Unable to use PORTE as analog input
cxiong
PostPosted: Thu Aug 26, 2004 11:32 am     Reply with quote
I try to use PORT E as Analog input. I can't use any of PORT E for
Analog input. I want to use PORTE because I have the
PIC Demo 2 plus board and RA0 already connected to
a POT, A1-A3 are connect to the LCD control signal. I try to connect
a thermistor to RE0, but there is not useable, when I use
the switch ALL_ANALOG then it screwed up the LCD.
I want to leave PORT for the LCD and use porte for
the analog.
Please help!!!!
PostPosted: Thu Aug 26, 2004 11:44 am     Reply with quote
Of course you didn't tell us what PIC you're using, since we are
mind readers. And also the compiler version.
So I'll assume a 16F877.
Get the data sheet from Microchip for the 16F877.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2046
In section 11.0 of the data sheet, look at the chart for the ADCON1
register. It lists all possible settings for Port A and Port E.
Then look at the 16F877.H file in your text editor. This file is found here:
c:\Program Files\Picc\Devices
Find the section called: Constants used in SETUP_ADC_PORTS()
Then find the constant defined by CCS that matches the configuration
that you picked from the chart in the data sheet. Then use that
constant as a parameter when you call the setup_adc_ports() function.
That's how you do it.
cxiong
PostPosted: Thu Aug 26, 2004 12:14 pm     Reply with quote
I use the PIC18F458 and I did look at the device file the CCS
defined the constant. None of them match what I need.
Either set ALL_ANALOG OR most of the constant just for
PORTA.
Here I copy it from the CCS file. Which one is the right one
for setting PORTE RE0, RE1, RE2 to analog:
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS                           7    // None
#define ALL_ANALOG                           0    // A0 A1 A2 A3 A5 E0 E1 E2 Ref=Vdd
#define AN0_AN1_AN2_AN4_AN5_AN6_AN7_VSS_VREF 1    // A0 A1 A2 A5 E0 E1 E2 Ref=A3
#define AN0_AN1_AN2_AN3_AN4                  2    // A0 A1 A2 A3 A5 Ref=Vdd
#define AN0_AN1_AN2_AN4_VSS_VREF             3    // A0 A1 A2 A5 Ref=A3
#define AN0_AN1_AN3                          4    // A0 A1 A3 Ref=Vdd
#define AN0_AN1_VSS_VREF                     5    // A0 A1 Ref=A3
#define AN0_AN1_AN4_AN5_AN6_AN7_VREF_VREF 0x08    // A0 A1 A5 E0 E1 E2 Ref=A2,A3
#define AN0_AN1_AN2_AN3_AN4_AN5           0x09    // A0 A1 A2 A3 A5 E0 Ref=Vdd
#define AN0_AN1_AN2_AN4_AN5_VSS_VREF      0x0A    // A0 A1 A2 A5 E0 Ref=A3
#define AN0_AN1_AN4_AN5_VREF_VREF         0x0B    // A0 A1 A5 E0 Ref=A2,A3
#define AN0_AN1_AN4_VREF_VREF             0x0C    // A0 A1 A5 Ref=A2,A3
#define AN0_AN1_VREF_VREF                 0x0D    // A0 A1 Ref=A2,A3
#define AN0                               0x0E    // A0
#define AN0_VREF_VREF                     0x0F    // A0 Ref=A2,A3
#define ANALOG_RA3_REF         0x1         //!old only provided for compatibility
#define A_ANALOG               0x2         //!old only provided for compatibility
#define A_ANALOG_RA3_REF       0x3         //!old only provided for compatibility
#define RA0_RA1_RA3_ANALOG     0x4         //!old only provided for compatibility
#define RA0_RA1_ANALOG_RA3_REF 0x5         //!old only provided for compatibility
#define ANALOG_RA3_RA2_REF              0x8   //!old only provided for compatibility
#define ANALOG_NOT_RE1_RE2              0x9   //!old only provided for compatibility
#define ANALOG_NOT_RE1_RE2_REF_RA3      0xA   //!old only provided for compatibility
#define ANALOG_NOT_RE1_RE2_REF_RA3_RA2  0xB   //!old only provided for compatibility
#define A_ANALOG_RA3_RA2_REF            0xC   //!old only provided for compatibility
#define RA0_RA1_ANALOG_RA3_RA2_REF      0xD   //!old only provided for compatibility
#define RA0_ANALOG                      0xE   //!old only provided for compatibility
#define RA0_ANALOG_RA3_RA2_REF          0xF   //!old only provided for compatibility
Which of the above is the right one?
NOTE: the constants are similar for both pic18f458 and pic16f877
PostPosted: Thu Aug 26, 2004 12:23 pm     Reply with quote
The Port E and Port A settings are shown in the 18F458 data sheet in
Section 20. The chart shows that you can't set Port E to be analog pins
just by itself, while keeping Port A as digital.
This is a limitation of the PIC hardware. You will have to re-design
your external circuit so it will work with the Port A and Port E settings
that are listed in the data sheet.
treitmey
PostPosted: Fri Aug 27, 2004 8:20 am     Reply with quote
Are you trying to use the TC74 in position U5 on the PICdem2 plus board?
cxiong
PostPosted: Fri Aug 27, 2004 9:36 am     Reply with quote
I add more thermistors into the demo board, and I also
add a low voltage detector circuit to the demo board to monitor the
9V battery. I run out of Analog I/O due to RA1 - RA3 tied to
the LCD on the demo board. That's why I try to use PORT E.
rnielsen
PostPosted: Fri Aug 27, 2004 10:21 am     Reply with quote
The best thing to do is to download the spec sheet, from Microchip, and look what configurations are possible. From what I could see if you want to use AN5, AN6 or AN7 (PINS RE0, RE1 and RE2) all of PortA will need to be set as analog pins as well.
Ronald
Mark
PostPosted: Sun Aug 29, 2004 10:39 am     Reply with quote
Here is a hint:
A pin can be an analog input in one part of the code and an output in another part of the code provided the changing doesn't affect the LCD.
