Adding WDT to a 12CE674
aphpic
PostPosted: Wed Sep 01, 2004 6:20 am     Reply with quote
Hi from your newest member
I have dabbled for a while with a PIC project and would like to add a WDT to try and make it bullet proof but as with all these things I have a problem.
I am using a 12CE674 and reading a 15kHz frequency on GP3 and ADC from a current sensor on GP0. Because of long delays I have set the prescaler on timer 0 to 1:64 but swap it to 1:1 each time I read the frequency then back to 1:64 again. So how would the WDT fit into this situation? I am probable not understanding the data sheet correctly because it says clrwdt resets the prescaler. Does this mean I have to keep setting the WDT prescaler each time and does it effect timer 0? A bit of code would go a long way!
Thanks in anticipation
Andrew
drh
PostPosted: Wed Sep 01, 2004 7:30 am     Reply with quote
The prescaler is assigned to either timer0 or WDT, not both. If you enable the WDT, your code needs to call RESTART_WDT() before the WDT times out. This should be about 18ms.
David
