, 2004 11:17 am |
"and i can burn him" ??!! Programs and chips are women :-)
However, forget the "pic" preamble in file names. Just find "12F675.H" in the "Devices" directory. |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Wed Sep 15, 2004 5:04 pm |
| Anonymous wrote: | | "and i can burn him" ??!! Programs and chips are women :-) |
So you burn women?
Anyway, at which line do you get that error?
Always post your code using the 'Code' buttons. We may need to look at the debounce.h too. |
Mark
Posted: Wed Sep 15, 2004 6:27 pm |
| My guess is that none of those registers are declared. The device is not specified. No #fuse statement. Debounce is mispelled ;) Take a look at some of the example programs to see how to set up the C file. |
Posted: Thu Sep 16, 2004 2:08 am |
Ali,
programs and chips are women because of the phrase you often say when the program/chip not works as well as you intended ;-) |
Posted: Thu Sep 16, 2004 2:57 am |
So you burn women
** ;-)) / what a conclusion :-)
OK. I can't start the debounce.c file so i went to another file called EX-8pin.c ( from the CCS example dir ). This file is using 12C508 header file. I'v started compile and all is working fine.
So, ok if i can't use microchip's examples i can use CCS eg.
Now, i'v changed the #include 12C508 to #include 12F675 and a get error "Unknown device type". The 12F675.h file was automaticly opened at line #device PIC12F675....
1.)
I don't get it where is the problem. Basicly now i got the same stuff like in debounce.c file accept this one is i ccs c. I have selected the device from the tools / device selector
2.)
Im using the pickit flash starter kit for 8pins Microchip MCU's and JDM programmer for the rest.
What should i add accept :
"C:\Program Files\Microchip\PICkit\PICkit.exe"%H %D into
"device programmer" part so i can burn this compiled (i hope in future, working program ) to PIC12F675 ?
Stay cool |
Haplo
Posted: Thu Sep 16, 2004 3:41 am |
| Anonymous wrote: | Ali,
What?! You mean you shout "That's enough shopping for today!!" at your circuit?!
Anyway I think I have figured out your problem. You see, 12C508 is a 12bit device and PCB is used for compiling its code. But You need to use PCM for 12F675. I think you are invoking the PCB compiler by mistake, and hence the error message.
Are you using PCW? If so, you can choose the compiler type from the drop-down box in the toolbar. Choose the compiler for 14-bit parts.
Look at this page for more information, B means PCB and M means PCM:
http://www.ccsinfo.com/devices.shtml |
