runtime
| why this doesn't work, please help (fprintf with pointers... |
Posted: Tue Aug 31, 2004 3:27 pm |
Hello all,
I'm new to pointers, please help me out. Function SetTerminal is called from main subroutine to initialize modem. This does not work, I get nothing in PC stream nor MODEM stream...
Thank you in advance
// Function SendModem
void SendModem(int8 val) {
disable_interrupts(int_ext);
fputc(val, MODEM);
enable_interrupts(int_ext);
// Function SendCmd
void SendCmd(char *cmdstr)
int p;
// signalOk is made True when Modem answer
signalOk = False;
output_high(Connected);
q = 0;
do {
fprintf(PC,"%s\r\n",*cmdstr);
SendModem(*cmdstr);
for (p = 1; p <= 40; p++) { // 2 sec Timer to get response
delay_ms(50);
if (signalok) break;
q++;
CheckResponse();
} while (!signalOk && q < 11);
output_low(Connected);
// Function SetTerminal // Configure Terminal
void SetTerminal(void)
fprintf(PC,"Programming GPRS Terminal...\r\n");
SendCmd("AT+WIND=4\r");
SendCmd("AT+CLIP=1\r"); // Caller Id
SendCmd("AT+CICB=2\r");
// ... More Commands ...
JPA Guest
Posted: Wed Sep 01, 2004 2:43 am |
There are some strnge things I pointed out with your piece of code:
1) Pointer to constant string: due to the compiler behaviour (see previous posts), function SendCmd is called for each character in the constant string. Obviously, this is not what you want.
2) Your SendCmd function also have some problems: let's suppose the argument cmdstr points to the correct string (which is not the case , see pt 1 ), then I think that you should write
"fprintf(PC,"%s\r\n", cmdstr);" and not "fprintf(PC,"%s\r\n",*cmdstr);" see http://www.cplusplus.com/ref/cstdio/fprintf.html for more info.
The SendCmd function receives one byte as input and so will only send 1 char... |
