coconico
| search string in string |
Posted: Tue Sep 07, 2004 6:22 am |
Has any one a function that it search a string in an other string?
Thank you for helpping! |
Mark
Posted: Tue Sep 07, 2004 7:09 am |
| Well how about the standard C function of strstr()? |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Tue Sep 07, 2004 11:15 pm |
As Mark pointed out, there is a standard C fucntion for this purpose called strstr(). In CCS, the code for strstr() is in the file STRING.H located in the \Drivers directory. Open it up and take a look at the source code. You can see:
| Quote: |
/* standard template:
char *strstr(const char *s1, const char *s2);
Locates first occurence of character sequence s2 in s1;
returns 0 if s2 is empty string
Uncomment #define FASTER_BUT_MORE_ROM at the top of the
file to use the faster algorithm */ |
Defining FASTER_BUT_MORE_ROM is indeed much faster especially if you need to work on big strings, but it results in a bigger code.
However, I remember having problems with the CCS strstr and writing my own. Still, the CCS code is a good starting point. |
coconico
Posted: Wed Sep 08, 2004 12:58 am |
Thank you very much. I don't saw this function.
Thank you for your help. |
