printf a floating #
cxiong
printf a floating #
PostPosted: Thu Sep 02, 2004 2:56 pm     Reply with quote
I have the PIC Demo 2 Plus and I write the code to measure a ADC channel as voltage and display it on the LCD as floating. I only want to print 2 #s after the decimal point only. I know that in C, if you print 2 #s after the decimal point is to put a . between the % and f. But it does not work for CCS. Its there anything I missing?
Here is my code:
////                          EX_TC74.C                             ////
////                          I2C serial concept                     ////
////  This program uses the TC74 TO-220-5 to                     ////
////  read the temperature for the sensor.                          ////
////               TC74 pin        Processor                          ////
////                  1            n/a   NC                           ////
////                  2            23   RC3      SDA                  ////
////                  3            n/a   gnd                          ////
////                  4            18   RC3       SCL                  ////
////                  5            n/a   VDD                           ////
#include <18f458.h>
#device ADC=10
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use i2c(Master,fast,sda=PIN_C4, scl=PIN_C3, FORCE_HW)
#include <lcdd.c>
main()
byte value,temp;
int16 bat_value;
float batt;
setup_adc_ports( RA0_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
     set_adc_channel( 0 );
      delay_us(25);
      bat_value = read_adc();
     batt = bat_value * (float) 0.00488;
      printf(lcd_putc,"\nBattery: %.2f V",batt);
      i2c_Start();                                          // Set a START condition I2C Bus
      i2c_Write(0b10011010);                                // Address and Write Flag
      i2c_Write(0x00);                                      // Temperature Register
      i2c_Write(0b10011011);                                // Address and Read Flag
      value = i2c_Read();                                   // Read Teperature
      i2c_stop();
     delay_ms(5);
     temp = value * 9/5 + 32;
     printf("Temp: %d Degree\n\r",temp);
     printf(lcd_putc,"\fValue: %d Degree",temp);
     if(value < 21)
         output_high(PIN_B0);
         output_low(PIN_B0);
         output_high(PIN_B1);
         output_low(PIN_B0);
The error message ( printf format % is invalid).
Please help.
dyeatman
Like Prego, its in there...
PostPosted: Thu Sep 02, 2004 3:15 pm     Reply with quote
Doesn't ANYONE read the manual any more??
Taken from page 125 for Printf():
The format takes the generic form %wt where w is optional and may be 1-9 to specify how many characters are to be outputted, or 01-09 to indicate leading zeros or 1.1 to 9.9 for floating point. t is the type and may be one of the following:
C Character
S String or character
U Unsigned int
etc...
cxiong
PostPosted: Fri Sep 03, 2004 7:25 am     Reply with quote
I just download the manual from CCS. It does cover the topic I ask for.
Thanks.
SherpaDoug
PostPosted: Fri Sep 03, 2004 7:58 am     Reply with quote
The CCS manual is fairly small and if you are going to do any serious work it is worth reading cover to cover. You will discover lots of things you never thought to ask for!
