Can I use parameters in kbhit() function?
curtis
PostPosted: Mon Sep 13, 2004 1:38 pm     Reply with quote
Hi all,
I have two STREAMS in my project with 18F252, one is by hardware and the other is by software implemented with fgetc() and fputc().
#use rs232 (..., stream = output232) // hardware
#use rs485 (..., stream = output485) // software
In my code I'm using # int_rda.
kbhit(output 232) ; Can I use it? I mean, Can I use a parameter in this function?
This worked well in my code with baudrate 19200.
But It couldn't work well when I changed the baud rate.
thanks
Vitor
SherpaDoug
PostPosted: Mon Sep 13, 2004 1:51 pm     Reply with quote
Yes it works. That is how you tell kbhit() what stream to look at.
dyeatman
PostPosted: Mon Sep 13, 2004 1:53 pm     Reply with quote
other than the stream parameter what other parameter do you want to use. What do you mean by "it didn't work when I changed the baud rate". Was it changed in the USE statement or on the fly?
PostPosted: Mon Sep 13, 2004 4:54 pm     Reply with quote
I used the parameter in my code even the CCS manual don't mention anything about that.
I tested it with 19200 bauderate in the USE statement and it worked well, but when I changed the baudrate in the USE statement it didn't worked.
dyeatman
PostPosted: Mon Sep 13, 2004 5:00 pm     Reply with quote
What version of the manual are you using? It is documented in the July 2003 version in multiple places (USE RS232, Getc(),Putc(),Fputc() etc).
Post the code showing the initial USE RS232 setup and where you are changing the baudrate so we can see what you are doing.
Mark
PostPosted: Mon Sep 13, 2004 9:34 pm     Reply with quote
You should post a test of the problem. Are you using the kbhit() inside the interrupt?
curtis
PostPosted: Tue Sep 14, 2004 6:42 am     Reply with quote
My manual is version July 2003, but in the page 108 the function KBHIT() is written "none" for parameters.
Follows my code:
#int_RDA
void read_RS232(void)
int cont232 = 0;
long timeout = 0;
restart_wdt();
disable_interrupts(INT_RDA);
disable_interrupts(INT_ext);
// Get 8 bytes
while ( cont232 < 8 )
// Wait maximum +/- 5000 us
while ( (!kbhit(OUTPUT232)) && (++timeout<500)){
delay_us(10);
restart_wdt();
// Get byte if available
if (kbhit(OUTPUT232)) {
RX232[cont232++] = fgetc(OUTPUT232);
// Case no, timeout
size232 = 0;
received232 = FALSE;
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
enable_interrupts(global);
restart_wdt();
return;
// If no TIMEOUT
size232 = cont232;
RX232[cont232] = '\0';
enable_interrupts(INT_ext);
received232 = TRUE;
restart_wdt();
Usart Configuration:
void adjustBaud(void) {
long value;
value = read_eeprom(92);
#USE RS232 (BAUD=19200, XMIT=TX2, RCV=RX2, parity=n, bits=8, stream=OUTPUT485)
#USE RS232 (BAUD=19200, XMIT=PIN_C6, RCV=PIN_C7, parity=n, bits=8, stream=OUTPUT232)
switch(value) {
case 1:
set_uart_speed(9600, OUTPUT232);
case 2:
set_uart_speed(4800, OUTPUT232);
Haplo
PostPosted: Tue Sep 14, 2004 5:36 pm     Reply with quote
Always read the ReadMe.TXT file that installs in the compiler directory. It contains the latest updates to the manual.
By the way, you don't need to disable/enable interrupts in the ISR. It is done automatically.
Always use the 'Code' buttons when posting your code. It makes it more readable.
Looking at your while loop:
delay_us(10);
restart_wdt();
// Case no, timeout
size232 = 0;
restart_wdt();
return;
You are not resetting the timeout variable for each iteration. It will eventually reach the maximum limit and cause the code to jump out of the loop prematurely.
