Cant Figure Out Odd Problem
Goto page Previous  1, 2
Alex
PostPosted: Thu Sep 23, 2004 8:18 am     Reply with quote
Regardless I have changed the UBYTE crc(UBYTE *data, UBYTE len)
to UBYTE crc(UBYTE data[], UBYTE len)
Alex
PostPosted: Thu Sep 23, 2004 9:02 am     Reply with quote
The solution is:
"DATA" is a key word
use different one
PostPosted: Thu Sep 23, 2004 12:08 pm     Reply with quote
'data' is not a keyword in the C language or in the CCS compiler.
See this MSDN article for a list of keywords.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vclang/html/_clang_C_Keywords.asp
Alex
PostPosted: Fri Sep 24, 2004 3:08 am     Reply with quote
may be.
but once I have changed the 'data' to a different name, it worked
Trampas
PostPosted: Fri Sep 24, 2004 5:53 am     Reply with quote
What version of the compiler are you using?
The reason I ask is CCS has been known to have problems with pointers. Actually this was the problem with ISO9001 orginal code, he used pointers on a version of compiler which had pointer bugs. I am guessing this is your problem as well as that the function defintion you changed to should compile to same code as the orginal one.
Trampas
Page 2 of 2
