How do I generate a checksum (16 or 32 bits). What's the
difference between checksum & crc?
StuH_CC
Joined: 07 May 2004 Posts: 16 Location: Shropshire, UK
Posted: Thu Sep 02, 2004 9:11 am
CCS have provided a driver to generate 8,16 and 32 bit CRCs - it's in the "Drivers" directory of your compiler installation, called CRC.C. There's also an example called EX_CRC.C in the "Examples" directory. Hope this helps.
Stuart.
dyeatman
CRC vs Checksum
Posted: Thu Sep 02, 2004 9:24 am
A Cyclic Redundancy Check (CRC) is a mathematical algorithm to determine if an error exists. A checksum is exactly that, just a sum of the data being transmitted.
An 8 bit checksum is where the individual bytes are simply added together modulo 256.
Hope this helps!
SherpaDoug
Posted: Thu Sep 02, 2004 2:44 pm
A checksum is very easy to impliment and fast to execute but may miss more errors than a CRC. Longer checksums or CRCs catch more errors than shorter ones but take more resources. _________________ The search for better is endless. Instead simply find very good and get the job done.
