how do I tell CCS to set the pic to use an external clock?
Nick
PostPosted: Wed Sep 01, 2004 1:20 pm     Reply with quote
My pic is using the internal clock and I want it to use the external. How do I go about doing that?
Nick
rnielsen
PostPosted: Wed Sep 01, 2004 1:53 pm     Reply with quote
Well, it would be nice to know ..which.. PIC you are trying to use. We only have a few different ones to pick from.
Nick
PostPosted: Wed Sep 01, 2004 2:18 pm     Reply with quote
ya, that was pretty dumb of me.
pic16f767
SherpaDoug
PostPosted: Wed Sep 01, 2004 2:44 pm     Reply with quote
If you mean the processor clock it is in the #fuses:
#fuses EC,WDT    // EC mode uses an External Clock, Watchdog
rnielsen
PostPosted: Wed Sep 01, 2004 4:44 pm     Reply with quote
If you want to see what fuses are available just select View on the menu bar within the compiler and then select Valid Fuses. Select the correct PIC and it will show them.
I believe the correct fuse statement would be:
#fuses EC_IO, // and any others that would be appropriate
This (EC_IO) makes OSC1 your clock input and also makes pin RA6 an I/O. Don't use this if you are going to use a crystal, only if you have an external clock source.
Ronald
Nick
PostPosted: Wed Sep 01, 2004 8:18 pm     Reply with quote
I found out my old version doesnt have that fuse I have 3.1, darn it.
Nick
bdavis
PostPosted: Wed Sep 01, 2004 9:32 pm     Reply with quote
If you have EC, you could use that also, and the OSC2 should be OSC1 divide by 4 output, but you don't get the IO pin usage on OSC2 that you would get with EC_IO. Does it show EC as a valid OSC fuse?
Nick
PostPosted: Wed Sep 01, 2004 10:37 pm     Reply with quote
no it doesnt show any of those fuse just the standard f76 ones. I'm going to get the update.
Nick
rnielsen
PostPosted: Thu Sep 02, 2004 8:47 am     Reply with quote
Just curious... is it possible to program the Configuration word with a command, something like #rom?
Ronald
