Void() in a structure
Davng
PostPosted: Fri Sep 10, 2004 8:48 am     Reply with quote
Why I can't use this piece of code?
typedef const struct _rom_desc_tsk
   unsigned char prioinit;
   unsigned int stackAddr;
   void   *nParameters;         //  Unknown type!
   unsigned char futur_use;
   unsigned char id_tch;
   unsigned int  ctx_tch;
} rom_desc_tsk;
The compiler don't let me use a void pointer inside the structure! The error that show me is: "unknown type"
thnx in advance
davng
Re: Void() in a structure
PostPosted: Fri Sep 10, 2004 10:21 am     Reply with quote
} rom_desc_tsk;
thnx in advance
davng
I'm not suprised.
'void' has two different meanings. The first is effectively a 'null' defintion for data types (as in a function that returns nothing). The second form, _was an extension to C, that is part of the ANSI definitions_, where it replaces 'char *', as the generic data pointer. CCS C, _is not ANSI C_. It retains the original K&R defintions, where char * is the generic pointer.
Some 'ANSI like' forms are allowed in places, but most are dubious, and should be used with care...
Basically you are trying to use an ANSI C structure, in a C that does not relibly support this.
Change it to char *, and cast it to the type that is actually required, when accessed.
