kbhit()
arif
kbhit()
PostPosted: Wed Sep 08, 2004 7:10 am     Reply with quote
hi all,
i use two rs232 ports (16F877A)
one is hardware and the other is software.
i want to test kbhit() for incoming serial data.
The problem is how can i understand hardware or software data received by using kbhit().
Can i use kbhit like this:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, enable=pin_b0, stream=host)////harware
#use rs232(baud=1000, xmit=PIN_d0, rcv=PIN_d1,stream=loop)///software
kbhit(loop)///software serial data test?
kbhit(host)///hardware serial data test?
i tryed these but my code din't work.
Please help...
Re: kbhit()
PostPosted: Wed Sep 08, 2004 8:04 am     Reply with quote
arif wrote:
hi all,
Please help...
It won't.
The software port, has no ability to receive a character, unless the code is actually sitting 'waiting' for it. If you want to have the code actually detect a character when it arrives, it may be possible, by using one of the external interrupt pins, and triggering the receive code, wen the edge is seen on the srial stream.
The kbhit function, is dependant on there being a hardware register to actually receive and 'hold' a character for you.
Mark
PostPosted: Wed Sep 08, 2004 8:17 am     Reply with quote
KBHIT()
Syntax: value = kbhit()
Parameters: None
Returns: 0 (or FALSE) if getc() will need to wait for a character to
come in, 1 (or TRUE) if a character is ready for getc()
Function: If the RS232 is under software control this function
returns TRUE if the start bit of a character is being sent
on the RS232 RCV pin. If the RS232 is hardware this
function returns TRUE is a character has been received
and is waiting in the hardware buffer for getc() to read.
This function may be used to poll for data without
stopping and waiting for the data to appear. Note that in
the case of software RS232 this function should be
called at least 10 times the bit rate to ensure incoming
data is not lost.
Availability: All devices.
SherpaDoug
Re: kbhit()
PostPosted: Wed Sep 08, 2004 8:23 am     Reply with quote
Please help...
This should work fine as long as you are calling the kbhit() for the software stream at least 5 or 10 times per serial bit rate. Kbhit() will detect the beginning of the Start bit and then you can call getc() to get the character. Getc() won't return untill the beginning of the Stop bit.
Mark
PostPosted: Wed Sep 08, 2004 8:25 am     Reply with quote
The problem is that he wants to use it for both (I believe). There is no way to tell the compiler which port to use. I believe that it will use the port of the last encountered #use rs232
arif
PostPosted: Wed Sep 08, 2004 8:44 am     Reply with quote
Thanks everybody...
SherpaDoug
PostPosted: Wed Sep 08, 2004 9:11 am     Reply with quote
kbhit(loop) checks the loop stream.
kbhit(host) checks the host stream.
Streams are not real well documented but if you look on this bbs the info it there.
drh
PostPosted: Wed Sep 08, 2004 1:26 pm     Reply with quote
The kbhit(STREAM) function tests the RCV pin asigned to that stream. If it detects a low, it returns TRUE, even if that low was not the first bit of a character. So, your program needs to call kbhit() often enough to catch the start bit. Once you call getch(STREAM), it will "bit bang" the character in until complete. If your code "missed" the start bit, you will get garbage and or hang in the getch() function.
David
SherpaDoug
PostPosted: Wed Sep 08, 2004 1:45 pm     Reply with quote
The only way getch() should hang is if the low condition detected by kbhit() is gone by the time getch() is called. Even if kbhit() catches some low data bit, getch() should come back with some byte and perhapse a framing error if it didn't find a stop bit where it expects one. Getch() only hangs if it never sees a low to use as a Start bit.
Arif
PostPosted: Thu Sep 09, 2004 12:31 am     Reply with quote
Thanks everbody,
Here is my test program. İt loops 3 times only (i understand by leds) and then pic locks (i think so).
What is wrong with my program..?
#include <16f877A.h>
#fuses XT,NOPROTECT,PUT,NOLVP,nowdt,BROWNOUT
//#include <a2465.C>
#byte   PORTA               = 0x05
#byte   PORTB               = 0x06
#byte   PORTC               = 0x07
#byte   PORTD               = 0x08
#byte   PORTE               = 0x09
#define  host_led    pin_b7
#define  loop_led    pin_c3
char ch1=0;
char data;
int8 adres=0;
void init()
    output_high(host_led);
    output_high(loop_led);
    output_low(host_led);
    output_low(loop_led);
void DelayByte()
   delay_ms(10);
int8 SensorTara(int8 adr)
   static int ret,adresler;
   int retry=0;
   char ch;
   adresler=adr+0x40;
   fputc(adresler,loop);
   retry=0;
   ret=255;
   delay_ms(10);
   while ((!kbhit(loop)) && (retry < 200))
      restart_wdt();
      delay_us(300);
      retry++;
   if (Retry < 200 ) ret=fgetc(loop);
   else fputc('?',loop);
   output_LOW(loop_led);
   DelayByte();
   DelayByte();
   DelayByte();
   if (kbhit()) ch=fgetc(loop);
   if ((ret >='0') && (ret <='9')) return ret;
   if (ret ==':') return ret;
   ret=255;
   return ret;
   init();
   while (1)
      adres='X';
      if(!input(pin_a0)) adres='A';
      if(!input(pin_a1)) adres='B';
      if(!input(pin_a2)) adres='C';
      if(!input(pin_a3)) adres='D';
      if(adres=='X')
         disable_interrupts(int_rda);
         disable_interrupts(global);
         ch1=sensortara(1);                        ///will answer by sending '0'
         if((ch1>='0') && (ch1 <='9')) output_high(loop_led);
         delay_ms(10);
         delay_ms(40);
         enable_interrupts(int_rda);
         enable_interrupts(global);
      delay_ms(700);
#int_rda
receive()
   data=fgetc(host);                       ///receives every message from host
   if(data==adres)                         ///test address
      DELAY_MS(5);
      fputc(1,host);                          ///send answer to host
      fgetc(host);                            ///hardware buffer empty
PostPosted: Thu Sep 09, 2004 2:06 am     Reply with quote
I'd suspect you are overflowing the UART input buffer.
When a character is being received on the hardware UART, you are going to the interrupt routine, which then waits for 5mSsec, sends a character, and waits for another character to come back. If there is not a 'reply' character, the code will hang waiting here, or if there is incoming data during the 'wait' (remember a character takes only just under 1mSec at 9600bps), the UART will have overflowed, and the code will again hang.
General rule, avoid delays, waiting for characters, or sending characters inside the interrupt handler. Look at the ex_sisr.c example, on how to buffer incoming data. Then write your main loop, to just monitor the buffer, flash LEDs, and send replies as required.
Also as a general comment, save time, and don't fiddle with the interrupt settings on every loop. If you have enabled the interrupts you require, just toggle the 'global' setting, to turn them all on/off. hence you only need the one instruction to enable/disable everything. Again though, if you are using an interrupt driven system, keep the times when interrupts are disabled, _short_. As it currently stands, the interrupts are turned off for over 40mSec in the main loop, is 'X' is seen, and again the UART will have overflowed, if characters have arrived in this time...
Arif
PostPosted: Thu Sep 09, 2004 2:28 am     Reply with quote
Thanks a lot
i will try it.
